Honeywell emm-3 goes to high heat when thermostat does not call for heat
Have a Trane furnace, will suddenly turn on when thermostat does not call for heat. The honeywell emm-3 electronic mini zone shows red light on, indicating heat is on. Goes to full high call for heat and will run exceeding the setting on thermostat. Example we have it set to 69 and tonight we came home to furnace running on high and temp in house at 73
    Master:
  • 613 Answers
Replace it (thermostat), but first make sure its in a good location to read the space temperature.
Posted on Dec 14, 2013
tborn6
  • 700 Answers
SOURCE: Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Posted on Jan 25, 2009
  • 61 Answers
SOURCE: thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Posted on Feb 19, 2009
  • 52 Answers
SOURCE: Improper Termperature Readings during AC run
personally i'd just replace the thermostat, but try pulling the front panel off and look on the circuit board and see if there is a jumper for F/C or any other settings. you may try changing its position. you can also remove the batteries for 15 minutes and see if it resets itself. the only other thing it could be is a wiring issue.
Posted on May 29, 2009
kapishtech
  • 2272 Answers
SOURCE: Honeywell thermostat; Lennox elite series
When the furnace exceeds the temperature set by the thermostat, this could be indicative of several issues. The thermostat mounted crooked. When a thermostat isn't level on the wall, it can affect the automatic on/off function. To fix this problem, pop the cover off of the thermostat and loosen the screws attaching it to the wall. Straighten the device and tighten the screws.
If the thermostat is level and the temperature regulation system is still malfunctioning, the problem is most likely with the heat anticipator setting. The heat anticipator is a device inside the thermostat that governs when the furnace turns off. When the heat anticipator is on the fritz the furnace doesn't receive accurate direction, resulting in a heat system that either runs too long or not long enough. Usually, simply adjusting the heat anticipator, which is a small disc located underneath the thermostat cover, will fix this problem.
  • Temperature Does Not Reach or Exceeds Setting
  1. Thermostat is not level ? Use a level to realign thermostat.
  2. Anticipator not set correctly ? Adjust the anticipator.
  3. Thermostat not calibrated ? Recalibrate line voltage or low voltage thermostat.
  4. Range stop incorrect ? Clean thermostat and check .if same problem then,Replace thermostat.
  5. To clean thermostat.
  • Kill the power at the circuit breaker panel.
  • Remove the thermostat cover.
  • Clean the bimetal coil with a soft, clean brush.
  • Remove the thermostat body by unscrewing the retaining screws (on a round thermostat). Slide a piece of bond paper between the lever and contacts to clean them.
  • Reassemble the thermostat.
  • Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
    Posted on Sep 21, 2010
    carmin77
    • 113 Answers
    SOURCE: I have a Honeywell EMM-3
    Zoning, in the A/C world, refers to different areas of the house which may be cooled to different temperatures. Zoning is accomplished by closing/opening vents.
    Zone 1, 2, 3 etc. do not have any particular meaning, except to indicate zone control flappers 1, 2, 3 etc. which are physically inside the ductwork which determines the zoned area.
    Just because you have this fancy thermostat, does not mean that your house is actually zoned, but I am not to sure why such a thermostat would be purchased if it was not (unless it was free).
    Zoning uses dampers. Is there air blowing out of the registers?
    :o).
    Posted on Jun 04, 2011
    How can I connect an Intertherm furnace with a heat pump to a new Honeywell thermostat?
    Ensure that that thermostat is for a heat pump and has connections for the emergency heat strips.
    Feb 02, 2016 | Heating & Cooling
    Honeywell thermostat blows cold air on heat
    Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
    Oct 06, 2014 | Honeywell Heat/Cool Thermostat
    Heat/Cool does not respond after replacing Trane Weathertron BAYSTAT239 with Honeywell RTHL3550
    Sounds like you didn't turn the power off and blew the low voltage fuse. Typically a 5 amp blade style (like a car) inside furnace. TURN THE POWER OFF!!
    Jul 13, 2017 | Heating & Cooling
    Trane xv95 converted to propane is on system lockout
    There is either a problem with the ignitor or the flame sensor.
    Nov 18, 2013 | Honeywell Electronic Programmable...
    I just got a new Honeywell Utility Pro Thermostat. The digital temperature gauge seems very sensitive which results in the unit turning the furnace on and off for very short periods; much shorter than my...
    Sounds like you also have a high efficiency furnace like mine.
    Here is a procedure to slow down the number of cycles you are experiencing.
    1. press System
    2. press and hold buttons 3 and 5 on the bottom of the screen. (there should be 7 buttons displayed)
    3. set code to 240
    4. change setting to 3 for 3 cycles per hour. (your thermostat probably shows a higher number, probably 5? That is why your unit is cycling so often).
    Jan 20, 2011 | Honeywell Electronic Programmable...
    I have a honeywell ct3200 with a trane xl 80 furnace. it will cycle on to the right temp, go off and cycle the furnace back on 30 seconds later. Is that normal? It is 32 degrees outside, set at 68
    Hi, check page 22 in your manual, it says "Adjust the screws on the back of the thermostat as instructed on page 7." Your furnace is a 80% efficiency but is also a high efficiency 2 stage heating system so try adjusting screws A and B both ways and see which gives you the correct cycling.
    Your manual is here:
    http://customer.honeywell.com/techlit/pdf/69-0000s/69-0653.pdf
    Jan 18, 2010 | Honeywell Programmable Thermostat Heater
    New Trane XV95 furnace runs and stops nine
    if it is a mechanical thermostat the heat ant. does that on cheaper digital tstats it is set by span and on better stats like honeywell model 5000,6000,8000 series you set the cycle rate. what kind and model number is tstat
    Dec 19, 2009 | Goodman GDS80904BNA Open Flame Heater
    Need wiring for honeywell pro 3000 in trane xe1200
    the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
    May 16, 2009 | Heating & Cooling
    Honeywell rth230b won't shut off heat
    Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
    Hope that helps...
    Geno
    Mar 07, 2008 | Honeywell Programmable Thermostat Heater
    Heating & Cooling Logo
    166 people viewed this question
    Top Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Donni Steen
