When switching in lg fuzzy logic 13kg T1308TEFT0 it displays PE
2 Suggested Answers
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
Fuzzy logic washing machine 12.5kg. What does PE code indicate?
PE pressure level switch error. This monitors the water level. It has a tiny hose connected from the drum. Could be blockage in the hose.
Feb 16, 2016 | LG Washing Machines
My lg fuzzy logic shows PE
The PE or pressure sensor error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
May 30, 2015 | LG Washing Machines
LG Fuzzy logic PE error
Pressure switch may be faulty.
May 15, 2015 | LG Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
What is a PE error on LG fuzzy Logic? beeping at the same time
Pressure switch fault......could be just blocked pipe!
locate pressure switch under top cover....far right corner, disconnect thin rubber pipe and blow through it to clear any blockage......might be lucky!
Oct 19, 2014 | Washing Machines
Hi ihave a lg fuzzy logic wf-1022tp top loader. When I switch it on it says PE pings whole time please HELP
You have a problem with the pressure switch (water level sensor).
Either a faulty switch, blocked air chamber or hole in the pressure hose linking the chamber to the switch.
Thanks
Jul 14, 2014 | Washing Machines
How to reset eprom for PE error
Hi, PE error code means there is an pressure sensor error in your machine .You need to check pressure it will be giving incorrect indication . Pressure switch is faulty you need to change it . Procedure for changing is : 1.Power off the machine remove backcover and top cover. 2.The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached. 3.It generallysits just under the top cover.
Apr 08, 2010 | LG WFT1071TP Top Load Washer
WHAT IS THE SOLUTION ON ERROR MESSAGE PE IN MY FUZZY LOGIC WFT601
There is a round clean out door accessed from the front of your unit. Some models you have to take the lower panel off entirely to clean it out. It unscrews and probably there is anything and everything you can imagine clogging the pump inlet....thus the error message "PUMP ERROR" THe unit's error code may manually have to be deactivated in the control panel to reset the unit to normal operation.
Nov 30, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
