Question about Sharp EL-531VB Calculator
Get rid of the RAD
Hi, On my screen I have RAD showing and I cannot use the 7 button, how can I get rid of this. Please help
  • Sharp Master
  • 7,993 Answers
You use the key combination [2ndF][DRG]. Every time you press the two keys in sequence it changes to the next angle unit. If your calculator is on RAD, you press [2ndF][DRG] once to change to Grads, and another time [2ndF][DRG] to change to degrees.
Hope it helps
Posted on Sep 17, 2009
How to get rid firefox ask
Go back into about:config and steps below:
  • When you are in Firefox, navigate to about:config like you are going to a website.
  • Click the I'll be careful, I promise! button to continue
  • In the search bar at the top, type ask.com
  • Under the searchbox you will see some prefs. Right click each of them, and click Reset.
  • REstart Firefox and see if it is fixed.
And also i share a informative link please visit and rad it. I hope solved you issue.
http://www.wikihow.com/Get-Rid-of-the-Ask-Toolbar
Thanks,
Apple Support
May 25, 2014 | Computers & Internet
My phone has a black screen, it doesnt show the nokia logo when turned on. what shall I do? please help
Hi bro....don't take tension, i just faced the same problem n get rid of it. You need to do as: It is just processing fault during booting on start up. Just press switch on button for some time and then leave it as for about 20 minute without pressing any other key, it will surely switched on.
Jul 22, 2011 | Nokia E63 Cell Phone
Dell inspiron mini -- at first it works fast but suddenly the screen goes black and I don't know why. I tried pushing the power button but it didn't work, the power button still lights up (so meaning, it...
Hi, Please try removing the battery and then starting it. Those beeps are error codes that help tech support people identify the problem, The easiest solution is to take the laptop to service center. Good Luck
Apr 01, 2011 | Dell Inspiron Mini 10 Notebook
I have a new samsung wave 533 mobile handset.Please let me know how to get rid of widget 10 application items(they are making the screen opech) display on my mobile screen.
Hi! To remove widgets, just long press the central button between the "accept call" n "reject call" buttons under the screen. It will show u options to end all applications or particular applications. Just press the "End all applications" button and all ur widgets will shut.
Jan 03, 2011 | Samsung Cell Phones
Our son pushed some buttons, and now we cannot get rid of the square in the upper right corner that says "video 2". HELP!
Video-2 is on-screen display. Press Display/ info button on tv remote, on-screen display will disappear.
Please note that only Sony tv remote will work to cancel on-screen display.
Thanks.
Jul 28, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
How do you put casio fx-300MS in degrees mode? please help
To change the default angle unit, you press the [MODE] button a certain number of times until display shows a rectangle inside which Deg Rad Grad appear on the top line and 1 2 3 on bottom line, with 1 under Deg, 2 under Rad, and 3 under Grad.
Press the number key corresponding to your case, 1. All angle values you feed the trigonometric functions will be considered to be in degrees. If you use the inverse trigonometric functions to find angles, the results will be in degrees.
Hope it helps.
Thank you for using FixYa and do not forget to rate this free solution.
Nov 04, 2009 | Casio FX-300MS Calculator
I can`t seem to get rid of the clock or channel on my screen HELP
Press Display or "info" button on Sony TV Remote, on-screen display will disappear. Please use TV Remote, no other remote will work for that.
Jul 15, 2009 | Sony KP-57WS520 57" Rear Projection...
Cannot type numbers etc
Press the reset button on the back of the unit. As to the things you want to get rid off, if they are on the top of the screen, they are indicators, to let you see what mode you are using. Some will change when you chande operation mode. There is nothing you can do about it.
However if these symbols are in the center of screen , with numbers to there left (a different number for each) they may be part of the setup procedure. During the setup procedure you are expected to configure your calculator in the mode relevant to the calculations you intend to perform.
What is an upside down p ? Could it be just a b? (as in binary). That is a mode of operation.
Hope it helps.
Feb 12, 2009 | Sharp EL-531VB Calculator
Error
Since the 2nd Button works press [2nd] [MEM] [7:reset] [F1][All ram] [ENTER]. That may help
Jan 13, 2009 | Texas Instruments TI-89 Calculator
Canon MPC 190 Imageglass printer
Hi, taken from here: http://www.fixyourownprinter.com/forums/printer/27470
1. Press MENU COPY SCAN COPY COPY
2. This will take you to TEST MODE
3. Use the + key to take you through to PRINTER TEST (option 8)(if you go past, either keep keying the +, or you can use the - to take you back)
4. Ensure that it shows 8-3 on the screen. This is EEPROM CLEAR
5. Press OK
6. It will show 0 INK COUNT
7. Press OK
8. Press the STOP/RESET button
9. Press the ON/OFF button
10. The printer won't turn off, but will "reset" itself (or something).
I'm not sure what this does, but it gets rid of the "WASTE INK NEAR FULL" message and you should be able to print again with no problem.
Feb 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Sharp EL-531VB Calculator Logo
513 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
