Question about Olympus FE-270 Digital Camera
Card Access lamp keeps blinking
When I take a picture the card access lamp (orange light) wont stop blinking. Do I need a new XD card or something
    Problem Solver:
  • 7 Answers
Hi
It sounds like you have either intentionally or inadvertently set your camera to it's highest possible setting.
I believe this camera has a TIFF image capability, which takes beautiful shots , but each weigh in at a hefty 15mb or so, which takes the cameras processor a little more time (quite some time on my old Olympus Camedia 5000z) to process and ready itself for the next shot in memory, - whilst it will allow you to knock out a couple in a row, if you do so you are only compounding the issue by lengthening the queue in memory.
So, the easiest way to tell if you have set this is to just look how many shots you have available on the card, if this seems unusually low, then you have set the camera to TIFF mode or a very hi res JPEG. in which case you must press the settings button, the go left into the image size settings menu and change the image size back to the best setting for your cameras, which should be a mega pixel or so lower than it's maximum capability for the fastest and most capable daily use of the camera. between 2-4 mega pixels is usually fine for domestic and family snaps that are still very printable. save the hi settings for the broad landscapes and super close Macros, then you really see the cameras capabilities shine!:-)
Highest resolution is fantastic, but slow -as you have noticed - and best saved for the occasional macro on a tripod.
I hope this solves your problem. Otherwise you can try formatting the card, they do often gather batches of small undeleted 'thumbnails' on Olympus cameras.
Also if the card is over 2-3 years old, you could well be right in your assumption that it needs replacing, in which case you will be pleasantly surprised how cheap they have become for much larger capacity cards.
All the best and happy snapping!.
Posted on May 09, 2009
Why my card access lamp cannot blink anymore?can you help me?
Posted on May 28, 2012
Just put a new lamp in my 92in Mitsubishi tv and know a orange light was blinking what is that
You may have solved it by now, but the lamp access door needs to be installed or the orange light will flash.
May 06, 2015 | Mitsubishi Televison & Video
What does the card error mean
Can be lots of things. Would have been handy, if you had told what card you are using. Your camera can work with CompactFlash, Microdrive and xD-Picture cards.
If you did not insert the card(s) you are using, correct, or you removed the card in a wrong way, you could have damaged the cardholder, causing an error you probably can't repair yourself. The CF and Microdrive you can remove by pressing the eject button. The xD-Picture card you can remove by pressing in the card, and release it. The card comes out.
Then you could have damaged the file system, by opening the card cover, while the card access lamp was blinking. What ever card was in, the filesystem can be damaged.
Then you can have two cards in, Both, o CF of Microdrive and a xD picture card. Some settings are required for the camera, to know hat card it should use.
If you have an Microdrive, the drive can be damaged, by a magnetic file, or the drive just stopped rotating. A micro drive is actual a miniature spinning hard drive.
First check if the memory card is inserted correct. Eventually, remove it and check all contacts, on the card and in the camera. Then try formatting the card. If you think there could be important pictures on the card, put it in a external card reader and use a recovery program, to see you can recover the pictures on your computer. Programs can be found on the net.
If you can't format the card, check if you have a Microdrive. If so, try to replace that with a CF or xD card.
I hope something is to any use for you.
Next time, please give us some more details. I know you exactly see and know what is not working, but we only can use your description. And only what you give us.
Feb 16, 2014 | Olympus E Cameras
Hi, I have D90 standard package with 80-105 lens kit and I'm using it with 16 GB SD card. I'm using it almost a year now however last few weeks, when camera is on "off mode", little yellow light...
That is the card access lamp. It should light briefly when you insert a card and when you take a picture. If it's constantly blinking, something is wrong. Try removing and re-inserting the card. Try a camera reset with no card in the camera. Try downloading the pics to your computer and then formatting the card in the camera to completely erase it.
Mar 16, 2011 | Cameras
Format problems
Hi: Did you unlock the XD?
If the Xd is not unlocked, then you can not access it and format it.
Your Xd might be too big for your camera.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Cyber Master
Jun 28, 2009 | Cameras
Formatting error on my olympus fe-340
never format the card from the computer... format using the camera.. use data recovery software to retrieve pictures if you have not formatted it... also make sure to "safely remove hardware" before actually unplugging the camera from the computer
Apr 06, 2009 | Olympus FE-340 Digital Camera
Olymp c-5000 won't turn on red/ yellow lights blink/ beep 20 time
Furrybutts (hehehe, like the name), This could be a lot of things and I'm sure there's a service guide out there that will tell us what 20 beeps and flashing lights mean, as I don't have one, let's figure it out.
Firstly, digi-cams and rechargables, eerrrrrgggg (Mr Burn's shudder) yeah they 'work', but for trouble shooting and iffy times, lets look at some half desent NEW alkaline batteries - for about $3-$4, it's worth it for this troubleshoot.
OK, did they work?, No?, lets look at the memory card. The cards are supporsed to be only put in one way, but ... lets take out the card, clean the contacts with a clean cloth/tissue, and put the card back in being sure it's in the right way. Still no go?
Take the card out again and try and turn the camera on without the card. Any changes?
This camera uses an XD memory card. I can't remember if it has an internal memory - what we're looking for is whether the memory is damaged and the camera is happy using it's internal memory or still erronous with no memory. Do you have access to another XD card to try it (this camera will take a MAXimum of 512mb, so don't try and card bigger).
Lets leave it at this for now and you let me know how things are going?
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 02, 2009 | Olympus Camedia C-5000 Zoom Digital Camera
Memory access lamp flashes
WHEN POUTTING INN A MEMORY CARD ON NIKON DSLR CAMERAS THE GREEN LIGHT WILL BLINK ONE TIME .
IF IT CONTINUES TO BLINK THE CARD COULD BE BAD AND TRY TO FORMAT IT .
ALSO YOU COULD HAVE A BAD COMPRESSION BOARD.
Oct 29, 2008 | Nikon D70s Digital Camera
I have new olympus 850SW with the required Olympus xD picture card, 1 GB & can't access the in camera panorama...I know I did it once but it is grayed out now - only pano on PC available...I've read...
To access the panorama mode in the camera you need to be in P mode.
To set the P mode you need to press the Ok button right arrow to P for Program Auto and press Ok. Then as long as you are using an Olympus xD card you should be able to go to menu and highlight the Panorama option.
Oct 05, 2008 | Olympus Cameras
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
No power
a blinking red light next to the viewfinder means one of the following:
It most likely is an xD-Picture Card Warning--meaning
no card inserted, card not formatted, incorrect format, card full, xD-Picture Card error (perhaps it was scratched when you removed it, or it received a shock.) If it looks dirty, clean it with a cotton cloth.
Have you touched your xD card? It is located in the battery area. You can either pull it out, or push it in and it pops out. Perhaps it wasn't pushed in all the way. Try that first. If that doesn't work, do you have another xD card to try? Maybe you can find the little one it came with--usually a 16 MB card. The 512 MB are pretty cheap these days online. I know that my card works whether or not it is formatted in the camera or by my computer, as I download all my pictures into my laptop with its card reader. If you did that, and erased the Fuji file the images usually sit in, you might have to download the card with a computer card reader, as the finepix software might not work. You will find loads of programs happy to download from a card reader--I like Windows live photo gallery. In fact, that is the ONLY thing I like about Vista. My camera then always reformats the xD card when I put it back.
One explanation: "The xD-Picture Card will work well for long time, but will sooner or later lose its ability to store and play
back images or movies. If this happens replace it
with a new xD-Picture Card."
If something is wrong with the xD card, an error message should appear on the LCD display. If you haven't fixed it with the info I;ve provided you, let me know what the error message says.
Mar 09, 2008 | Fuji FinePix E550 Digital Camera
Olympus FE-270 Digital Camera Logo
189 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
