Question about Brother MFC-8840D All-In-One Laser Printer
Document Cover Open
I have a Brother MFC 8840D laser mutifunction copier/fax.  I have an error message of "doc cover open" after removing a jammed document through the top feeder.  I have checked that there is no papers stuck in copier feeder, but I cannot get the message to clear.  I have turned the unit off and on and I cannot clear the message error.  Please assist.
  • 2 more comments
  • mheinz May 01, 2008
    I am seeing Doc. Cover Open with instructions to remove original and then close cover  on the LCD, the hinges look fine, what else could it be??  I've restarted the machine.
  • ivoss Jun 16, 2008
    I lifted the document cover and pushed and held the  sensor lever in the left and back of the open lid and the error message "Doc. Cover Open" went away and I could copy and print again.
    Ingrid
  • Anonymous Jun 17, 2008
    ERRO A 6
  • Anonymous Aug 27, 2008
    I cannot use the fax bec doc. cover open but no more paper or mispeed paper how could fix this prob.
I had the same problem with mine. Lift the top scanner, and check the hinges on the left. That error message means that the little black sensor on the left next to the hinges is not meeting flat with the unit when closed. Hold the sensor in for a few seconds, and your printer will start working properly.
Posted on Jul 09, 2008
Their rest botom in under the cove bush it to rest the sensor to clear the error ( cover open).
Posted on Jun 17, 2008
Open and close the feed cover and do the same with the front cover. It seems to me that I've had to do that to clear the error before. Otherwise... I'm not sure.
Posted on Nov 02, 2007
  • Brother Master
  • 1,113 Answers
Left hinge is broken, replace with new hinge
Posted on Dec 08, 2007
  • Soulvisitor
    Soulvisitor Dec 16, 2007
    parts LINK
    problem part that I have changed 10000 times
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Another cover not closed properly or a sensor not being triggered
Posted on Oct 11, 2007
Check paper error
Sir/Madam
I Think There is paper jammed in the printer.
Action:
Press button A, open the front cover and remove the jammed media.Make sure that there is no paper jammed in the paper trays.
Or Still Having Brother Printer Problem The Follow Us For On: Brother Printer Support
Jan 23, 2014 | Brother MFC-8840D All-In-One Laser Printer
I removed a jammed paper from my Brother MFC-8840D and there seems to be piece still stuck and i dont know how to retrieve it
Try openning the front cover remove the drum and toner remove the toner from the drum, close cover, turn printer off and on. Then reinstall drum and toner.
Apr 01, 2010 | Brother MFC-8840D All-In-One Laser Printer
How to remove back corner panel at feeder cable in Brother MFC 8840D
If you mean the top left of the doc. feeder, you remove the cover by flexing slightly, remove a phillips screw, lift the scanner cover and there's a square hole on the lid with one of those flex clip retainers that you use a screwdriver to lift.
Jan 22, 2010 | Brother MFC 8840D All-In-One Laser Printer
The error message says Doc. Cover open but the cover is closed
You will probably have a broken hinge at the back left hand side of the Doc. cover.
This means that the cover won't close properly at the back corner, and the cover sensing switch won't actuate.
Dec 08, 2009 | Brother MFC-8840D All-In-One Laser Printer
Doc cover open errror message on a mfc-8840d and cant' seem to print anything and the mode always is in fax mode and we can't seem to change it.
That error happens when the left hinge in the back breaks and the scanner cover won't shut all the way. temporarily you can tape the switch that is above the hinge and when the error is gone the modes should change again. The hinge is #LP2403001.
Oct 16, 2009 | Brother MFC-8840D All-In-One Laser Printer
Brother 8840D ADF not working. The flat bed scanner runs instead for fax or copy. Displays Doc Cover Open message
Open ADF and close again. There must be tab in the ADF which is not pressing a microswitch located in the lower part of the ADF. IF you can locate it, try pressing it manually.
Jun 06, 2009 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 8840D still says change drum soon
Open the front cover
press clear/back button
press 1 and when the lcd shows accepted, close the front cover.
thanks adi
Apr 27, 2009 | Brother MFC 8840D All-In-One Laser Printer
Doc. Cover Open displayed...remove original and then close cover.
Left rear hinge is cracked stopping lid from closing fully. Tape down black switch left corner near glass rear. Or replace hinge
Dec 15, 2008 | Brother MFC-8840D All-In-One Laser Printer
Error Msg: PAPER JAM in Brother MFC-8840D
one of the jam switchs is stuck down or paper concertina in fuser assy
Dec 28, 2007 | Brother MFC-8840D All-In-One Laser Printer
Doc cover open
3 screws easy fixf5f7046.jpgno tec needed bout 25 bucks for hinge see my other post re this problem 8025, 8820,8840,8225 same same
Dec 26, 2007 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC-8840D All-In-One Laser Printer Logo
458 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
