Question about Kitchen Ranges
Wiring problem I am wiring in a smeg se2640 tc electric (ceramic) hob. I have a type 2 terminal board - do I need to purchase terminal push on connectors? Also has three core cable - can you confirm red wire terminal 1 is live wire and terminal 4 white wire is neutral. Thanks, Dave
    Scholar:
  • 43 Answers
If they only way to fit your cable is by using the terminal push on connector (which, frankly, i'm not 100% sure what that's describing) and you can easily get that from your hardware store then yes, as long as you can connect up your wires without difficult and without stray copper.
Red wire is live, but white may be live as well during one aspect of operation. Usually neutral is black or blue. If your cable has red white and blue color in it then your using a 3 phase cable. A single phase 3 core cable will have red/brown black/blue green/greenyellow.
Hope this helps. Let me know.
John
Posted on May 09, 2009
What is the worst that could happen if an electric double oven ceramic hob had the neutral and earth mains power wired the wrong way round ?
Electronic controller would most likely be damaged and need to be replaced. These things usually cost between $350-$400
Nov 28, 2014 | Ovens Ovens
Why is my electric cooker tripping?
there is a short in the wiring
May 15, 2014 | Kitchen Ranges
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
Mar 11, 2014 | GE Cooktops
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
SMEG SE435X-1 60CM Electric hob. Keeps tripping fuse
It's possible that one of the burners stay on for a long time, which cause one of the wires to overheat, breaking the connection and touching the body of the unit, please turn the breaker off and check for a loose connection, replace the wiring if you feel confortable doing it yourself or contact a technician.
Jan 06, 2010 | Smeg 23 in. SA435X Electric Cooktop
TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
May 18, 2009 | Cooktops
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Nov 28, 2008 | Neff T1323 Electric Cooktop
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Kitchen Ranges Logo
174 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
