Question about Eastwood Mig Welder 175 Amp 220VAC Welding Spool Gun
Spool gun spins backwards - Eastwood Mig Welder 175 Amp 220VAC Welding Spool Gun
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    Why wont the wire come through my cosmo gas gasless welder
    Most mig welders have reversible feed spools. There is a good chance you have the spool in the .030 wire side. Remove the spool retaining clip and flip the spool to .023 wire for example. I don't know what size wire you are using. Also there is an adjustment for the drive spool. Tighten the tensioner spring thumb screw to increase the feed tension.
    Apr 28, 2014 | Welding Tools
    Can I use my spool gun with steel wire
    you can use spool gun but-you won't be able to switch it to aluminium-if you don't do al not a problem-and spool doesn't hold much wire-gun is heavier and big -not able to get into tight or angled places-cheers Denny
    Nov 04, 2013 | Welding Tools
    I have a Migmatic 200 Canox (millar)ser# kb060228 and would like to purchace a spool gun to use with it . There is a 14 pin remote feeder plug on th front. Is there a spool gun available for it, or do I...
    They make a spool gun for it, it has a round 7 pin connector like an RV trailer with braking would use.
    If yours is truly a 14 pin, you can use your schematic and the one for the spool gun made for your machine to rewire it to work for you.
    this is the manual for the gun that made for your welder:
    http://www.millerwelds.com/om/o250884a_mln.pdf
    Jan 07, 2012 | Welding Tools
    Hello, I would like to purchase 3035 spool gun and attach it to my self made welder. Could somebody to tell me which power supply I have to provide for spool gun motor? DC voltage, amperage ? Can I use...
    the spool gun is a 12volt motor, i usely hook it to the power feed for the feed motor in the welder. it is also 12 volt . i have heard of some welders that have 110 volt feed motors but have not seen one yet but just to be save i would test the power feed to the feed motor before i made the connection.
    Mar 11, 2011 | Hobart Handler 210 Wire Feed MIG Welder
    023 wire caught in line from machine to trigger on my 175 T lincoln welder
    first stretch the gun lead straight ,unlock feed rollers try gently to real the wire spool backwards,if it wont move then cut the wire back towards the spool so you can take the gun off the unit lay it staight out use pliers and try hard to pull wire out.if that dont work you will have to replace liner.
    Nov 29, 2009 | Lincoln Welding Tools
    Spool gun not working
    Was it working before?? If so check switch on gun/relay in welder and connections. If not it is not connected properly/bad relay/ gun switch/ or bad spool gun.
    Mar 16, 2009 | Welding Tools
    Eastwood Mig Welder 175 Amp 220VAC Welding Spool Gun Logo
    60 people viewed this question
    Top Eastwood Tools & Hardware - Others Experts
    John Trevino
    Are you an Eastwood Tool and Hardware - Other Expert? Answer questions, earn points and help others
