Question about Brother MFC-9840CDW Laser Printer
Imposible imprimir 2A - Brother MFC-9840CDW Laser Printer
2 Suggested Answers
mariolands
  • 2296 Answers
SOURCE: imprimir .imposible 4F
The 4F error code message indicates that the printhead is dead, you will need to replace it to make it work again. Before you replace it, you may want to try this, see if it will remove the clean unable error message: Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3. This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Posted on Feb 13, 2011
How do I sole system of equations
To solve a system of equations, there are two algebraic ways to solve them, one is by substitution, while the other is elimination.
1) 2a + 3b + 5 = 0
2) 2a + 4b + 10 = 0
-b -5 = 0 (subtract 2 from 1)
+b-b-5 = b
-5 = b
Substitute into 1) to solve for a.
2a + 3(-5) + 5 = 0
2a -15 + 5 = 0
2a -10 = 0
2a -10 + 10 = 10
2a = 10
2 2
a=5
Substitute into 2) to check if we did it correctly.
2(5) + 4(-5) + 10 = 0
10 -20 + 10 = 0
0=0
Good luck.
Paul
Feb 10, 2015 | Office Equipment & Supplies
Imprimir imposible 36
Print impossible messages or similar almost always indicate a full waste ink tank. These can be emptied and the purge counter reset, but it is a messy pig of a job. Do a check on google or similar for instructions and demos,
e.g.
http://printercartridgesinkuk.blogspot.co.nz/2014_06_01_archive.html
and disassemble the machine to get to the waste tank mounted (usually) behind the cartridge bay. Clean and dry the pads, then put it all back together and run the reset code.
Aug 11, 2014 | Brother Ink for Dcp-6690cw and Lc-1100
Como soluciono el error B200 de la canon MP250
De acuerdo a lo que lei en un foro esto se produce por recalentamiento del cabezal al imprimir con un cartucho sin abastecimiento de tinta, tienes que cambiarlo o prueba con desintalar la impresora del windows y lo reinstalas despues.
Aug 30, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
Tengo una i,presora HP P4015n y ne sale un error 49.FF04 error turn off then on, como soluciono este problema?
Tengo un problema con la i hp 4014n, de repente empezo a imprimir los documentos con partes en blanco o imprime algunas partes otras no... marca error y no se puede imprimir el documento pero lo imrpime igual solo q con este problema
Sep 19, 2011 | HP LaserJet P4014n Printer
Como tirar apenas um lado da folha?
Para imprimir dois lados documentos utilizando o software Lexmark, por favor siga os passos abaixo:
  1. Com o arquivo aberto, clique em Arquivo> Imprimir.
  2. Na caixa de diálogo Imprimir, clique no botão Propriedades, Preferências, Opções ou Configurar (dependendo do programa).
  3. A partir da guia Layout de impressão, selecione o layout e as configurações de duplex para o tipo de documento que pretende imprimir.
  4. Depois de ter aplicado todas as configurações desejadas nas Propriedades de impressão, clique em OK na parte inferior da tela para retornar à caixa de diálogo Imprimir.
  5. Clique em Imprimir para concluir a tarefa.
Nota: Esta é traduzido usando translate.google.com.
Jul 25, 2011 | Lexmark Refurb X1185 All-in-One USB...
Como imprimir una foto
Ver la foto, mantenga el dedo hacia abajo hasta la opción de guardar que aparece.Guardar la foto. Salga de la aplicación, e ir a sus fotos. Buscar la foto que acaba dedescargar y enviar por correo electrónico a ti mismo. Ir a la computadora de tu casa (ocualquier computadora con una impresora), abra su correo electrónico, e imprimir la foto.
Feb 28, 2011 | Facebook Apps
Imprimir .imposible 4F
Feb 09, 2011 | Brother MultiFunction Center MFC-440CN...
Buen dia mando a imprimir a travez del pto.
prueba con otro cable. tamb me paso eso alguna ves.. y era problema de cable y fijate la configuracoin de bios epp bi
Jan 13, 2010 | Epson DFX-9000 Matrix Printer
No puedo imprimir, me aparece error, la opcion de tintas me parpadea y aparece una E encopy menu
la foto copiadora funciona muy bien,pero cuando voy a imprimir ,sale el papel en blanco.
Jan 30, 2009 | HP Deskjet F4140 All-In-One InkJet Printer
Problemas a Imprimir, recuadros y lineas
Sounds like a dirty seal glass. Clean the glass on the left side of the scanner. The 1/2 inch strip of glass.
Feb 12, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Brother MFC-9840CDW Laser Printer Logo
227 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
