Windowx xp booting time no icons appear.
At the time of booting no icons displaying in windows xp sp-2
after 1). pressing ctrl+alt+del 2). select task manger 3). open New task 4). type explore.exe then only windows xp showing its desk top and start ment. What is the reason.
  • 432 Answers
Changing the default shell (all users):
1) open regedit (start menu > run, and type in regedit)
2) go to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon.
3) Change Shell from explorer.exe to the new shell path e.g C:\Litestep\litestep.exe
4) log out and log back in.
Changing the default shell (only current user):
1) open regedit (start menu > run, and type in regedit).
2) go to: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Winlogon.
3) add a new string value (Edit > New > String Value) called shell. and set the value to the path of the new shell e.g C:\Litestep\litestep.exe.
http://support.microsoft.com/kb/228309
Posted on May 09, 2009
Don't have a an icon
Please give more details as to what is happening and when it happens?
If you are saying your computer boots up but there are No Icons on the desktop, then a virus or infection has hidden them or changed some settings.
Click the Ctrl/Alt/Del keys to start the Task Manager. Press and Hold the Ctrl and Alt keys then hit the Del key. When the task manager opens up click the Processes tab. Under the processes tab click the columnar heading Image Name to sort the items running in alphabetical order. Look to see if you see explorer.exe running under the image name. If you do click it one time to highlight it then click the END PROCESS button at the bottom right of the Task Manager Window.
Next click FILE at the very top left corner of the Task Manager Window and select New Task (Run..). When the Create New Task window pops up type in: explorer.exe and press OK. Your desktop icons and start menu should start populating.
Apr 18, 2012 | Computers & Internet
Blank screen
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
Hp dv7-1130us booted but no software/applications
Click Ctrl+Alt+Del to get to Task Manager. Hold the Ctrl key, plus Hold the Alt Key then hit the Del key while holding them. Once the task manager opens Clcik the Processes tab then click the Image Name Column heading on the left to get them in alphabetical order. Scroll down and look for explorer.exe. If you see it click it to highlight it then click End Process.
Next, click the FILE tab at the very top left of the window and select New Task (RUN). When the Create New Task window opens type explorer.exe and press ok. Your start menu, task bar and desktop icons will start appearing and populating. if not that means a virus has hidden your files and folders.
Mar 31, 2012 | Computers & Internet
Lost start button and icons
Are you saying there are no icons on yourdesktop and the start menu is missing? If so try this: Click Ctrl+Alt+Del to get the task manager to come up. Press andHold each key (Ctrl+Alt) until you hit the Del key, then you can release them.
When the task manager opens up click the Processes tab. You can click theImage Name column to get them in alphabetical order. Look forexplore.exe, if you see it listed click it once to highlight it then click theEnd Process button at the bottom right portion of the task manager window.
Next click File at the very top portion of the task manager window on the leftand select the option New Task (Run). When the Create New Task window openstype: explorer.exe and press OK. Your items will start populating andappearing on the desktop.
Mar 29, 2012 | Computers & Internet
My friends laptop starts up and only loads the wallpaper on the desktop homepage, no icons or start menu appear.
Don't worry when your friends laptop starts and if nothing is displayed then Press Ctrl Alt Del keys on your key board.Just see that you have pressed all the keys at same time or first press Ctrl then keep it pressed and with another finger press Alt and also keep it pressed and at last press Del key.
You will find task manager opened on the screen .There you will find File option ,click on it and select New task from the drop down.
Another dialog box will open type there explorer.exe and click OK.
Your problem will be fixed then.
Thanks,
Have a great day
Sep 17, 2010 | Computers & Internet
Windows did not appeared, only mousepointer was appeared. The icons on destop, taskbar and start menu are not appeared. What are the best solutions Tank you!
Press Ctrl + Alt + Delete together and Task manager will be opened. Click on file -> New task . In the box type explorer.exe.a nd click ok. If this doesn't works boot your computer from XP disk and run repair from disk.
May 27, 2010 | Microsoft Windows XP Professional SP2
On my pc not any icon or start menu can be shown only wallpaper can be here
To solve this issue..
1) Click CTRL+ ALT + DEL at a time..
2) You will find Task manager option..
3) From that select process tab..
4) Then select explorer.exe...  And select end process..
5) Then select application tab...
6) And click o new task..
7) In the bar type explorer.exe..
8) Then select ok..
Now the icons will be reloaded.
Jan 02, 2010 | Microsoft Windows XP Professional
PC Display after booting
Okay this is a flaw with XP. what you need to to is when that happens. Wait for the screen to load and press Ctrl+Alt+Delete and that will bring up task manager. Under the file button on the top right hand corner and select New Task (Run...). Then the run box opens up and type in the box EXPLORER.EXE that should show the task bar and shortcut icons. If you need any more help just ask me.
All The Best,
RCF
Aug 30, 2008 | Microsoft Windows XP Professional With...
Control-alt-delete
Thats Task manager and if you have Windows 2K , XP or Vista they will not shut the unit down w/these keyboard options.
Feb 29, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
