Question about McCulloch 10" Electric Pole / Chain Saw
Unit works but chain stops when pressure applyed, what oil goes resevior.
    Brigadier General:
  • 4,088 Answers
Does the motor continue to run when chain stops? Electric saws usually don't have a clutch, so I would look for badly-worn chain sprocket, or a possible sheared key in the sprocket hub, or a loose mounting nut. Remove the chain and bar, try to turn the sprocket by hand (wear good gloves). There may be some type of overload clutch built into the sprocket.
Posted on Jul 08, 2009
Stihl 391 chain saw chain not getting oil
remove your bar and chain. check now for oil. also at this point clean and inspect the oil hole on your bar. if you get oil from unit with bar and chain off then the problem is in your bar. if still no oil and assuming you have oil in reservoir then remove clutch and oiler cover remove the worm gear and inspect. if damaged replace if not with low pressure used compressed air through to resevior
Sep 30, 2014 | Stihl Garden
Engine oil light on at idel goes off when driving comes on at stops
Check oil level on dipstick. Check for loose connection on oil pressure sender unit. Have the oil pressure checked using a master gauge.
Mar 28, 2013 | 2004 Dodge Stratus
Oil light flickers when it warms up, when your stopped.
The flickering light usually indicates low oil pressure particularly at idle.Check oil quantity. How long since serviced and filter replaced. If these all good have your oil pressure tested with a master gauge. Some issues can be oil pickup slugged up or if high miler engine bearings.
Feb 25, 2013 | 2003 Kia Sorento
I have a b and d alligator lopper that has never been used, but no manual. How is the chain lubricated? Type of oil? How is oil applied? Thx.
Information on your product, inlcuding a link to the Manual may be found here:
http://servicenet.blackanddecker.com/Products/Detail/LP1000
A high quality bar and chain oil or SAE30 weight motor oil should be used for chain and bar lubrication.
The use of a vegetable based bar and chain oil is recommended when pruning trees. Never use waste
oil or very thick oil. These may damage your chain saw.
- Before first use and every ten minutes of use you must oil the product with the recommended chain oil. Open the oiling cover and insert the bottle into the oil filling hole apply pressure to the bottle once to dispense oil.
- This should be adequate for about 10 minutes of cutting depending upon cutting speed and type of wood.
- The hole feeds the oil through to the chain onto the chain bar and an excessive amount of oil applied to the unit could mean the oil drips from the unit around the jaw area. This is normal and is nothing to be concerned about.
May 23, 2011 | Black & Decker Black Decker Lp1000...
Trying to figure out where the oil goes after leaving the oil pump in a 88ford bronco II i'm not getting oil pressure
It goes through passages in the block that go to holes in your main bearings which pressurizes the holes in the crankshaft which then oil the rod bearings. Another passage takes oil to the cam and lifters and timing chain and is returned to the oil pan to repeat the process. Oil pressure cannot build if the rod and main bearings are worn out or spun, pick up screen on oil pump is blocked, oil pump is bad, oil passages are blocked. If the engine runs and is quiet with no knocking or taping then it may just be your sending unit or pressure gage is bad. Check it with a live oil pressure gage.
Feb 04, 2011 | 1988 Ford Bronco II
The chainsaw runs fine chain rotates all ok untill pressure is applied to cut through a small branch. the chain then comes to a stop and sometimes the engine will stall???
The engine should 4-stroke lightly when running at speed unloaded, but immediately 2-stroke when cutting. Adjust the H jet CCW somewhat to accomplish this. Make sure the chain is being oiled properly, the chain tension is correct, and the chain is sharpened properly. If this doesn't help, then remove the bar and chain, and wash out the clutch internals with spray carburetor cleaner to remove excess oil. Hope this helps!
Jan 11, 2011 | Echo Garden
Oil light comes on when car is stopped but goes off when I drive oil recently changed. no leaks
First, check the oil level. Make sure the oil is at the proper level. If it's OK, then there maybe an oil pump problem or the oil pressure sending unit problem.
A Mechanic with an oil pressure gauge will be able to determine if the oil pump is working correctly at idle or the oil pressure sensor is bad.
Dec 29, 2009 | 2005 Chrysler 300
Oil light on at stop
engine oil pressure may be low remove oil pressure sending unit and install a pressure gauge check for pressure while warm if pressure is ok replace oil pressure sending unit oil pressure at idle should be between 5-15 psi at min
Nov 17, 2009 | 2006 Dodge Stratus
McCulloch 10" Electric Pole / Chain Saw Logo
188 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
