Question about Mitsubishi HC3000U Multimedia Projector
Lights both red
Replaced bulb
I just replaced all the bulbs but the book says 3457 for the front amber in the guy that car Parts told me to put 4157 them
Amazon.com: Genssi 3057 3457 4157 White LED Bulb ...
www.amazon.com > ... > Bulbs > Tail Lights
Amazon.com, Inc.Genssi 3057 3457 4157 White LED Bulb Replacement Tail Light (Pack of 4) ... note we recommend Red LED bulbs behind red lenses, but white bulbs can also .... However, as cool as they look, I had to replace them with GE 3457NH/BP2 ... The LEDs were just not anywhere near bright enough for me at all. ... Book reviews
Sep 19, 2015 | Cars & Trucks
Replced bulb starts to power then fail red light blinks thre times
You might need a new housing! Sometimes, the housing can be damaged with a new bulb and it can caused the TV to want to shut off.
Mar 15, 2013 | Sony KDF-E60A20 60 in. LCD HDTV
Samsung sync master 226 cw pink screen problem
A pink or red color on the screen indicates the back light bulbs are failing. The bulbs are just small florescent bulbs like used in your home or office lights. When they start to go out they put our red or pink light instead of white light. You can order the bulbs and replace them in the unit if you want to repair it. You can get the bulbs from http://www.ccflwarehouse.com/lampfinder.html
But this repair is very time consuming because the lights are very fragile and you have to fully disassemble the LCD panel in the monitor to replace the bulbs.
Aug 16, 2012 | Samsung Computers & Internet
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
Replaced both bulbs with brand-new bulbs. Now all
Verify that the lamp doors are securely closed. The blinking red lights indicate a lamp problem. In this case, both appear to be defective. I doubt that the lamps are the problem. double chack all connections and doors for proper seating. Update this if the problem remains.
Thanks,
Dan
Apr 16, 2010 | Sharp XG-PH50X Multimedia Projector
I replaced the lamp when and the red LED light
More likely a faulty ballast. Check connections.
Jan 19, 2010 | HP VP6111 Multimedia Projector
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Mitsubishi HC3000U Multimedia Projector Logo
18 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
