Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
Hd only switches on briefly the shuts it's self down
I plug my 1tb wd elements hard drive in and the blue light comes on and the drive spins up, however this only lasts for about 2 seconds then its switches off and is not recognised by my pc
  • 432 Answers
If it has another connector type ie firewire or usb ( the opposite of what you are using ) then try that.
If its usb then you can go into device manager and un install the usb hub under usb devices etc and re install your motherboard drivers and re connect the hard drive also if you have a laptop or a friends computer you can connect it to temporarily to install it on just to see if it works on there computer - if it does then that means the hard drive is fine if not then it points at the hard drive.
Posted on May 09, 2009
WD hard drive not opening
Something might have happened to the driver. You might need to reinstall it.
May 12, 2010 | Western Digital Elements powered by WD 320...
WD Elements 1tb External HDD media files skipping
Try running Scan Disk and defrag. Otherwise use a program like SpinRite to do a low level scan of the disk.
Good luck
Feb 15, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
Brand new - plug in, switch on, and instantly get
You have a bad drive, return and get a new one. Dont try plugging it in to your computer anymore as you may damage your computer.
Feb 08, 2010 | Western Digital My Book Essential 1TB...
External Harddrive locks up Windows Vista Home Basic on start up
I would suggest two things.
First, plug in the 1TB drive when it won't cause problems, and go to Disk Management under Administrative Tools (for example right-click the My Computer icon and select Manage, then drill down to Disk Management). Check your 1TB disk's drive letter there, and perhaps change it to some letter further down the alphabet, like "T" for example.
Then run a full check on the drive - right-click the 1TB drive and select Properties, go to Tools tab and run "check for errors", selecting the option to repair system errors.
After that's finished, plug in the 500GB drive and run a full check on it as well, just to make sure.
Now try booting up with both disks plugged in - the problem should be gone.
If it's not, then it may mean, that your BIOS is trying to open this 1TB drive to make an option to boot from it possible, and it has troubles because of it's size; some older BIOSes can't cope with disks of that size. Should this be the case, you can go into BIOS Setup and disable booting from other devices that the primary internal hard disk.
A
Jan 02, 2010 | Western Digital My Book Essential Edition...
Hard drive will not turn on, light blinks
sounds like the powerboard bit is knackered on the case try taking the drive out the case and buying a hd caddy sata 2 usb
Jan 01, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
I purchased 2 WD elements 1TB. I have pluged it
right click on the drive , format it and it should work, if this not solves your problem go to the shop and use your warranty, it may be broken.
Nov 16, 2009 | Western Digital Elements powered by WD 320...
No power to my WD elements 1 tb
Same thing here. What about the data. Could you recover it ?
Jun 09, 2009 | Western Digital Elements powered by WD 320...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
WD Elements 1TB stopped
I would remove the data with another computer using a usb adapter and then re format the drive but check your motherboard will support more than 528Gb chunks. If it won't, partition the drive accordingly.
Jun 11, 2017 | Computers & Internet
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
283 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
