Question about Toshiba D-KR10 Multi-Drive DVD Recorder
Kr10 manual - Toshiba D-KR10 Multi-Drive DVD Recorder
Removing regional code toshiba d-kr10
will it copy from another sorce? if the programing from your cable box is copy protected it will not let you record.
Feb 06, 2013 | Toshiba D-kr10 Dvd Recorder With 1080p...
Shutter broken
You have a cheap Chinese copy of a Ricoh KR10-Super.
Assuming the shutter is actually broken (you didn't give details of symptoms) you cannot get spares for either of them. Throw it away (keep the lens) and buy any other Pentax K-Mount 35mm SLR camera, they're virtually worthless these days (except for the all-manual Pentax K-1000 and a few high-end models).
The near-worthless resale values means that you can pick them up from your local FreeCycle (also Freegle in the UK only) groups for nothing.
Pentax, Cosina, Ricoh, Chinon are the main brand names for K-Mount SLR's, but if you have a choice go for Pentax first, Ricoh second and only take the others if they're free as they're worth even less than a set of new batteries.
Feb 11, 2010 | Kalimar K-90 35mm 35mm Point and Shoot...
I have toshiba dvd recorder,the problem is the recorded dvd cannot play with other player. Do I have to return this recorder as it just a week away since i buy it
Make sure you Finalize the disc when you are done recording, otherwise it won't be read on other players or computers. To do this you go to Setup> Disc and choose Finalize. It takes a few minutes per disc, don't turn off the player while it it finalizing. In the same Setup menu you can choose an option to autofinalize the disc when you are done recording, so you do not have to to it manually each time.
Dec 07, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Ricoh KR10 Super
Try a camera shop that still repairs obsolete camera's, if you have all the parts it can be fixed or replaced ( top cover ) with a good used one . If your KR10 has a flash socket on the front of the camera buy a flash bar and use that. Be sure the loose wire from the hot shoe is not touching anything.
Oct 08, 2008 | Photography
Timer Recording
This is from the KR10 manual. Hope it helps.
1. Set the clock before setting a timer.
2. Insert a recordable disc with enough space.
Then:
1. Press [TIMER PROG] on the remote
2. Use up/down arrows to select "New Program" then press [ENTER]
3.Use up/down arrows to enter the date, then press right arrow
4. Use the arrow keys to enter the start and end time, then press right arrow key.
5. Use the up/down arrows to select the external input position to which your cable/satellite box is connected, then press [right arrow]
6. Use the up/down arrows to select a recording mode.
7. Press [ENTER] when all items are entered.
8. Press red [I/O ON STANDBY] to set a timer programming.
DO NOT FORGET THIS LAST STEP! The timers will not work if the recorder is not in standby mode.
Jul 24, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Will not show picture on disc
Check the RCA wire or fiber optic conection. If you use RCA wire be sure you put Video output from your DVD to input Video of your tv set.
Apr 16, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Toshiba D-KR10 Multi-Drive DVD Recorder Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
