Question about Iomega Computers & Internet
Power adapter for iomega mmhd - Iomega Computers & Internet
My Iomega LDHD250U 250 GB USB External Hard Drive's Power and Usb ports WILLNOT CONNECT!!!!!!! Please help ive been trying to figure out why all day.
Dear Friend, Your I-Omega case might be bad or the controller inside that connects everything. I suggest you to get: http://www.walmart.com/ip/Apricorn-Universal-Hard-Drive-Adapter/10811435. and pulled your hard drive enclosure apart, then removed your hard drive and connect with the external adapter. Usually comes with a SATA or IDE connector for data and power adapter. After connecting everything plug into your PC and it should be able to recognize.
Good Luck#
Jan 13, 2014 | Iomega (33215) 250 GB Hard Drive
My 500gb iomega external hd model : MDHD-UP . is not working i think its the power supply that has a problem because my friend use the wrong adapter instead of the right one 12v he use my laptop's
Hi sir/madam
Use only 12v adapter for your drive...purchase same volt adapter...
Still not working remove the casing of iomega , connect it as internal drive on desktop ..
If it is under warranty pls go for service centre
Sep 21, 2017 | Computers & Internet
I need a replacement adapter for my iomega 1TB desk top hard drive. The original has been mislaid therefore I have no reference to match. The sticker on the unit says "use only with iomega...
The power adapter should be AC 120/230V and are you sure its LDHD and not LPHD? either way I would recommend going on ebay and typing "iomega ac adapter" in the search bar and take it from there, see if you can find one or e-mail a few sellers and see if they have one for your model, hope this helps!
-Ryan
Mar 07, 2011 | Iomega (32692) Power Supply
My iomega does not turn on at all. Have played with all the plugs and tried using a different computer. This is the second iomega drive I've had with this problem.
1. you have a bad power adapter or the electronic controller board in the hard drive case has malfunctioned.
2. You should call the manufacturer for a replacement power adapter or go to the local computer store and purchase a new case for the hard drive.
Jun 30, 2010 | Iomega HDD External Desktop (32660) 80 GB...
Iomega Prestige 1TB External Hard Drive (34275) adapter
Hi LeoChen,
Most of the Iomega drive adapters do but not all. There's no information on Iomega's site regarding the voltage but if you look carefully at the fine print on the adapter, it should have a Input Voltage Range listing, normally 100-240, if this is the case then as long as you have a cord that fits from the wall to the adapter the adapter will adjust itself to voltage within this range. If you have one of the few that staes only 90-120V for range then the answer is no, but Targus sells a universal adapter for laptops that comes with an appropriate tip for your drive that does support 90-240V.
Hope this helps FixYa,
Chris
Aug 08, 2009 | Iomega Computers & Internet
I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted...
i have the same probleme . I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted to know which is the correct product to buy please
Sep 08, 2008 | Iomega (33090) 250 GB Hard Drive
No Power to External Hard Drive
Do you have access to a multimeter or voltmeter? If you do you can check the voltage coming out of the adapter and make sure it matches what the power adapter says it is. If it doesn't, then it is the power adapter. If it does, then it is the drive or enclosure.
Jun 21, 2007 | Iomega (33090) 250 GB Hard Drive
Computers & Internet Logo
87 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
