Question about Microsoft Windows XP Home Edition
Power surge on hub port message
I plugged my signeo mp3 to my usb port in front of my desktop and suddenly there was a message that notes Power surge on hub port. A USB device has exceeded the power limits of its hub port. I already done this last week in fact i already downloaded some music on my mp3 and no message like this..please what should i do to solve this problem..thanks
  • 413 Answers
Use a powered hub, one that has it's own power supply.
Posted on May 09, 2009
2 Suggested Answers
  • 106 Answers
SOURCE: power surge on hub port message
unplug your mp3 player immediately!! it will fry your mp3 player if you leave it plugged in!! try adjusting the player's settings and seeing if there is somewhere to switch it from '1000mah' to '500mah' or lower. try that. if it still gives the error try a different usb port.
Posted on May 26, 2009
We bought my son an RCA mp3 player yesterday (TH1814-A). We inserted the battery and are trying to plug it into my desktop using the usb connector so that we can upload some music. however, when i plug...
There are different types of USB port. For instance my computer has two types. One with a blue connector and one with a black connector. It might be that your USB ports are not suitable for that device. You need to check the specifications of the USB ports on your computer and the specifications of the MP3 player. Continuing to use the device might cause damage to the computer.
Mar 19, 2017 | RCA Audio Players & Recorders
Anytime I plug something in to the USB port it give a error message that states, Power Surge on the USB port. What can I do to fix this?
The USB device could be drawing more current than the USB port can supply or the USB port may be faulty.
Get a powered USB hub and plug it into your computer's USB port and then plug the USB devices into the powered USB hub.
Aug 16, 2009 | Dell Dimension 3000 PC Desktop
Power Surge on USB Port
I'm assuming you're not using a hub but plugging directly into one of the USB ports on your laptop?
First, have you installed all current patches for your PC? I think this was a common error message that was hotfixed some time ago, so be sure your OS is up-to-date. If so, you could try to uninstall all USB ports in device manager, then restart. When your system is up, go to the first USB device and right-click, then turn off warning messages. This is just for the error message, you may have a problem with your Zen as well so try it on a different PC if possible but I'd do that when it's fully charged. You may need to do a hard reset (instructions in your manual) to get it to work but that may delete all of the Zen's contents, so that's a last resort.
Aug 05, 2009 | Creative Labs Zen MicroPhoto MP3 Player
May 26, 2009 | Microsoft Windows XP Home Edition
Power surge message
Problem :Overvoltage on USB hub port
Solution: Look carefully at that same port and you will four gold pins make sure they are NOT touching each other..
Apr 16, 2009 | Computers & Internet
Try this to find out which one of your components has an issue. Turn off your machine then unplug all of your USB cables. Turn your machine back on and plug in one of your USB cables. Verify the component you just plugged in works correctly and if it does plug in another cable and verify that component is working. Continue these steps until you have the one component that displays the error you have seen. That component is most likely the cause of your issue and should be replaced.
Good luck, Greased.
Jan 28, 2009 | Dell Dimension 4700C PC Desktop
Ipod
maybe bad ipod try another computer
Aug 04, 2008 | Apple iPod MA446LL/A MP3 Player
Power Surge error message
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
Power sugre with m240
Hi there. This message would indicate any one of the following: 1. You have a lot of USB devices plugged in to your computer, and the maximum power supply for the USB ports has been exceeded by plugging this player to your computer. It would be best if you unplugged 1 or 2 of the USB devices connected for the time being. 2. You are plugging the player on your front USB port, and may need to plug it in the rear USB port to acquire ample power supply (front USB ports do not get as much power as the rear USB port -- sad but true) 3. You are using a laptop and may need to try another USB port on that computer. Purchasing a self-powered USB hub would be ideal as it gets its power supply directly from the wall electrical socket.
May 11, 2007 | SanDisk Sansa m240 MP3 Player
Microsoft Windows XP Home Edition Logo
192 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
