Question about Samsung SW62ASP Top Load Washer
It is displaying dE what does this mean I cannot get it to operate as usual The model no is SWS 1 ASP Samsung washing machine
SOURCE: samsung washing machine reset code
solved this problem in 1 min lol just push the door in a little wen u press start so it can form an airlock
Posted on Aug 26, 2008
SOURCE: Samsung Washing machine fault
possibly a blockage at the end of the thin pressure hose where it fits onto drum ie;scale or soap powder. Also clean the chamber/hose it fits onto
Posted on Jan 16, 2008
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
Posted on Apr 17, 2008
  • 489 Answers
SOURCE: de is displayed when i turn machine on
You may have a door latch problem and it will need to be replaced.
Posted on Apr 28, 2008
SOURCE: Samsung WD-J1255R washing machine takes double the displayed time
The problem is surely with the clock timer or the control board (cannot be repaired).I hope the product is under warranty, you can better have it replaced.Good luck.And please do post your comments.
Posted on Jan 16, 2009
What does DE in red mean on a samsung DV400 washing machine
There is a door problem.
The following link may provide helpful information.
One can also search the internet using the following:
"DE error code, Samsung DV400"
Jun 02, 2017 | Samsung Washing Machines
What does the error code dE MEAN
you have not said what your washing machine you have.so this is for the samsung.
If the Machine is displaying "dE" error, kindly check for the following : First and foremost the door must be properly closed. You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact). Also, you can check the end of the drain hose is submerged in water.7 Mar 2014
'dE' Error is displayed on the panel of the Washing Machine? - Samsung
www.samsung.com/in/support/skp/faq/135992..if yours is not a samsung then please let me know.
Nov 20, 2016 | Washing Machines
I KEEP GETTING A DE MESSAGE AFTER A FEW MINUTES
My washing machine is displaying an error code ... - Samsung
www.samsung.com/my/support/skp/faq/1033803
Samsung ElectronicsFeb 19, 2014 - ... your Samsung washing machine and the solution needed to resolve the .... If problem persists please call Customer Careline. *. dE. dE1. Ed.
Aug 06, 2015 | Washing Machines
Can you tell me what e6 on the display means as the machine wont work when this shows
Not sure of the make/model, but with Samsung washing machines that usually means 2 things. If you get it when entering the spin mode and the system stops and displays the code, the water heater is heating too quickly. Press the power button once to clear the code and finish the cycle before repair.
If you get the E6 during the spin cycle that can mean a problem with the main controller board.
You can keep resetting to get past that code but if you continue to get it during a spin cycle or part of the laundry where hot water isn't used, then usually that controller board is bad.
Good luck.
Apr 08, 2015 | Washing Machines
What does dE mean on the samsung sw5asp top loader washing machine
dE means the door its detected as closed
a quick look at THE USER MANUAL
tells you the error codes
http://downloadcenter.samsung.com/content/UM/201409/20140922144717463/WD8704RJ-02718A-07_EN_XEU.pdf
here is the link
if the door closes firm
then you get the DE error then the door interlock has failed
and will need to be replaced
Feb 07, 2015 | Samsung Washing Machines
Code de will not go away
You have not included the Make and model of your washer. Below is a google search for Washing machine error code de
This refers to a Samsung washing machine.
I suggest that you edit your question to include both the Make and model number. This question has been answered before on FIXYA for a samsung washing machine. Link included below. dE
dE1 Ed Door issue ·Check that the door is closed fully.
·Check nothing is trapping in the door.
·Check unit is not overloaded.
· If problem persists please call the customer support team.
Samsung washer machine error code dE
Aug 16, 2014 | Washing Machines
After putting washing in the machine and setting the controls the machine fills up with water but thats all.On the display it shows the letters- de-.I would appreciate your assistance in this matter.Thank...
hello de error means this is a door lock error most of the time you would have to replace the door lock assembly this is on both lg and samsung washers if your model is another kind please message me back the make and model number and I will look further into the situation with your appliance also please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 01, 2011 | Kitchen Ranges
I have a fully automatic whirlpool washing machine H-65 model. Rcently, it is sterted displaying the error code-"dE" after finishing bthe wash cycle. That is, the machine does washing and drains the dirty...
Hello Ajithkumar,
"H-65" is not resolving as a MEANINGFUL
MODEL NUMBER...
Most Frequent Causes for dE - DOOR OPEN ERROR // Main control detecting a problem with door/lid lock system...
>> In the MIDDLE of a cycle...
I would first have to ask if you are IGNORING
the very VITAL INSTRUCTIONS to use only
"HE" (high efficiency) washing detergents...
IGNORING this very IMPORTANT instruction is
PURE NEGLEGENCE and can damage the machine.
I would suggest if you don't want to buy a replacement
machine... you treat this one according to the OPERATING
MANUAL.
Carnac the Magnificent
Aug 26, 2017 | Washing Machines
What does ED mean on a washer machine
DOOR NOT CLOSED PROPERLY OR POSSIBLY DOOR SWITCH PROBLEM.
Oct 03, 2007 | Samsung WE356A5W Washer/Dryer Laundry...
Samsung SW62ASP Top Load Washer Logo
203 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
