Question about Dometic RM2852 Refrigerator
My dometic frig will not turn on either gas or electric has power
    Top Expert:
  • Dometic Master
  • 6,465 Answers
See if voltage to outlet if ok bad board
Posted on May 27, 2016
  • 51 Answers
SOURCE: Dometic Model # RM2652
Check with a DC meter on fuses to verify voltage is passing then check at the input on back side of the fridge to verify voltage is there. If yes to both it can be the eye brow or the lower control board hard to tell without further testing.
Posted on Sep 07, 2008
SOURCE: dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Posted on Nov 11, 2008
SOURCE: dometic rm2852 does not run on gas
So, the solution was simple but not obvious: the heat probe and the igniter are one and the same item, and all we had to do was bend the probe/igniter closer to the burner. After we did that the refrigerator started to behave properly.
Oddly enough, the repair manual for the refrigerator shows a igniter with a heat probe above it: the is not how the refrigerator is built.
Posted on Mar 24, 2009
  • 6 Answers
SOURCE: operates with gas, does not operate with AC.
Check the heater element for power.
Posted on Jul 01, 2009
SOURCE: my dometic rm2852r frig doesnt work on ac or gas,
this is well woryh a try take the fridge out turn it upside down leave for a few hours then turn it upright put back in LEAVE FOR AT LEAST 8 HOURS TO SETTLE then try it and see what happens hope this may help worked for me on a few occasions regards john
Posted on Jul 19, 2009
We have a dometic frig in our RV that runs on either electric or gas. Can I run it on gas while driving to the campground or do I just turn it off until we arrive?
The dometic is designed to run down the road in the gas mode, but NEVER fill you LP tank with you unit switched on, in either the gas or AC mode. Make sure you shut everything down before filling the tank!
http://67.238.126.140/pdf/3309661.001.pdf
Aug 13, 2011 | Dometic NDR 1062 Refrigerator
Our refrigerator Dometic RM2804 (1992), was left
get in a technician for the diagnosis
Sep 11, 2017 | Refrigerators
3 way small frig no power noted
Here's a link to the owners manual with all the instructions for operating the fridge on gas, 120V-AC, or 12V-DC.
The key with this popular fridge is to be sure the control switches are in the correct position for the power source you want to run it on, as it will not work on gas if the electric switch is on, and vice versa. Also note that you can only use one (1) power source at a time to run the fridge.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Print out a copy for your use and save an electronic one in case you lose your printout. Hope this helps you get the fridge up and running!
Jul 23, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic RM2193 Works on 120V, but not on gaz. I succeded in cleaning the burner jet and I get a flame. It ligth well now but the flame very small. The frig doesn't cool. Help ?
These fridges require that the control switches be in the correct position for the power source you want to use. If you try to operate the fridge on gas and have the electric 120V-AC switch on, all you'll get is the gas pilot light to stay lit. Also, when running on gas, the electric has to be off.
Here's a link to the manual for your unit. Print a copy and save an electronic one for future use, in case you lose your printout.
Hope having the manual helps you to get the fridge working on all the power sources you need! Best regards!
Jul 03, 2009 | Dometic RM2193 Compact Refrigerator With...
My 1995 Dometic 2611 runs OK all day but not at night
Yes more than likely the cooling unit is going bad. If your boiler tube is hot the cooling unit is no good. Your frig is 13 years old, it has reached its life span and beyond. A cooling unit or a new frig can be purchased from www.coachtech.info. Just send them an e-mail.
Feb 28, 2009 | Dometic RGE400 Top Freezer Refrigerator
Dometic RM2852 Refrigerator Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
