Question about Cameras
Lumix system error ios - Cameras
I wrote a text message to someone today and at the bottom of the message in a gray box popped the word Velkomin
Hi, you can try FoneDog iOS System recovery.
  • Fix with various iOS system issues like recovery mode, DFU mode, white screen looping on start, etc.
  • Fix your iOS device to normal from white Apple logo, black screen, blue screen, red screen.
  • Only fix your iOS to normal, no data loss at all.
  • Unfrozen your iPhone, iPad and iPod touch
Here are some articles for FoneDog:
Tips & Trick to Fix Your iOS System
iOS System Recovery Guide How to Fix with Various iOS System Issues
May 16, 2017 | Cell Phones
Panasonic LUMIX DMC-FH4 is showing system eror focus. How solve it ?
Can you tell exactly what is on the screen please. The system error focus is not supposed to be an real error that is displayed on your camera.
"System error" is possible. But if switching of and a few moments later switching on does not change the error on the dis[lay, you should contact a Panasonic certified repair centre.
May 24, 2014 | Panasonic Lumix DMC-FH4 Digital Camera -...
Iphone 5 error 4005
hi. your phone has board hardware problem cant be fix . best solution
apple store to exchange 250$ cuz its out of warranty . believe me its worth .
Feb 18, 2014 | Apple Cell Phones
3007 itunes update error
This is probably too late but I really hope this can help you or others.
You may have encountered different errors during restoring and updating your device. You may have seen "This device cannot be restored Error " message from iTunes before and wondering what just happened. A common error usually exists because of just simple things. And so there are things you need to consider first when you're updating or restoring your iDevice. Here are some of those:
1, Stable Internet Connection.
2, Firmware Issue.
3, Security software.
4, USB cable and port issue.
Part 2: Common Solutions to Fix iTunes Error
Solution 1: Reboot your phone.
Solution 2: Replace the USB cable.
Solution 3: Checking your phone storage.
Solution 4: Restarting your computer and resetting your phone.
Solution 5: Look for more stable internet connection.
Solution 6: Update your iTunes.
Solution 8: Deactivating your antivirus.
Part 3. Fix iTunes Error by Setting Your Phone in DFU Mode
Part 4: Use FoneDog Toolkit to Fix the iTunes Error
Step 1: Choose "iOS System Recovery" Option.
Step 2: Connect Your iDevice to Your Computer.
Step3: Download Firmware.
Step 4: Start Repairing Your iOS.
Step 5: Repair Complete!
More information you can see the Guide: How to Fix iTunes Error Occurred While Restoring or Updating iPhone, iPad
Hope it can help you!
Sep 28, 2013 | Apple iPhone 5
Use vb.net and access
Imports System
Imports System.IO
Imports System.Data
Public Class SaveImage
Shared Sub main()
Dim o As System.IO.FileStream
Dim r As StreamReader
Dim gifFile As String
Console.Write("Enter a Valid .Gif file path")
gifFile = Console.ReadLine
If Dir(gifFile) = "" Then
Console.Write("Invalid File Path")
Exit Sub
End If
o = New FileStream(gifFile, FileMode.Open, FileAccess.Read, FileShare.Read)
r = New StreamReader(o)
Try
Dim FileByteArray(o.Length - 1) As Byte
o.Read(FileByteArray, 0, o.Length)
Dim Con As New _ System.Data.OleDb.OleDbConnection("Provider=Microsoft.Jet.OLEDB.3.51;Persist Security Info=False;Data
Source=Test.mdb")
Dim Sql As String = "INSERT INTO images (Pic,FileSize) VALUES (?,?)"
Dim Cmd As New System.Data.OleDb.OleDbCommand(Sql, Con)
Cmd.Parameters.Add("@Pic", System.Data.OleDb.OleDbType.Binary, o.Length).Value = FileByteArray
Cmd.Parameters.Add("@FileSize", System.Data.OleDb.OleDbType.VarChar, 100).Value = o.Length
Con.Open()
Cmd.ExecuteNonQuery()
Con.Close()
Catch ex As Exception
Console.Write(ex.ToString)
End Try
End Sub
End Class
Jul 08, 2008 | Microsoft Computers & Internet
Cameras Logo
20 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
