Question about Exercise & Fitness
Draw the lewis dot structure for h2ccch2 - Exercise & Fitness
  • ernesto cuadra
    ernesto cuadra Nov 29, 2013
    Hi morgan , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
How do I rewrite this sentence for clarity?
The sentence is too long and contains multiple statements. Split it as follows:
Spell and grammar checkers will highlight potential errors, including poor sentence structure, syntax and spelling errors. These must then be amended, if considered valid
Mar 03, 2015 | Computers & Internet
Lewis dot structure for i
http://www.chem.uky.edu/courses/che230/FL/chapter%201.pdf
May 29, 2014 | Toys
What does a drafter do?
This is someone who designs and draws plans of structures. They take all the ideas and drawings from the architect and his team of engineers and makes a technical drawing of the structure. He creates this drawing on his drafting table. Nowadays he may also or instead use computer programs to create his/her drawing.
Jan 03, 2013 | Furniture
Lewis structure for h2s
Really I can not understand.
Apr 27, 2012 | Exercise & Fitness
What is the electron dot diagram for nitrogen
The electron-dot structure (also known as the "Lewis dot structure") for N is shown below:dubblea_6.jpg The red dots represent electrons that comprise the atom's 5 valence electrons. Recall that the valence (outermost) electrons are those that are involved in chemical reactions of bonding. The rule you should apply to drawing this electron dot structure is to first draw (or imagine) a rectangle around the atom's symbol, letting the rectangle represent the atom's core electrons (not shown), those within the atom's inner (s) shell. Then place one electron on each side. That leaves the remaining electron to be placed on one of the already occupied sides to give the electron pair.
It doesn't matter what side you place this 5th electron, because the final result is the pattern shown above, 3 single dots and one pair of dots, which neatly reveals the bonding power* of N (3) - and the existence of the one electron pair, which predicts special types of reactivity you will probably appreciate in more advanced topics of this element's behavior.
*The single electrons are more reactive than the electron pair, and will readily form bonds with other atoms, such as H. This allows you to predict that N and H atoms will combine to form NH3.
How do you know there are 5 valence electrons? For the answer, refer to the following partial image of the Periodic Table of the Elements I drew using Word and SnagIT software:
Notice the number-letter labels above each column ("group") of elements, for example "5A." The letter A indicates the groups of "representative" elements, the most common elements studied in general chemistry courses. The numbers before the "A" represents the number of valence electrons surrounding each element's atoms. For example, hydrogen has one valence electron, nitrogen has 5 valence electrons, and oxygen has 6 valence electrons.
Using the rules described above for drawing electron-dot structures, how many single dots and double dots should be drawn around H? Around O? Can you predict the bonding power of each of these atoms? What molecular compounds do you predict would be formed from the reaction of H and H? What molecular compound do you predict would form between combining H atoms and O?
Hints:
Reactions tend to occur that cause the single electrons (dots) to pair up. This occurs because paired electrons are much more stable than single electrons. A strong driving force for a reaction is the going from a less stable state to a more stable state. Hydrogen atoms from H2 molecules (diatomic molecules). H and O atoms combine to form dihydrogen oxide, also known as water!
Summary:
  • A very simple set of rules allows you to predict the electron dot structures of the representative elements.
  • The electron dot structures are very useful, because they can allow you to predict the bonding power of each representative element.
  • They are also useful in guiding your prediction of the compositions of molecules that can form during reactions between their atoms (that is, how many of each element in the molecule).
  • In more advanced topics you will also be able to use electron-dot structures to predict the shapes (or geometry) of molecules, including bond angles!
  • So, learning the skill of drawing electron-dot structures is very important to mastering chemistry!
Nov 04, 2010 | Scientific Explorer My First Chemistry Kit
Printer character very small , how to character normal
A character set is presented with which unscaled 2D molecular structural diagrams can be constructed. A minimal subset has been implemented in ROM on CBM microcomputers, whilst the complete set has been defined as a character font on an ICL PERQ computer. Structural diagrams have also been output on dot-matrix and daisy-wheel printers using appropriate software to print the special characters. The character set provides a simple means of displaying molecular structures on inexpensive microcomputers, on printers and on hardware offering user-definable character fonts.
Oct 25, 2010 | Posiflex PP7000 Printer
Excel formulas
Below is the formula for "2". The logic should be obvious from this so you can adapt for "1" or a combination of 1 and 2. This need to be written as one long formula so I have pasted it in to this reply so you can do a copy and paste into your spreadsheet. Sorry its not very readable in this form but you could paste into word so you can break it down and examine structure.
=IF(OR((AND(Sheet3!A12="WA",OR(Sheet3!AH2="Lewis",Sheet3!AH2="Pacific",Sheet3!AH2="Wahkiakum"))),(AND(Sheet3!A12="OR",OR(Sheet3!AH2="Clackmas",Sheet3!AH2="Multnomah",Sheet3!AH2="Washington")))),"X"," ")
Aug 18, 2009 | Microsoft Office Excel 2007 Full Version...
I want a software to drow the chemistry structures can u tell me from where i can get it.thank u
You can download these softwares from the link below:
http://www.sciencegeek.net/Chemistry/chemware/chemware.shtml
Jul 10, 2009 | Computers & Internet
Smartboard 580 draws scribbly lines
dip checking first is good. then reorient the board. press and hold the 2 large buttons on the pen tray until the 9-point orientation appears. use one of the smart pens to orient. don't just press the dots, start about 6 inches from the dot and draw an arc to the dot and hold it at the dot for a second, then release and do the same for the other 8. if there is still a problem, the usb voltage might be low coming from the hub/computer. try another usb cable or a shorter one. there shouldn't be more than 4 usb cables coming from one hub and the usb cables cannot be longer than 16 feet.
Mar 03, 2009 | Smart Technologies SMART Board 580 (SB580)
Pen tool not actually drawing
I also solved the problem by installing the driver from the website. The trick was to uninstall the old driver first.
Feb 06, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
