Question about Electrical Supplies
Glendale motorhome what size do i need and or can i use a non rv generator?
    Genius:
  • 1,198 Answers
You need one at least as powerful as the last one. More is better, as long as it fits. The new one should match the connectors from the rv.
Posted on Nov 29, 2013
3 Suggested Answers
protek480
  • 1714 Answers
SOURCE: I have a 1992 Itasca Toyota RV with a electric issue
Is there power at the gen? The transfer switch may not be transferring power over from gen. Check it at the gen first thing.
Posted on Aug 06, 2009
  • 10 Answers
SOURCE: generator in rv,not charging batteries
Hmm, maybe one of the circuits busted. I would call a specialized person for this.
Posted on Jun 03, 2012
I need simple pictures of the wiring diagram to rewire this motorhome including the engine in the generator so I can wire them together
Hi, will the shift lever move? If not you may a solinoid (shift antilock)that triggers when the brake pedal is engauged, If Thats your issue check your fuses. Also, you may have a def. switch on your break pedal. If the shiter moves and your rv dies, chk your trans. for low fluid. Hope that helps.
Aug 21, 2015 | Rv Motorhome Dual Co & Lp Gas Alarm...
My motorhome generator keeps sputtering and dying.
Check the fuel system e.g.the filter the hose and tap, also the on of elec. switch.
Sep 16, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
My onan emerald 1 genset is not transfering charge to the battery
Assuming your generator has the battery charger option?
Measure the battery voltage at the battery lead in the generator, without the unit running, or the motorhome ignition on. It should read approx 12V after the unit has been sitting a while. Then start the generator, it should rise to approx 13.8 with a good battery. If it does not then the stator windings and charge rectifier in the generator should be checked. If the voltage is 13.8 approx with the generator then you problem lies further upstream, and possibly with an isolation solenoid. If you generator does not have a battery charge winding/option then charging comes from the line voltage via a motorhomes inverter, check the inverter.
Sep 08, 2012 | Onan RV QG, 2500W GenSet, LP Gas
Generator in rv,not charging batteries
Jun 03, 2012 | Kohler CH25 PA-CH730-0040 Command Gasoline...
I want to add a new circut to my fuse panel
Maybe I am not understanding you correctly. Most motor homes and RV come standard with a shore power recepticle. Are you wanting to add two sources of power? If so, you will need to really rework your wiring on the inside of your RV.
I have a generator on my motorhome and the generator plugs into the source recepticle when I want to run on generator, or I unplug to connect shore power.
Jan 10, 2012 | Electrical Supplies
We have an rv with a onan emerld I set generator on board. When we bought the rv (used) the generator did not work at all. We purchased the motherboard for it and it now starts and runs fine but we are not...
Is your generator wired in to an automatic switchover in the motorhome, or do you have external plug in on face of generator, or near it. The power from the generator needs to be attached one way or another to the motorhome. It may be as simple as plugging the cord from motorhome into it, depending on what set-up you have.
May 16, 2010 | 1983 Chevrolet Chevy
I have a 1984 winnebago motrhome with a 6500nh rv onan generato runs getting power on the line but none in the motorhome
Hooked in to motorhome via automatic switchover, or does the power plug of motorhome have to be plugged in to receptacle at or near generator?
Mar 15, 2010 | Watts Onan Portable Generator - 5000 ,...
Aug 05, 2009 | Electrical Supplies
2008 Gaurdian Generac 3cyl diesel shuts off after hitting bump
If you dont find a solution here. Call Generac in Waukesha WI. and get the number for Robert Schwalm Co. He is the best in the Country for Generac I used to be #2 but I havent worked on all the new Generacs. Give me an old RV unit and no one is faster!
May 20, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Electrical Supplies Logo
59 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
