Question about Samsung BD-D7500 Player
My bluray player will not accept any dvd I try to load
Why does my bluray player flash
Most likely the loading mechanism is defective. Unless this is a high dollar player the most cost effective solution is to replace.
Jul 16, 2016 | Televison & Video
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
My samsung BluRay Player BD D5700 will play DVD's but will not play BluRay DVD's.
I had a similar issue. Try resetting your resolution. By default it should be at the highest level. I reset mine to 1080i and now the BluRays will play.
My TV is a few years old, I think it was bogging down because it was getting too much information from the player, but that's just a guess.
Jan 28, 2014 | Samsung BDD5700 BluRay Player
5 yr old Westinghouse TV w built in DVD player. DVD player won't play. Tried several different movies, none will play.
First thing I would check is that you are playing regular DVDS and not BluRay. Your TV may be old enough not to accept BluRay. If it doesn't work with a regular DVD then you most likely have a bad reader which can be replaced but you will have to take the tv apart to get to it.
Dec 12, 2013 | Westinghouse Electric SK-32H570D 32 in....
Loaded new blu ray disk today and the player will not recognize Display says "can not operte this disk" tried two new and the same response....no problemes before
try updating the firmware of the bluray. This is one downfall of blueray is that for newer bluray movies it requires new frimware to process the video :)
Dec 27, 2010 | Sony BDP-S350 Blu-Ray Player
Why does my samsung Blue Ray DVD player load to the menu but wont play the movie
Just need to verify if your trying to play a Bluray Disc or regular DVD?
If Bluray Disc:
All you need to do is to check on the FW version of you BD player. Go to Set-up > System > System Information. SW will be the FW version info. Please be informed that the latest FW version is v2.12. If it will not resolved the concern, try to verify if its happening to all of your Bluray Disc.
Sincerely yours,
Genius 101
Oct 22, 2010 | Samsung BD-P1500 Blu-Ray Player
Remote code for sony blueray model#bdp-s350
Hello All
Due to the Sony BDP-BluRay's needing a BLUE LIGHT SIGNAL to get past the Main Menu....There is no code or PUNCH THROUGH OPTION to read a INFRA-BLUE to an INFRARED signal from every other remote...Manopalized the market to Sony...No Play button will work after going to the maine menu of a BluRay DVD.
.....IF YOU CAN GET INTO SETUP ON THE PLAYER WITH ONLY A BDP-B101-105A REMOTE.....YOU CAN CHANGE THE REMOTE ACCEPTANCE.....WARNING MAKE SHIRE YOU CAN PULL UP A MENU and read about accepting other Remotes....
BEST TO BUY ONE FROM EBAY...25.00 to 35.00 OEM's are almost double......OK
Mar 03, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Samsung BD-D7500 Player Logo
24 people viewed this question
Jerry Greenberg
Jerry Greenberg
