Question about Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher
Lights keep blinking on my maytag mdb5130aww - Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher
I have an older Maytag DW model #MDB5130AWW I've
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101'
May 31, 2011 | Maytag MDB8551 Built-in Dishwasher
Maytag dishwasher model mdb5130aww won't do anything, we have checked the circut breaker and it fine. I believe it may be the door switch (unless it the entire electronic panel)
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 15, 2011 | Microwave Ovens
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
I have a MDB5130AWW model dishwasher and it has worked extremely well up until a week ago. Now there is water sitting at the bottom of the dishwasher, and the "Clean" and "Rinse Only" buttons are blinking....
You may have a seized/stuck motor. Turn the electricity off and remove the lower panels. Take a flat head screw driver and carefully attempt to move the motor impellers. If the impellers feel hard to turn continue to try and free the impellers. If they loosen, reactivate the power and start the appliance. Good luck!
Feb 24, 2010 | Maytag Dishwashers
Maytag Dishwasher model # MDB5130AWW
I had a similar issue with my MDB5130AWW. The Wash was interupted and wouldn't come back on. Not knowing where to start I read some other solutions on this site and started by opening the bottom cover. Thats where I found a 4 page diagnostic / Electrical Schematic. Start with the Sales Demo mode of pressing the Rinse button 5 times within 5 seconds. I had to do it twice before the washer came "alive". I was estatic after reading about the $100 mainboard cost and maybe more for other parts. The document has other test and what different keypads mean when flashing. Thankfully I didn't have to go that far.
May 22, 2008 | Dishwashers
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Control Panel going crazy
the motherboard likely needs to be replaced. this is a major issue with maytag side-by-sides and its likely that maytag makes that model for kenmore. Cross your fingers, call sears repair, and hopefully they can have it working again within the next month.
Sep 01, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher Logo
29 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
