Question about Bulova Watch
Unfamiliar with using 30 minute totalizer sub-dial on Nicolet Chronograph and trouble setting Moonphase complication
How does the "30 minute totalizer" work on this watch and how do I reset it to 0 if applicable. Als any advice on setting the moonphase complication on this?
5 Suggested Answers
  • 26 Answers
SOURCE: don't know how to set my Patek Replica calendar
Most Likely they are non functioning. If there is little buttons on the sides of the case try and push them in with a pin. But most likely you are stuck with them the way that they are
Posted on Jan 03, 2009
  • 10 Answers
SOURCE: Where can I find english instructions to my ladies
go to web page of make of watch put in seriel no on back of watch they should give u a english version
Posted on Jan 06, 2010
genebur2
  • 63 Answers
SOURCE: how does moonphase work>
The moon phase is based on the Lunar calendar.
Lunar calendars differ as to which day is the first day of the month. For some lunar calendars, such as the Chinese calendar, the first day of a month is the day when an astronomical new moon appears in a particular time zone. For others, such as some Hindu calendars, each month begins at full moon. Others were based in the past on the first sighting of a lunar crescent such as the Hebrew calendar.
Posted on Aug 14, 2010
SOURCE: Bulova Marine Star with chronograph. The minute
I have the exact same issue with the minute hand resting at the 1 minute mark and now I have condensation under the glass. The watch is only 2 months old so I think I will return it.
Posted on Dec 10, 2010
2 hours back?
Severe shocks,drops or strong magnetic fields have as result the wrong indication of watch hands.Try to reset your watch by the hands "0 set" procedure following manual instructions.
Mar 18, 2013 | Casio Watch Edifice Eqs-500c-1a1er Man...
Tip
Watch glossary: C (part2)
C0Ck, see bridge.
COLIMAçONNAGE, see snailing.
COLUMN-WHEEL
Part of chronograph movements, governing the functions of various levers and parts of the chronograph operation, in the shape of a small-toothed steel cylinder. It is controlled by pushers through levers that hold and release it. It is a very precise and usually preferred type of chronograph operation.
COMPLICATION
Additional function with respect to the manual-winding basic movement for the display of hours, minutes and seconds. Today, certain features, such as automatic winding or date, are taken for granted, although they should be defined as complications. The main complications are moonphase, power reserve, GMT, and full calendar. Further functions are performed by the so-called great complications, such as split-second chronograph, perpetual calendar, tourbilon device, and minute repeater.
CORRECTOR
Pusher positioned on the case side that is normally actuated by a special tool for the quick setting of different indications, such as date, GMT, full or perpetual calendar.
COSC
Abbreviation of "Contrôle Officiel Suisse des Chronomètres" the most important Swiss institution responsible for the functioning and precision tests of movements of chronometers. Tests are performed on each individual watch at different temperatures and in different positions before a functioning bulletin and a chronometer certificate are issued, for which a maximum gap of -4..+4 seconds per day is tolerated.
CôTES CIRCULAIRES
Decoration of rotors and bridges of movements, whose pattern consists of a series of concentric ribs.
CôTES DE GENèVE
Decoration applied mainly to high-quality movements, appearing as a series of parallel ribs, realized by repeated cuts of a cutter leaving thin stripes.
COUNTDOWN TIMER
A function that lets the wearer keep track of how much of a pre-set period of time has elapsed. Some countdown timers sound a warning signal a few seconds before the time runs out. These are useful in events such all kinds of race.
COUNTER
Additional hand on a chronograph, indicating the time elapsed since the beginning of the measuring. On modern watches the second counter is placed at the center, while minute and hour counters have off-center hands in special zones, also called subdials.
CROWN
Usually positioned on the case middle and allows winding, hand setting and often date or GMT hand setting. As it is linked to the movement through the winding stem passing through a hole in the case. For waterproofing purposes, simple gaskets are used in water-resistant watches, while diving watches adopt screwing systems (screw-down crowns).
CROWN WHEEL
Wheel meshing with the winding pinion and with the ratchet wheel on the barrel-arbor.
CRYSTAL
The clean cover over the watch face. Three types of crystals are commonly found in watches: acrylic crystal, mineral crystal and sapphire crystal .
on Jan 11, 2010 | Watches
How can we set the chronograph dial
From time to time, chrono sub dial hands will be off. Solution is rather simple, pull out your crown and push either top and bottom button, each button will set certain hands on sub dials. This applies to both positions of crown (depending on complication & number of sub dials).
Apr 11, 2012 | Watches
How do I reset the watch after I change the battery?
1st you have to set the second hand, and the milli second- pull the crown on its third position and push the upper button until the big second hand reaches 12 o'clock then the lower button is for the millisecond push it until it reached 0. nd push the crown to its second position and push the lower button to set the minute hand of the chronograph until it reaches 30 then 3rd push the crown in its normal position. that' it. i hope that i had helped you.
Jul 08, 2011 | Fossil Arkitekt watch
I just need online instructions to use the lap timer on my Women's Timex Ironman Triathlon watch. I'm not sure of the model, but I think it's a 50-lap, and it's small. The 4 buttons on the side...
Here is the link that can help you set up your watch. Also here is the All list of timex watch downloadable instruction.
I hope this can help you resolve your issue.
Thank you for choosing Fixya
Mar 06, 2011 | Ironman Timex T5B721 Sports 50 Lap...
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
Can't set the date on the Merona moon watch
https://www.watchnetwork.com/moonphase/index.html
Nov 08, 2010 | Watches
HOW TO CHANGE THE TIME ON MY DIGITAL WATCH IT HAS 4 BUTTONS ON THE TOP LEFT IS "LIGHT" ON THE LEFT "MODE" ON THE TOP RIGHT "START" AND ON THE RIGHT IS "RESET" THE...
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Oct 29, 2010 | Watches
Just been given an Audemars watch - don't know how to set it.
I was unable to find any instructions on their web site, so if you haven't got the instructions, then I suggest you try ringing them on one of the numbers below. (You might ask them for a set of instructions as well as how to solve your problem).
Toll Free: (800) 595-5330
Phone: (239) 262-4545
Jan 31, 2010 | Audemars Piguet Watch
Bulova Watch Logo
389 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
