Question about DCS RGU-485GD Professional Series 48" Gas Range With Griddle 5
DCS GRIDDLE NOT HOT ENOUGH
SET AT 450 DEGREES BUT NOT HOT ENUFFF. POPS LOUDON RE-IGNITION
How do you repair oven that won't fire?
Given that its gas, I would advise you get a competent person to check it out. Propane gas and sparks don't mix. There are things in the owners manual you may feel confident enough to check, if not, leave it to a trained person.
Aug 29, 2014 | DCS Professional RDU485GDL 48" Pro-Style...
DCS 36 in. CS-366 LP Cooktop ignition
in that burner something is short check it out
Dec 09, 2007 | DCS 36 in. CP-366 Gas Cooktop
Left burner not lighting
Could be the igniter isn't sparking, sometimes they get cracked and run to earth you will still hear it click. Remove the top plate and check the wiring and igniters, turn the lights off and you will see if it's sparking all over the place.
Apr 03, 2014 | DCS 36" Professional Gas Cooktop W/Griddle
Why does the ignnitor keep clicking even after the stove lights
can be faulty. You must replace.
Please read your instr manual go to the section troubleshooting, and see the information. However you can get support ONLINE via chat or phone.
God bless you
Sep 24, 2012 | DCS RGU-485GD Professional Series 48" Gas...
I have leaky valves on my cook top. Do they need
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Jun 04, 2010 | DCS CP-486GD 48 in. Gas Cooktop
How do I clean a Viking griddle that hasbeen
I use a product called Greasecutter Plus by ECOLAB, it makes the griddle look brand new, gets everything off. You just spray it on and let it set for a little bit then it wipes clean.
May 13, 2010 | Viking Cooktops
The igniters will not stop sparking on my dcs cooktop when I turn the burners on. This happens with all burners.
Because this is happening on all burners, i would say you have a faulty ground to the ignition module.
Dec 19, 2009 | DCS 36 in. CP-366 Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
DCS RGU-485GD Professional Series 48" Gas Range With Griddle 5 Logo
24 people viewed this question
Top DCS Cooktops Experts
Timllfixit
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a DCS Cooktop Expert? Answer questions, earn points and help others
