Question about KitchenAid KGSA906PSS Gas Kitchen Range
F6E4 Communication error
Worked yesterday had error message this AM
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: it lost communicatiomn error message -
Either way the error code is a mis-communication error... which means a faulty power board... click on the link below... Here's the tech. data sheet for your model that explains what to do for error code F6 E4: manuals/Tech_Sheet_9761387.pdf
You would need the rest of the model number to make sure you have the correct board... and here is the Power Board for your model...
F6 Systems E4 LOST COMMUNICATION
PROCEDURE: Before proceeding, perform steps 1 through 3 above chart on page 5 to enter the Diagnostic mode.
A. Unplug range or disconnect power.
B. Open the back panels and make sure the P2 connector is fully plugged in on the power board and on the display board.
- If it is not, plug it in to the connector and go to step F.
- If it is plugged in, go to step C.
C. Visually inspect all the four wires between P2 on the power board and P2 on the display board. Make sure the wires are not cut or pinched. If the wires appear to be intact, perform a continuity check between pin 4 of the power board and pin 4 of the display board. Do the same for pins 1, 2, & 5. Both of these checks should result in a reading of less than 5.
- If either of these checks fail, go to step E.
- If these checks pass, reconnect P2, then go to step D.
D. Replace the power board. Ensure all connectors are properly seated and then go to step F.
E. Replace the wiring harness (signal) and go to step F.
F. Ensure all wiring connections are made. Replace the back panels.
G. Plug in range or reconnect power. Observe for longer than 1 minute.
H. If error does not appear, initiate a bake cycle. Let the cycle run at least 1 minute.
* If no error occurs, cancel the cycle. The problem has been repaired.
* If the error occurs again, restart the troubleshooting procedure at step A (except in step D replace the display board if power board has already been replaced).
Hope helps.
Posted on Sep 04, 2011
Error message: communication error
I use a USB cable and never see a communication error
Jul 08, 2015 | Canon PowerShot SX520 HS Digital Camera...
Error connecting to server
Error messages can mean several things. You may have lost internet connection for a short period or your tablet may be having problems with downloading. This is a common problem that happens to devices if they aren't working properly with internet or you could have interferance. Try down loading later at night, late late and see if it just happens to work.
Feb 28, 2014 | Android 4.0 Tablet PC
Whirlpool dishwasher error code f6e4
F6 error fault code...
This is the Water tap closed. What that means is that the flow meter is not recording water entering the dishwasher, this can be a water tap turned off (suprisingly more common than you'd think, after new flooring or decorating has taken place),water hose kinked or blocked, the dishwasher water soleniod valve defective.
Dec 18, 2013 | Dishwashers
Error message that my IP90 Canon is offline.
Check that you haven't accidentally changed it setup to being off line, you will find this in the devices section of the control panel. If that doesn't work I suggest you re-install the printer software using the setup disk that should have come with the printer. Hope this helps.
Dec 30, 2012 | Canon PIXMA iP90 Mobile Printer
Communication Error
try either a card reader (rather than connecting your camera to the computer) or try erasing photos. it seems that it happend when the card is too full. i had the problem and had to go under 3000 photos and then it worked.
hope this helps.
Nov 30, 2009 | Canon Cameras
Kitchen Aid gas range error code "F6E4 lost communications"; oven not turning on
i had some milk boil over and got this error message on our oven. we had a tech come out and he said that we would have to replace a control board for $280. he went away to order the part and in the mean time i had to shut off power to some circuits and when i turned the power to the over back on it worked fine. i would try this before replacing the part
May 22, 2009 | KitchenAid Kitchen Ranges
Can not recieve email using Outlook
Check out your incoming / outgoing server details and test settings once from Outlook->Account settings. Also check for dns settings if you are using any vpn connection. Let me know if this works.
Mar 12, 2009 | Microsoft Office Outlook 2003 for PC
How do I view my picture message?
it might be a network problem cal ur network service provide and tel them to re send the settings and say the problem
Dec 16, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
HP Jornada 720 handheld communication with pc.
This error is a communication problem between your computer and the Jornada. Try these solutions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpia2302&cc=us&lc=en&dlc=en&product=61677
Has anything changed that caused the problem, eg, installing new hardware, using a different cable to sync the Jornada?
Feb 21, 2008 | HP Jornada 720 Pocket PC
KitchenAid KGSA906PSS Gas Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
