630 eurosit heater model 0630536 after I turn the knob to the pilot setting and successfully light the pilot I can't turn the knob to an "on" setting if you will to light the heater
SOURCE: Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Posted on Feb 24, 2009
koolbreezes
  • 540 Answers
SOURCE: williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Posted on Dec 22, 2009
  • 3 Answers
SOURCE: where to find a thermocople
eBay has them for $75
Posted on Nov 16, 2010
  • 59 Answers
SOURCE: pilot light will not stay
next to the pilot there is a connector with a long copper tube. it is normally that and most decent plumber shops stock them.
Posted on Mar 14, 2011
  • 2527 Answers
SOURCE: WHAT SIZE PROPANE TANK DOES THE GLO WARM 630 NEED?
The tank size dosn't matter all you need is a feed line This looks like a spicific tank appalaction but just feed it remotely with a normal propane tank and a feed line and save your self the head ache as long as it dose what you want it to do ist cool
Posted on Mar 06, 2012
630 eurosit heater
The thermocouple has to warm up before the unit will go on.
Nov 28, 2013 | Heating & Cooling
630 Eurosit 0630535 gas fireplace pilot wouldn't stay on what needs replaced...
I'm in the middle of this right now. Y'all don't know what you're talking about. The thermocouple you can buy at the local hardware store has a different thread (fine) from the Eurosit TC (coarse) and doesn't fit. Now I'm trying to source a Eurosit TC. Any suggestions?
Oct 20, 2011 | Heating & Cooling
Pilot light will not stay on,model 0630504 Eurosit 630
Mar 14, 2011 | Heating & Cooling
How di i light the pilot light
Be sure that the gas line to the heater is ON.
Looking at the Control Knob on top of the heater, you note that he knob has 3- positions: OFF, Pilot, ON.
Turn the control knob to the Pilot position and push down on it. If it does not go all the way in and your do not feel strong pressure pushing back at you, it is not directly in the pilot position. (Reposition the knob slightly and try again). Once You're sure the knob is directly in the pilot position and the knob is depressed, continue to hold it in and press the Ignitor button next to it. You will hear a loud click. If possible, watch the pilot assembly inside the heater when you do this. That way you can see if the pilot lit the first time. If not repeat, pushing the ignitor.
If the gas line had been turned off to the heater, the pilot may not light the first couple of tries, due to air being in the gas line. If that is the case, hold the control knob in until you smell gas, let off, wait 5 minutes and repeat the lighting sequence.
Once the pilot does light, continue to hold the control knob in for 1 minute. This will allow the Thermocouple to heat up completely. Ease off the control knob and the pilot should remain lit. If it does, turn the control knob to ON and the burner will light.
Now you're ready to set the temperature or comfort level. You do this by raising or lowering the flame height. The higher the flames, the more heat it puts out. The lower the flames, the less heat it puts out. The stripe on the knob represents the flame heights - Narrow stripe, lowest setting, widest strip, highest setting. Or your specific model may simply say Low, Medium, High.
If you do not have the Owners Manual for this heater go to http://www.desatech.com/
click on Wall Heaters and enter the Model Number of your heater. You can then download and print the Owners Manual.
Hope this helped to get you up and runnig.
Feb 20, 2011 | Vanguard International Blue Flame - Large...
Williams debonair wall heater + pilot light problems
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
