Status message no source found - Office Equipment & Supplies
I'm getting 2 error messages when I import the Canoscan D1250U2F from Photoshop: 1) ScanGear CS-U: Cannot communicate with scanner. Cable may be disconnected. Check status. Scanner driver will be...
I have many years experience repairing Canon scanners so here is my suggestion for you.
This is a common problem with all Canon scanners. If you do a lot of scanning or leave your computer on all the time and never shut it off. What is happening is the memory fills up with all of the images and it needs to be cleaned out. If you reboot (restart) your computer it will clean out the memory and your problem will go away. I always recommend that if your going to be scanning a lot then do it off a fresh reboot and you should be able to your hearts content.
I hope this helps you out.
Mar 04, 2011 | Canon CanoScan D1250U2F Flatbed Scanner
Failed to connect to the internet thr wi-fi
f Active Standby is activated on your Cell, your WLAN connection status is always visible from standby mode. The bottom line of the screen shows your WLAN status. If there are no wireless networks in the area, you'll see the message 'No WLAN network found'. If you're near a WLAN that you're not connected to, you'll see the message 'WLAN name found'.
To log on to this network, simply highlight the WLAN status line and press the centre selection key. You'll see three options:
  • Start Web browsing
  • Search for WLAN
  • Switch WLAN scan off
If the WLAN has detected then cell will open, unprotected network (and needs no passcode to access) then simply highlight Start Web browsing and press the centre selection key to go to your Bookmarks page and start browsing the web.
Hope this helps
Jan 17, 2011 | Cell Phones
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
The printer light was flashing and error message told me that ink cartridges were empty - they have been replaced but it still wont print
Hello there...
I've found someone on the internet having similar problem as yours...
and I quote:
If the LED keeps blinking then the most likely cause is a failed print
cartridge (not simply empty), in this case what does the status monitor report?
It should tell you if one of the cartridges is giving trouble. You can try
cleaning the cartridge contacts in this case with a cloth dampened with water,
do not touch the printhead nozzles however, that will do no good and may do harm.
Source:
http://www.pcreview.co.uk/forums/thread-2470442.php
Hope this helps.... :D
Apr 14, 2010 | HP DeskJet 3550 InkJet Printer
I get an eror message status Oxc00000e9 what does
There are 3 step to repair oxc00000e9 error
If you got oxc00000e9 error then there is a 94% chance that your computer has registry problems. To repair oxc00000e9 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair oxc00000e9 error.
Here are the url of Perfect Optimizer:http://www.nomoreerror.com/tidpp-oxc0000… Source(s): http://www.nomoreerror.com/tidpp-oxc0000…
Nov 24, 2009 | Acer Aspire 5050-3371 Notebook
New beamer optoma hd65,message: no source found
adjust the resolution to match. also, make sure the monitor port is activated.
Nov 04, 2009 | Optoma HD65 DLP Projector
No signals found when searching for channels at setup
you need to press the channel up button 3 times if yo get message as please connect av sources. then do the manual channel search for 2 times. it should solve the problem.
Oct 13, 2008 | Sanyo DP32746 32 in. LCD Television
Unfamiliar Error message:
This seems to be related to a network problem, specifically, authentication. Has anything been changed or upgraded recently? There are a number of references to the error on the internet. I have attached them below.
Firstly, one user has looked at the /var/log/messages log file and found the additional error "uam: uam not found (status=-1"
Can you check that log?
A fix suggested by one user is:
"Turns out I needed to update the nettalk version that was included with YDL 2.3 to version 1.5.3.1-1c. After that and a restart apple talk works perfectly, on both our os9 and X machines." Maybe there is a lead there.
Attached bits from other users below.
Apparently, this error is "-5002 afpBadUAM: AFP Bad UAM," something to do with the User Authentication Module.
I've looked in var/log/messages
>>and it says : uam: uam not found (status=-1)
http://www.yellowdoglinux.com/support/solutions/ydl_2.3/netatalk.shtml
Good Luck. If you need to talk further, pls post it here. Rgds,
May 08, 2008 | Apple MacBook Pro Laptop Computer with...
Message box
Ive found my v220 does this. What i normally do is take out the sim, give it a wipe and then its okay.
Apr 09, 2007 | Motorola Mobility V220
16 people viewed this question
jasbo
jasbo
