Question about Miele S514 Solaris Electro Plus Vacuum
Miele Delphi won't stay on - Miele S514 Solaris Electro Plus Vacuum
How can I fix my Miele cat and dog vacuum cleaner. The electric lead will not stay out it keeps wanting to rewind. What can I do?
I think this model is a canister. If it is you might have broken the retractor reel from its bracket. Unfortunately it has to be taken apart and the part checked. Unless you are familiar with taking these apart you will need to bring it to a Miele dealer to have it looked at.
Mar 03, 2015 | Miele Vacuums
S2000 delphi power brush
take it back to the place were you bought it from and get it serviced
Jun 12, 2014 | Miele Vacuums
Milie won,t stay upright
If your miele is laying all the way down like mine is and will not stand upright..look for a dark gray corrugated plastic part where the handle bends at the base. This is above the silver holed plastic filter holder. This may be stuck. I just pulled mine out and then I was able to stand it upright again. I wasn't able to put it back in but I think it is there just to cover up the inside workings of the vacuum. So I left it out.
May 23, 2014 | Miele S7210 Bagged Upright Vacuum
Miele S 571 worked intermittently recently then stopped for good.
have you checked the wire for any broken wire plug in and move the wire around to see if it stays running
Jan 02, 2014 | Miele S318 Bagged Canister Vacuum
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Jun 02, 2011 | Miele Vacuums
Miele Vacuum Cleaner - burning smell / motor won't stay on
check brush the belt may have popped off and is binding or brush is binding clean brush of any debris thread/hair wrapped binding brush and check and or replace belt
Mar 24, 2010 | Miele S318 Bagged Canister Vacuum
Miele Solaris won't turn on after falling down 1 stair.
there is no reset on this model. look @ your miele info & it shows you where it would be. I just had to look for mine when it would'nt start. mine ended up being cord winder kink affecting motor.
good luck
linda
Mar 15, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Miele S514 Solaris Electro Plus Vacuum Logo
29 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
