Question about Stanley NEW Bostitch 2 HP 6 Gallon Electric Air Compressor
Replacing bostitch 6 gallon regulator
Need to know how to replace the regulator. Factory sent replacement but I do not have parts manual on how to replace this part.
3 Suggested Answers
SOURCE: Bostitch 6 gal compressor regulator knob is broken
Call Bostitch At 800-556-6696 and they will send you a free redesign part #27. It was a bad design part and I just did it a minute ago.
Posted on Jul 12, 2010
mygirl31558
Regulator knob can be purchased from amazon, take a look: Amazon com Bostitch compressor regulator.
Wish you best of luck.
Regards
Chris
Posted on Jan 07, 2015
My bostitch 6 gal compressor keeps running , and running , even goes into a higherpitch motor noise. can i check something ? or clean something to fix it ?
is it building up any pressure on the gauge
if the pressure recorded is around 40 psi or less , replace the failed poppet/reed valves in the compressor head
if it goes to 100 psi then replace the automatic controller for the motor
Jun 15, 2016 | Stanley Bostitch CAP200P-OF 6 Gallon...
Why will my bostitch pancake compressor 240 psi tank 180 regulator that the guages will not show building pressure
Hi, There are different posibilities. I would need more information. Was it always like that? Does the guage on the main tank and the guage on the regulator both not show more than 20psi? When the auto shut-off is triggered do you feel there is more than 20 psi in the tank?
Sep 15, 2014 | Stanley NEW Bostitch 2 HP 6 Gallon...
I have a 2007 Bostitch sir compressor that will not buid pressure. I am able to repair my self, I just don't know what to replace or adjust. Any info will help. Its a model CAP6OP-OF. Thanks
Your compressor could have worn cylinder /ring, worn/ leaking/ or broken reed valves or just leaking at a joint (check for leaks first using soapy water). Oil-less compressors have a silicone /vinyl compression ring that wears out quite easily depending on conditions at the job site (dusty/ gritty etc). Remove cover and turn motor till the piston is at top of stroke. Look for scratches close to top of cylinder, if present, replace cylinder and compresson ring to restore full power. If cylinder is smooth, and ring looks ok from the bottom than loss of power could be reed valves. Remove head and examine reeds replacing as needed. Good luck
Dec 16, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
I've had this unit for about 1-2 years, and it was working fine until last week. Pressure in tank but none in the outlet valve to the hose. Called Bostitch last week and the said it was the...
Yes, if you can't remove the regulator due to it hitting the tank then just unscrew the entire pressure switch from the tank. It is right hand pipe thread just like the regulator. Some compressor's will allow you to start to turn (unscrew) the pressure switch just enough to move the regulator away from the tank so that you can replace it. If that doesn't work then you have to completely remove the switch.
Jul 27, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
Used my Bostich CAP2000P for total of less than 2 hours. (not continuous). Now it won't start, have 115 volts at switch, 115 volts at motor. replaced regulator switch. Does not smell of any electrical...
If the motor cover was removed to test power there and it is there. Check for electric continuity across the motor with the power leads disconnected. If the motor is electrical open, find the open or replace the motor.
Inside the motor is a thermal overload motor protection device, it may be defective
Aug 29, 2017 | Stanley FactoryReconditioned Bostitch...
When the unit is on and building pressure, the safety valve goes off before it reaches the factory set 150psi pressure. I then lose most of the air and it starts over until the safety valve releases again...
The pressure switch (on / off switch) must be adjusted or has failed. A qualified Bostitch Technician can determine if the switch can be adjusted or must be replaced. Each model is different and without the model number I cannot give you a more precise answer.
May 15, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
I do not know how/or where to insert the end of the hose to the Bostitch 1850BN compressor.
http://www.docstoc.com/docs/56973363/Factory-Reconditioned-Porter-Cable-C2002R-Oil-Free-UMC-Pancake-Compressor
Usually when buying new/reconditioned it doesn't have the female coupling installed.You need to buy it separate and a roll of Teflon tape.On your model its to the right of the psi adjustment knob.Take a look at the link,it connect to the 2 brass peices on the front right.Good luck.
Feb 22, 2011 | Stanley FactoryReconditioned Bostitch...
My Bostich 6lb 2 HP oil free compressor was running fine until it kicked while I was using it as it sometimes does and would not stop. It actualy made a high pitch noise and began to smoke for a second...
The regulator on this model is prone to stripping and a kick would do it. Call the toll free number 800.556.6696 with your receipt and you should be able to get a replacement regulator.
Oct 19, 2010 | Stanley FactoryReconditioned Bostitch...
Regards
Chris
Jul 10, 2010 | Stanley NEW Bostitch 2 HP 6 Gallon...
Stanley NEW Bostitch 2 HP 6 Gallon Electric Air Compressor Logo
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
