Question about Sunbeam 2370 MixMaster Series Stand Mixer
How to disassemble a sunbeam 2370 mixer
Sunbeam 2370 mixer won't turn off, still turns at slow speed when dial is rotated to off position
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
To disassemble a sunbeam mixmaster 2370, find four plastic snappers arranged at 1, 5, 7 and 11 o'clock around the front circle of vents. They can be seen with the help of a good flashlight. un-snap them and the top and bottom shells will separate. From there on, it is clips and screws. Good luck!
Posted on Dec 13, 2016
SOURCE: Sunbeam Stand Mixer
For whatever reason, Sunbeam must have decided to cut on costs and used a plastic gear to transfer power to the beater. I had my Sunbeam for two years and the plastic gear decided to break. End of mixer. You cannot find a replacement part anywhere. It is the last sunbeam I will buy.
Posted on Dec 24, 2007
SOURCE: sunbeam 2436 not working properly
did you mean model 2346? If you did, I am having same problem
Posted on Mar 24, 2008
SOURCE: Sunbeam hand mixer. One beater not working
That spring does not turn the beaters. It is part of the beater release assembly. Probably one of the gears is worn.
Posted on Jun 05, 2008
SOURCE: sunbeam mixer
When you open it, there is are contact points and a piece that has to touch to change the speed. It may just be slightly bent or out of place. Some food may have gotten in there.
  • 3 Answers
SOURCE: Sunbeam Mixmaster 12 speed may need lubrication
Part 1. Oiling the model 12:
Anyone can do this part.
On the top of the motor are four places where oil should be applied.
Starting from the speed finder dial and working forward-
There is a small hole on the top of the motor, just in front of the speed dial. Using a wooden skewer or a match, clean the hole out, and apply two drops of good quality sewing machine oil.
On top of the motor, and near and behind the juicer attaching cone is another hole, sort of key-hole shaped. Clean it out and put in one drop of oil only.
Three drops of oil go into the juicer cone. Let them run down the side of the hole.
Next to the juicer cone is another round hole. You may need to turn the handle as in removing the beaters to uncover it. Clean this hole too, and apply another three drops of oil.
Do not apply more oil than specified. It will get into the works where it shouldn't.
The following proceedures assume some mechanical ability. Read first to assess whether you are competent before starting.
After all these years, the gears in the front of the motor housing probably need fresh grease. This is a fibre based food grade grease that can be obtained from most bearing sellers. (I used a non-food grade grease, but I have to watch that the motor doesn't get too hot, and the grease run down the beaters, which can happen in extreme conditions.)
Prepare to get greasy during this proceedure. Latex gloves are an asset for doing this job.
Remove the cover plate in the centre of the front, and then the central screw from the front and pull away the front housing cover and handle. Don't loose the coil spring inside. It goes over the screw you just undid.
Unclip the return spring on the beater ejector, and remove ejector and spring together, slide the ejector down and off the beater spindles, then up and out of the guides..
There are four screws that retain the gear cover. The lower right hand one also retains a wire. Remove the screws, and gently bend the wire so the cover can be removed. There is a gasket underneath. Take care not to break it, it's brittle.
Once the cover is away, the gears and worm shaft are visible. Using a pop stick or old screw driver, remove the grease around the under side of each gear. A square headed set-screw retains each gear. When you find each screw, remove it completely. Turning the worm shaft will make the gears rotate.
Once both screws are out, pull the beater drive shafts downwards and out of the housing, and lift out the gears.
Using pop sticks, paper towels etc, but NOT solvents, clean out the gear space. Remove all the grease possible. A toothbrush is good for cleaning the worm thread. Use someone elses.
Wash the gears and shafts in petrol, kerosene or similar and dry thoroughly.
Reassembly is the above in reverse order, first filling the gear housing with fresh grease.
Grease each drive shaft lightly before refitting. Note the holes for the set screws in the shafts.
The nylon gear goes on the left, brass under the juicer cone.
Fit the nylon gear first, working the shaft upwards until the locating hole in the shaft can be seen through the screw hole in the gear. Fit and tighten the set screw.
Align the brass gear so both screws face forwards at the same time when engaged with the motor worm, to prevent the beaters clashing. You may have to put the brass gear in and out a few times to get the right teeth engaged with the worm shaft. Then slide the shaft in, once again observing the alignment of holes to ensure the set screw locks the gear securely.
Put everything else back in reverse order. Apply a smear of grease for the beater ejector where it slides, and don't forget to put the wire back under it's screw.
Part 2, speed control.
The jerky operation at low speed is probably due to dirty points in the governer. Addressing this involves disassembling the rear end of the motor.
DON'T pull the motor armature out of the housing without first removing the brushes during this proceedure. There's no need to remove the armature, but if you're curious....
Remove the chrome cap from the centre of the speed finder dial. Remove the lock nut from the thrust control screw under the cap. Remove the dial, catching the washer that goes under the nut.
There is a resistor, usually green, and a capacitor, a small aluminium cannister under the dial. Gently pry the retaining legs away from one end of each and remove them. Note which one goes where so you can put them back correctly. Marking with a felt pen is a good idea.
Now are visible two slotted screws. Remove these screws and pull the governer housing back and away from the motor. Note the pin with a plastic head, and remember to put it back when reassembling the same way around.
Locate and clean the points with a slip of soft wood and metal polish. Clean away the polish thoroughly. Do not use emery paper, it will make the points arc, and speed control will be worse than now.
Put everything back the way it came off.
To reset the governer, leave the locknut on the thrust controling screw loose. Set the speed control to position 1. Whilst pressing the dial home with one hand, screw the thrust screw in or outwards until the motor just starts to run, and lock the screw by tightening the nut. Test the control for full range, and tweak by slightly altering the thrust screw position as required. Getting the speeds just right first go is usually a fluke.
Replace the chrome cap and you're done.
Posted on Jul 18, 2009
How do I tighten the speed control dial on a vintage Sunbeam Mixmaster PowerPlus?
There is a cover plate over the screw that you need to tighten. This cover plate is held in place by two spring latches, 180 degrees apart. Use a small flat-tip screwdriver to depress first one latch, then the other. Don't use too much force - the latches are plastic and will break if treated roughly.
Jan 27, 2015 | Sunbeam Food Mixers
Sunbeam model mx8900w circuitboard not working wont start possibly need newone.
Hi Eschill,
The model you posted was 2370 and mx8900w ar enot the same. YOu may want to check the basic troubleshooting guide based on the model of your mixer. Just click this link MANUAL. Just message me if you have any question.
Aug 04, 2011 | Sunbeam 2370 MixMaster Series Stand Mixer
Mixmaster motor won't spin. Leads from circuit board to motor read 119 volts at the motor. voltage does not vary when speed knob is rotated but does turn off & on. 275 W sunbeam mixmaster, white...
so far I determined the thermal fuse had blown. I jumped around it but can get replacement. Now the motor runs full speed when turned on. I suspect the pot turned by the speed knob is bad. Having trouble locating a replacement circuit board.
Jan 19, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
My sunbeam mixmaster blades wont turn but the motor is on?
Hi, GLENNHOLD148 - With a motor that runs and the blades do not turn, it appears that your mixer's suffered a mechanical failure in the mixers transmission. I don't know if your mixer is under warranty, but I suspect like any small appliance the warranty's only good for a year, and you've probably had it much longer than that. That leaves with with three options; purchase a replacement (Sunbeam and the economy would appreciate that!), take it to a local authorized Sunbeam repair shop, and finally attempt to repair the transmission yourself (DITY repair). The later can be most gratifying, however, sadly, Sunbeam doesn't provide Parts List manuals like some other mixer brands, e.g.; Kitchenaid, so I can only suggest Option 1 or 2. I wish I could offer you more help. Hopefully this will help point you in the right direction. Howard - Burke, VA
If this solution has helped, please rate it, thanks! - hslincoln
Nov 30, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Motor head will not tilt back
Push down slightly on the head and then the button will go in further and the top will release. ((this answer after I just bought it home and was about to take it back to the store!!))
Oct 11, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Turntable does not turn. Motor runs. Beaters work.
I have the same one, and the turn table has never turned on it's own. from looking at the bottom of the stand, i think the mixers are supposed to turn the bowl, so i just give it a little turn, and the mixers kinda take care of the rest. BTW, i got 2 sets of beaters with mine and i dont know what the second set is for, do you? contact me at rawemo@hotmail.com
Feb 18, 2009 | Sunbeam Food Mixers
Sunbeam Mixmaster model 9 speed control problem
Try www.davesrepair.com/pdfmanuals
You can download the manual for your specific model there, and most of them that I saw included at least basic maintenance like oiling and greasing locations. Good luck!
Oct 26, 2008 | Sunbeam 2386 MixMaster Series Stand Mixer
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam 2370 MixMaster Series Stand Mixer Logo
168 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
