Question about Rancilio Silvia Espresso Machine
Waterflow/heat seems fine - but little/no extraction
Have dad my silvia for a few days now with know problems. However, recently and suddenly it has started having problems with extraction.
The shot dribbles out very slowly (if at all), and only after ~10 seconds or so. Even when running for up to a minute, I only end up with a very small amount.
The steam wand seems fine - seems to produce hot/flowing water and steam.
Tried doing a thermometer reset - no luck. Also tried the coffee+water buttons 4-cup flush.
Perhaps this is a portafilter issue? Or something to do with pressure?
Any help would be greatly appreciated
    President:
  • 1,618 Answers
Try running the gro;up without the portafilter in place, what does the water flowq look like: is it a nice strong flow or barely a dribble. If if is barely a dribble, backwash machine with purocaff and check shower screen, that may be clogged. If you have a nice flow then try adjusting the grind on the coffee grinder.
Posted on May 11, 2009
Hi. I have a Rancilio Silvia Espresso machine which has a light that cycles on much more frequently than normal when I am using the Steam option. I have injured the machine somehow, I'm afraid. I was using...
First of all, your machine is not safe to use so do not use it. A thermostat maybe have shorted out, a wire may have grounded, who knows. Pull the top off and determine where and what has burned out. It should be quite visible.
Feb 09, 2011 | Rancilio Silvia Espresso Machine
Rancilio silvia
If your machine is recent it is a v3 which comes with an adhustable over pressure valve. It is possible to test the pressure (without the expense of a gauge) be using the balnking disc and measuring flow with a measuring jug (or scales) and a watch. check the make of pump and google for it - the Rancilio site also has the data flow rates for the pumps used. If you get the correct flow rate - the machine is fine and it comes down to grind and tamp... the stuff of alt.coffee and countless forums. Also have your freind use his coffee in your machine and see if he gets different results to you.
Dec 28, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia stopped heating up.
Hi
Check to see if it will heat in the steam position. If it does, then you have a bad brew thermostat, and just need to replace that. Its the one with the red dot. If not, run some water through the wand and see if it is milky? If its milky you have a blown heating element. You can also do an ohms check in the element. There should a reading between the element terminals of 12 to 16 ohms. If you have no reading, your going to have to replace the boiler.
Oct 26, 2009 | Briel Coffee Machine Multi-Pro...
Rancilio Silvia leaks around group head. Gasket seems fine.
HI
You need to change the group head gasket. They only last about 1 year and then should be changed. Get 2 because they usually fail on Friday and you have a party on Saturday.
The gaskets get hard from the heat and don't form to the filter any more so they leak.
When you get the new gasket.
Empty everything out of the machine (water tank, drip tray, etc.) Turn the machine upside down on a towel. This way you can see what your are doing.
Remove the filter screen and diffuser from the brew head. The black O-ring is your gasket. Carefully pry it out. Clean the opening good before you install the new gasket. Insert the gasket with the beveled side down (on the inside edge of the O-ring is the bevel). Once you have the gasket in place, use the portafilter to finish seating the gasket.
Oct 23, 2009 | Rancilio Silvia Espresso Machine
Silvia pressure issue
The Silvia comes equipped with a "pressurestat" that may have gone out of adjustment. Do a google search on that and you will find numerous pictoral guides on how to do this. The owner's manual that came with the machine (they have electronic versions at espressotec.com, among other places) will also give you basic instructions. Good luck!
Aug 22, 2009 | Rancilio Silvia Espresso Machine
The water isn't heated
Hi
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also an other problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Jul 13, 2009 | Rancilio Silvia Espresso Machine
Noisy during heating cycle
element is litlle bit bad.you need change element .
Nov 02, 2008 | Rancilio Silvia Espresso Machine
No wireless signal
Most home router has an IP address of 192.168.1.1 or 192.168.2.1. If you dad's laptop can connect to the router just fine, then it's a problem with your linux laptop. Can you see other wireless networks on your laptop?
Jul 23, 2008 | Belkin (F5D7231-4) Wireless Router
CREME
Hi ensure that the group head has heated up before using I tend to screw the head in and place the porta filter on top of the machine to allow it to heat up (heat the machine up for at least and with regards to the tamping ensure that you tamp firmly and twist at the end to smooth the surface.You could try tampind the cofee in the portafilter before placing it in the group head then after you have placed the porta filter back in give it another quick tamp remembering to twist at the end to help smooth the surface.
Then pull a shot. I get great crema like this.Also ensure the cups are warm.
You can heat the brew head and cups by running hot water through them before using as well this method is called cheating the Silvia
have a look at this http://youtube.com/watch?v=5mapl0Fw-_M&feature=related
Hope this helps
May 04, 2008 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
286 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
