Question about Health & Beauty
Service manuals torrey LEQ service manual
Dryer shuts off after 5 seconds then beeps 3 times
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Apr 03, 2015 | Frigidaire FARE1011MW Affinity High...
Where can I purchase a PC cord for a lpc40l
I would check eBay, I always have good luck with finding cords for electronics there.
Aug 21, 2014 | Torrey L-PC-40L Legal for Trade Price...
How do i change the brushes in my kitchenaid mixer?
Solution for these KitchenAid Stand Mixer Models
  • KitchenAid Stand Mixer Service Manual - K45SS
  • KitchenAid Stand Mixer Service Manual - K5SS
  • KitchenAid Stand Mixer Service Manual - KP50P
  • KitchenAid Stand Mixer Service Manual - KSM50P
  • KitchenAid Stand Mixer Service Manual - KPM5
  • KitchenAid Stand Mixer Service Manual - KPM50
  • KitchenAid Stand Mixer Service Manual - KSM75
  • KitchenAid Stand Mixer Service Manual - KSM90
  • KitchenAid Stand Mixer Service Manual - KSM103
  • KitchenAid Stand Mixer Service Manual - KSM110
  • KitchenAid Stand Mixer Service Manual - KSM150
  • KitchenAid Stand Mixer Service Manual - KSM151
  • KitchenAid Stand Mixer Service Manual - KSM156
  • KitchenAid Stand Mixer Service Manual - KSMC50
Fix KitchenAid Stand Mixer Workshop Service Repair Manual Download
Jun 18, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
No start , replaced head gasket now won't start not firing
Hello Torrey,
Your two problems are not related. Not firing has nothing to do with replacing a head gasket, but to do with the ignition system. You must have unplugged or disconnected something in your ignition system in the process of changing your head gasket ?? Look for that.... Hope this helps.
Andre
Mar 27, 2014 | 2005 Nissan Altima
The motor on my dryer is working but the barrel is not spinning. The model is LEQ 9858 PW1
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 16, 2011 | Whirlpool Dryers
Fan stopped. Turned on and spun blade but nothing, on any of the three settings. Bad capacitor? how do I test switch or motor windings with voltmeter? Thank you, Torrey
you can check the switch or motor by using an ohmeter for continuity test. connect the probes on each switch starting from common to no 1, 2, and so on. if the motor is okay, the capacitor is defective.
Sep 08, 2009 | Vornado Air Circulator - Black
Location of thermal fuse on leq9858 l dryer whirlpool
if this is a top load?if so remove the back panel and you will see the dryer heater box to your right,the fuse is on the left side of box top,the high temp thermostat is on the bootm left and should be replaced also,before you do thatmif you have a meter remove the 2 wires from the heating element and check it on omns,no meter?remove the 2 screws pull the element off and look to see if the coil is broke anywhere,let me know how you do-mkie
Apr 20, 2009 | Whirlpool LEQ9858L Electric Dryer
Health & Beauty Logo
88 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
