Question about Arris Comcast Touchstone Telephony VOIP BROADBAND Modem TM402P
I have arris TM402P and my device is asking for my wifi password. I never needed it before and I have no idea what it is. I have tried the reset button but that does not work. What next?
I have Arris TM402P. How do I reset password. Reset button does not do it. What next?
oldnovii
  • 667 Answers
SOURCE: how is Arris Telephony Modem installed?
Hi taldrich6 - You have this listed under Arris CM450. Is that what you have?
Posted on Jul 22, 2008
  • 31 Answers
SOURCE: connecting my arris modem to x-box live
I have an Arris cable modem and use Xbox live. They work very well together. Most ISP's will only allow one active device at a time. When you switch between you cable modem and your Xbox you need to use a pen and press the reset button on the arris every single time you switch.
Posted on Apr 09, 2009
  • 40 Answers
SOURCE: Unable to connect Linksys wireless router to my arris cm450a
All routers will only work with ethernet. You would need to get an ethernet card installed in your computer. You can probably buy one for about 20.00 at Walmart. If you don't want to do this you can purchase a usb/ethernet adapter and still use the usb port on your computer. You can purchase one of these for around 5.00's on ebay. Just go to ebay and search for usb/ethernet adapter. Please rate if this has helped. Thanks.
Posted on Apr 10, 2009
SOURCE: Arris Modem won't work with Airport Express
Not sure how helpful this will be, as I'm running a different piece of gear, plus it requires both troubleshooting + ISP assistance.  I had a similar problem with my AirPort Extreme: AirPort Extreme saw the Arris, iBook saw the AirPort Extreme, but no internet connectivity.
  1. In my case, I needed to set the AirPort to DHCP in the AirPort Utility application.
  2. Power down the AirPort Extreme
  3. Power down the Arris. You achieve this by unplugging the Arris *and* removing the back-up battery.
  4. Wait a few moments.
  5. Insert the battery into the Arris.
  6. Plug in the Arris power supply.
  7. Wait for the Arris to go through the restart protocol; when all the lights on the front panel are solid green, the start-up is complete.
  8. Power up the AirPort Extreme; wait for the front panel light to go solid green.
As I was doing this, I had my ISP on the phone that confirmed complete connectivity of the signal path and ensured that I was online.  While the Arris was powered down, my ISP also sent a "message" to the Arris; I don't know if this was a software update or what.  I completed the AirPort set-uo through the Utility application, the AirPort restarted, and I was online.
Hope this helps.
Posted on Apr 13, 2009
Why does it keep disconnecting?
If you know the password to get into the modem by typing 10.0.0.1 into the browser, you can look at the signal levels for the modem to see if they are low. If you cant do that then you can check all the connections to be sure they are tight and that there are no bad spots in the cable.
Nov 19, 2015 | Arris Comcast Touchstone Telephony VOIP...
How do I get wifi to work after the service guy has left
If he has activated WiFi, your WiFi capable devices should be seeing an Arris-XXXX wireless network. Just select that network and use the password the service guy has left you.
Dec 19, 2014 | Gateway Arris Touchstone Telephony Cable...
Find network key on sb6141
The term "Network Key or Passphrase" indicates your printer is asking for a WiFi password, but the SB6141 is not a WiFi capable device at all, it's just a Cable-to-Ethernet device. So then, you need to look at your WiFi router, which should be connected with an Ethernet cable to your SB6141. If this doesn't match your setup, you'll either need to get a WiFi router hooked up (that process will contain the answer to your question) or simply use an Ethernet cable for your printer.
Nov 09, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Cant find my password to Bevmills1963
Try getting into the modem settings usually starts with www.http://192.ect........
May 06, 2014 | Arris Comcast Touchstone Telephony VOIP...
Arris WiFi Modem to lenovo thinkpad t61
As it works ok on your other devices then it may be the software on the T61. Try going to devices - wifi and update the driver.
Jan 28, 2014 | Arris Computers & Internet
My wifi has no password set up
open ur modem using its ip address
then go to wireless tab then security then go to network authontication and change to wpa-personal or wpa-psk ten it shows passpharses tab type new password save and exit
Jan 22, 2013 | Arris Comcast Touchstone Telephony VOIP...
Password for my wireless connection
U NEED TO RESET IT GO TO http://www.fixya.com/support/r11153882-general_routers_reseting
Apr 11, 2012 | Arris Comcast Touchstone Telephony VOIP...
Arris Comcast Touchstone Telephony VOIP BROADBAND Modem TM402P Logo
32 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
