Question about Konica Minolta magicolor 4650DN Laser Printer
Te sensor k is shown on the display - Konica Minolta magicolor 4650DN Laser Printer
Hi! i am trying to detect a problem in my sony model HCD-GZR777DA when switch it on, after waiting it display c 31 00. where to start please help
31: DPD offset adjustment error .
Contact any service technician. You can't repair this. The error code list to this set:
The meaning of error code is as below:
01: Communication error (No reply from syscon)
02: Syscon hung up
03: Power OFF request when syscon hung up
19: Thermal shutdown
24: MoveSledHome error
25: Mechanical move error (5 Changer)
26: Mechanical move stack error
30: DC motor adjustment error
32: TE balance adjustment error
33: TE sensor adjustment error
34: TE loop gain adjustment error
35: FE loop gain adjustment error
36: Bad jitter after adjustment
40: Focus NG
42: Focus layer jump NG
51: Spindle stop error
52: Open kick spindle error
60: Focus on error
61: Seek fail error
62: Read Q data/ID error
70: Lead in data read fail
71: TOC read time out (CD)
80: Can't buffering
81: Unknown media type
Are you confident to do anything with these error displays.
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Sony Audio Players & Recorders
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Rf265abwp display shows 4 8's in display last on
The broken wires at the ice maker can cause that problem. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. After fixing this problem several times, I finally made a metal bracket from aluminum angle, drilled and tapped 4-40 holes in it, and drilled the plastic icemaker to mount it more permanently. I added a wire tie to hold the temperature sensor wire up and away from possible snag sources. The sensor wire and wire tie are not shown in the photo below, but if you have the tools to solder the wires and fabricate a bracket it helps a lot. It is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out.
Ice maker assembly upside down on bench.
Aluminum bracket and screws
Bracket installed. The sensor is not shown in this photo, but the wire comes out the right side and crosses in front of the metal bracket. The wire tie holds it to the bracket near the top center (hole not shown).
Sep 21, 2013 | Samsung Refrigerators
We are getting a 50.7 fuser error on our HP CM6040mfp printer and we replaced with new one but still it showing the fuser error. Do we need to reset the printer or any other issues .kindly help
Pressure release mechanism error in fuser, you already replaced the fuser.. then check below connectors.. Remove rear door...>Check connectors:J1720,J1965,J1964 &dc controller PCA connector J105 & J121..shown in fig>check fuser driving gear,>Fuser driving motor as shown in fig>Fuser sensor flag & pressure release sensor> perform sensor test... administration..scroll to trouble shoot..sensor test..perform all sensors as shown in display.. check sensot test passed or not...
Jan 31, 2012 | HP Office Equipment & Supplies
I get a te code all the time and a he code from time to time.
from Lg this is the meaning of the codes.
  • The heater circuit has failed if "HE" is displayed. Discontinue use and contact a service technician. The dishwasher requires servicing.
TE
  • "TE" means the thermistor has failed or the temperature of the water entering the dishwasher is over 194 degrees Fahrenheit. Turn the temperature down on the hot water heater in the home. If the error code reappears, replace the thermistor.
    By the sound of this your heating system is malfunctioning and needs service.
    If you need more on this let me know, but it is either your temperature sensor or your heating element or control board.
Oct 02, 2011 | LG 24 in. LD-12BW5 Free-standing...
I have canon w7200 printer and while switch on the printer it give error E02D02 pls guide me have to solve this problem
this means that you have problem with carriage home position error.
This is displayed when the carriage homeposition sensor could not detect the
carriage within the prescribed time.
Some of things that needs to be checked or replaced:
1.Visual check
Remove any foreign objects adhering to the carriage contact section, carriage
homeposition sensor, linear scale, and linear sensor.
2.Carriage homeposition sensor
Check operation using SERVICE MODE>I/O DISPLAY, and replace if anything
does not function normally.
3.Cable connection check
Replace the cable between the carriage homeposition sensor and engine controller
if the connection is not functioning normally.
4.Replace the linear scale.
5.Replace the linear encoder.
6.Replace the engine controller.
7.Replace the system controller.
How to enter Service mode:
Follow the procedure below to enter Service mode.
1) Turn off the printer.
2) Turn on the printer while holding down the [PAPER SOURCE] button and [Online]
button.
3) Check that "Canon W72xx" is shown on the display, and then release the buttons.
4) Next, "SERVICE MODE" is shown on the display. (If sheets are inserted, this will
be displayed after the sheets are loaded.)
5) Use the [down arrow] button to make a selection.
Hope that helps!
Apr 27, 2011 | Canon imagePROGRAF W7200 InkJet Printer
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Wiring Diagram for 3TC-TE.
did you have Diagram for 3TC-TE.now
Nov 10, 2009 | 1997 Toyota Previa
540 : y toner sensor error
Hi moneybaggz52:
Here is your problem.
Symptom:
When setting up a brand new C5100n or C5300n out of box, a toner sensor error is encountered.
The printer can display any one of the following errors:
543K: TONER SENSOR ERROR
540Y: TONER SENSOR ERROR
541M: TONER SENSOR ERROR
542C: TONER SENSOR ERROR
Cause:
This generally can be caused by two things.
1. The toner cartridge lock lever is not in the correct position.
2. The Transfer Belt lock levers are not in the correct position.
Resolution:
Check the appropriate toner cartridge lock lever (Shown below) and make sure that it is in the correct position.
0.110?openelement&fieldelemformat=gif 2.1ac?openelement&fieldelemformat=gif
CORRECT POSTITION INCORRECT POSITION
Check both transfer belt lock levers (Shown below) to ensure that they are in the correct position.
5.2eea?openelement&fieldelemformat=gif
CORRECT POSITION
10.4086?openelement&fieldelemformat=gif
INCORRECT POSITION
Hopes this helps
May 24, 2009 | OKI C5500n Laser Printer
My microwave oven is displaying sensor error
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
Nov 19, 2008 | GE JE620 Microwave Oven
Konica Minolta magicolor 4650DN Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
