Question about Braun C21 Smoothstyler Cordless Curling Iron
Braun smoothstyler does not ingnite to heat up
Braun 5705 will not charge, no lights, or run from power cord. This just occurred as it functioned fine and charged a month ago.
If you've never changed the batteries, the old batteries have probably damaged the circuit board from corrosion or heat. If cord is good and the lights do not work, it probably can not be repaired as circuit boards are no longer available for your model number
Apr 15, 2017 | Braun Health & Beauty
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
When razor is plugged in for charging the whole razor and cord get really hot! What is going on? It is a 4700 Series razor but it says For use only with Braun Series 549 class 2 power units. Do I need to...
After reviewing your Problem , My think says , its a Machine Problem... or may be its a Heat Problem , the Reason of Heating is that , the blade of machine is not installed Correctly , so Blur your Machine , clean it all ,then it will okey.
Jul 24, 2011 | Braun 7000 Series Foil and Cutterblock
I push the start button (the one with the red light) and the light turns on, but then nothing happens. (Yes, I had water in the tank and coffee in the filter part.) Usually, I push the button, the light...
Sounds like there an issue with the heating element. When the element goes bad it wont pull any water from the tank nor will it heat the water sending it up through the shower head and onto the beans. Unfortunately, since Braun has discontinued ALL kitchen appliances here in the US many of the parts are obsolete including the heating element for this machine.
Mar 29, 2011 | Braun FlavorSelect KF 180 Coffee Maker
My KF 180, Type 3115 Braun Coffee Maker stopped working, no heat, no purking but red light is on. I'm trying to open the bottom cover, have removed the centre screw but still can't get past the clips. I...
I have the same problem and even though I was able to disassemble the unit + get to the heating element, I fear I won't ever find a replacement part. Element is def bad; checked w/ohm meter across element - OPEN.
Like everything else we buy, coffee makers are throwaways when they fail so no one sells repair parts.
SAD!
Mar 13, 2011 | Braun FlavorSelect KF 180 Coffee Maker
My cooktop igniter keeps on igniting for no reason
This problem is due to a short to wires contact on the igniter sometimes this happens after a cleaning of the cook top with water so in this case you just use hair dryer and dry out the ingniter.
Other possible reasons are over heating of the ingniter contact so you have to remove it and clean wire contacts.
Finally the igniter contacts are melt together or sometimes full of burned oil and they need to be replaced. Inginter is not expensive part.
Oct 02, 2010 | Baumatic 34 in. B17.5 Gas Cooktop
Braun C21 Smoothstyler Cordless Curling Iron Logo
27 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
