Question about Microsoft Xbox 360 Console
My Xbox disc drive
Hello there. My name is David Warner and i have an isue with my Xbox 360 and i wondered if you could help me.
Basically, the disc drive will not open. I have tried everything to try and get it to open but i have had no luck and I'm stuck on what to do next. The rest of the console is fine, in fully working order. I don not want to try anything more myself-I have decided to seek professional help. Anything you tell me would be greatly appreciated.
Thank you very much.
Re: My Xbox disc drive
Hello david,i have d soulation but d problem is dat i dont know english language good,i will try 2 explaine it for u,sure ur ur disk drive is samsung bcoz all samsung have d same problem,there r 2 soulation,one of them is diffecult for u bcoz u have to open ur xbox and the drive,the easy one is,first press the open buttom then knock by ur fingers softly on d top of ur xbox above the drive,it will open,u just have 2 leave ur game disk in d drive always and it will open normaly always
Posted on Oct 11, 2007
0 characters
3 Points
When I play Black ops it loads but never goes past the black screen after you press play game. I have an Xbox 360 white and I'm wondering is that the problem. When i took it to my uncles 360 it worked...
I have never heard this issue before. You probably have a lager issue then what can be resolved here and might face future issue in the future. Is this the only game you are having issues with?
Seeing that you mentioned you have purchased a hard drive then I would recommend you install the game to your hard drive and try play after that. This will resolve any issues possably of your disk drive possably getting hung up during gameplay.
follow these instructions to get your game installed on your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Jul 17, 2011 | Microsoft Xbox 360 Console
Hello my xbox 360 wont read a disc it says open tray can u help me.
Your Xbox's disc drive is most likely broken. This happened to me about a month ago to a used xbox I had bought. You should call Xbox Live Support. They are very helpful.
Dec 14, 2009 | Microsoft Xbox 360 Console
Free repair help
XBOX 360 games have security codes embedded within. The motor is going out or likely filled with dust and debris that will not allow it to spin the game fast enough for the XBOX to recognize the security codes therefore telling you ''Please insert the disc into an Xbox 360 console''. Keep in mind, these DVD drives are nthing more than that. I am sure you can order a new motor online for a few dollars.
This is a guide to open your XBOX 360
ALL YOU NEED IS THE MOTOR (found on ebay, etc.) and the DVD drive will tell you the brand name right on the top of it once you have opened the console.
Good luck
Nov 04, 2009 | Microsoft Xbox 360 Console
Best XBOX 360 Disc Drive?
Hi, first let me say that as far as the DVD drives go I don't really think there is a significant difference in any of them. It basically boils down to who offered Microsoft a DVD drive cheaper. Next, I would strongly recommend that you get the same model/part number DVD drive.Reason is that you will have to do alot of work trying to get a different drive to work in your system. such as "flashing the drive" or having to change the sisterboards to make it work.
Aug 11, 2009 | Microsoft Xbox 360 Console
Cant play games due to "put disc into a xbox 360 console"?
This problem is caused by your disc drive.... A new disc drive bought off of ebay, generally costs about 50 bucks, including the shipping and handling..... You will need to open your xbox to get the model number... yes, it does matter... Once you get the new disc drive... you need to open up the old disc drive... and you will see a memory chip inside and you will need to be VERY careful not to rip any of the parts it is connected to... once you have the chip out... you will need to take the chip out of the new disc drive, and replace it with the chip from your old disc drive... (each xbox 360 has its own unique memory, which can only otherwise be installed by flashing it through a sata computer which much more complicated than it really should be).... once you put the old chip into the new disc drive... put everything back together... for a tutorial on opening an xbox 360 and also fixing disc drive in your 360... i recommend youtube,,, and the person's name i recommend is "fixyourownxbox" These videos are definitely helpful, and saved me mucho dinero $ :D.... Good luck... if you have anymore questions, dont be afraid to ask... i would be more than happy to answer them
Dec 27, 2008 | Microsoft Xbox 360 Console
I need the update for xbox 360 to play original xbox games
Hello my name is David,
I see you have a problem trying to play original xbox games on your xbox360. You will need
to update your machine by using a disk below is a site I have found that will tell you how to make the disk and how to use it. I think it should help you get started but even with the update not all games will work but most will. follow this page and follow the instructions it should help.Thank you for choosing for the help you need.
Nov 06, 2008 | Microsoft Xbox 360 Console
My xbox 360
Hello brian, i had the exact same problem with my xbox 360 and it is not your tv , it is simply the laser lens inside the disc drive. here are the steps you need to follow:
1)you need to take off the faceplate,
2)you need to pull the disc drive out, it will slide out easily, if the disc drive is stuck tap quite vigourosly on the top of the case (trust me it will not get damaged) while pulling out the disc drive.
3)open the disc drive and then take out the laser's lens and give it a good clean. the laser sometimes gets very dirty from sucking in dust particles from the air.
if this guide doesent help email me on:
regards caitlyn crighton
Nov 03, 2008 | Microsoft Xbox 360 Console
360 samsung disc fix
I bought a second hand drive from a seller on Ebay and swapped out the motors...basically replaced the hardware mechanisms. samsung drives being the oldest 360 drives tend to wear out first.If you cant get 2nd hand for reasonable price get one from Ebay coming from Hong Kong..
Oct 17, 2008 | Microsoft Xbox 360 Console
Xbox 360 says to play disc put it in an xbox 360 console
The box isn't loading the decoder softwarer for the Disc. The Xbox discs are encoded HD DVD-ROM discs, and the box needs to recognize them so it can load the decoder software. It probably says "play dvd" on the xbox dashboard right?
Apr 22, 2008 | Microsoft Xbox 360 Console
Disc Tray.
From what I no when the 360's light indicated flashes yellow it means it's overheated, try letting cool down.  I have had so many problems with my 360 and the cdrom drive is number 1.  When my drive started making all that noise i almost started to cry.  What i did was called the Xbox Helpdesk and they fixed the problem right away.  Call the Xbox Helpdesk at this number: 1-800-469-9269 (This munber will get you through faster).  if you ahve any more questions just let me know....
Oct 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
46 people viewed this question
Top Microsoft Video Game Consoles Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Martin Murray
Are you a Microsoft Video Game Console Expert? Answer questions, earn points and help others
