How to change wick in a gr9 comfort glow - Heating & Cooling
2 Suggested Answers
  • 3 Answers
SOURCE: Directions for changing wick on Dyna Glow RMC95C7
You can find a free downloadable manual here.  There is a signup process, but it's free.
Hope this helps!
Les
Posted on Feb 04, 2009
How do you replace the wick in a comfort glow model gr9a kerosene heater?
Post your question on this page , and you shall find the answer .
http://www.searspartsdirect.com/partsdirect/part-model/Comfort-glow-Parts/Heater-Parts/Repair-Maintenance/Questions-Answers/Model-GR9A/0218/0912160?mmlLandingSearch=GR9A&modelNumber=GR9A&diagramPageId=&documentId=
Sep 05, 2015 | Comfort Glow Heating & Cooling
How do you replace the wick on a comfort glo kerosene heater?
open the vent of wick, turn the knob clock wise to dismantle the wick from its fixing hole,after completion to out the wick,then try to insert the wick in its hole from below side,push gently the wick in &
rotate the adjusting knob to set the wick in
Dec 09, 2014 | Heating & Cooling
How do you replace just the top part of the wick on a comfort glow GR9B kerosene heater?
    • Remove the base plate from your Comfort Glow heater and expose the fuel tank. Lift the fuel tank out of the heater and set it to one side, well away from the heater. Note that the fuel tank is not connected to anything and will slide out easily.
    • 2 Run the heater until all the fuel in the lines is used, a process called "dry burnicon1.png," which usually only takes a few minutes. The fire will go out when the lines are empty. Turn the heater switch off and allow it to cool.
    • 3 Take the batteries out of the battery compartment on the back of the heater. This is an important safetyicon1.png step that keeps the heater from accidentally coming on while you are working on it.
    • 4 Lift the wick ring up and off, then remove the two nuts that secure the wick. The wick ring fits around the wick and the draft pipe -- the hollow tube that holds the wick -- and serves to hold the wick firmly in place.
    • 5 Slide the wick up as far as possible to reveal the positioning pin -- the small metal pin near the bottom of the wick. This pin is part of the wick and helpsicon1.png to ensure it is installed correctly. Push it out through the positioning hole in the draft pipe and lift the wick out of the heater.
    • 6 Fit the new wick onto the draft pipe and engage the positioning pin in the hole by pushing it in until it clicks into place. Move the wick down into the heater and replace the two nuts to secure it.
    • 7 Measure the distance between the wick and the draft pipe with the clearance gauge. The distance between the wick and the draft pipe should be the same all the way around, to ensure an even burn. Adjust the set screws as necessary to create even spacing. These are the small screws spaced evenly around the draft pipe that, when turned, move the pipe slightly so you can correct the spacing between the draft pipe and the wick.
    • 8 Replace the wick ring over the wick. Return the batteries to the battery compartment and the fuel tank to its compartment. The fuel tank will slide securely into its compartment in only one way. Replace the fuel compartment cover to complete the project.
Tips & Warnings
  • Keep the heater set on medium to medium-high for best results. Setting it too low or too high may cause soot to accumulate on the wick.
  • When operating a kerosene heater indoors, always have a working carbon monoxide alarm and a smoke alarm. These heaters are generally safe when in use, but an alarm will provide a safety backup in case the heater malfunctions
Oct 14, 2013 | Northern Tool 10,600 BTU Radiant Kerosene...
Where can I get a maintance manual for a GR9 Comfort Glow kerosene heater
You can find the Owners Manual in a downloadable and printable pdf format at
http://www.desatech.com/
Feb 07, 2011 | Heating & Cooling
Hi, I need a users manual for a Robeson Kerosene space heater model # 03-2619-91. I tried to light it with an open flame and nothing is happening. Thanks
DO not try to light with flame. Check fuel an vac lines first.then ck glow plug. to ck plug, remove leave power connected.to plug. ground plug to unit. Turn on switch.plug should glow bright red.
Jan 01, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Looking for a Comfort Glow Kerosene Heater Manual. Model #PHS/D
I am looking manual or answers for Comfort Glow Portable Heat System Model PHS/D with serial # 3D006270186
Jan 03, 2010 | Desa International Comfort Glow Infrared...
Hope this helps!
Les
Nov 25, 2008 | Heating & Cooling
Corona DK 23 kerosene heater won't start
try bringing your wick up to the fully raised position and pinch and bend the wick toward the igniter until they line up right. I have two coronas one of which has a broken igniter due to wear and tear. If you open the little door,press down the start lever,and light the wick with a barbecue grill lighter,you can safely light the heater if lining up the wick fails.
Oct 09, 2008 | Corona 23-DK Compact Heater
Kerosene heater will not wick up fuel from tank properly
Have you checked the length of wick. May not be long enough to get down into fuel. RON
Jan 26, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
