Question about Microsoft Windows XP Home Edition
Tel me how to install xp and.sata ahci driver
    Sergeant:
  • 296 Answers
Hi
after long research i have serched this site.plz chek this site ,i hope it will answer ur querry.
http://www.theacerguy.com/2008/06/how-to-install-the-ahci-drivers-after-installing-xp-in-ide-mode/
plz don forget to rate this answer.
thankyou
Posted on May 09, 2009
    Scholar:
  • 52 Answers
try to install windows by the help of following link :-
http://support.microsoft.com/kb/316941
http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
for sata :-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00758841&dlc=en&lc=en&cc=us
http://techrena.blogspot.com/2009/01/download-intel-sata-ahci-drivers-for.html
Asus motherboard problems Installed a new F2A55-MLK series to replace old ASUS board. Running XP and when I install the HDD it boots until the starting windows screen and get blue screen Asus tech no help.
go into the BIOS setup and find settings for SATA operation or something similar. the available options should be
1. Native SATA/IDE
2. AHCI supported
3. RAID
windows xp was installed with SATA support but requires special drivers for AHCI or RAID, so you should set your computer's SATA operation to native or IDE in order to solve the problem.
Additional tip:
next time you manage to boot to windows, boot to safe mode (boot while pressing F8), so you can review if all the drivers are well installed in device manager.
Oct 12, 2013 | Computers & Internet
I have toshiba satellite L505-S5990 model.i have installed windows xp by changing the settings in Bios that is sata hard disk enabled as compatable mode from AHCI.if i change to AHCI i can't install...
If you would like to make use of the SATA controller's AHCI features, you should enable this BIOS feature. But please note that enabling this feature requires you to load the SATA controller driver during the Windows XP installation routine.
If you do not intend to use the AHCI features, it's recommended that you disable this BIOS feature. This allows you to use the native Windows XP driver. You won't need to load the SATA controller driver during the Windows XP installation routine.
Read more: http://www.techmetica.com/howto/sata-ahci-mode-bios-setting.-what-does-it-do/#ixzz0y5ObAtN8
Aug 30, 2010 | Toshiba Computers & Internet
Can not get it installed on Note Book computer
You should go to BIOS and set "mapped as AHCI" to SATA/IDE mode". Find any information regarding AHCI, SATA/ID mode or anything like that on your BIOS. then try to install Windows XP Home Edition
Aug 24, 2010 | Microsoft Windows XP Home Edition
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
I can't downgrade Vista to Xp
You can install windows XP.
First go to BIOS and change sata mode to IDE mode
or option to disable SATA Native mode
then choose mode to IDE or disable SATA Native mode
then install windows XP
If there is no option about change sata mode in BIOS.
You should insert ahci driver to Windows XP CD using nLite
read this
http://komku.blogspot.com/2007/11/integrate-driver-into-windows.html
you can use this driver
http://cahya.prastyanto.googlepages.com/driver-sata-ahci-4920.zip
Or you can install windows by inserting driver when setup prompted
To install Windows XP with native SATA driver, perform the following steps:
Boot the notebook PC.
Insert the Windows XP installation CD into the optical CD/DVD drive.
Press the F6 key when prompted
Press the S key to specify the additional device.
Insert the SATA driver disk into drive A. (using floppy disk drive)
Follow the on-screen prompts.
Or if both way is cannot be done
i have the third way
use an unattended XP installation disk
you can download it from here:
http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
after you download
burn the CD image to the CD/DVD
then install XP using that CD/DVD
Jan 24, 2009 | Compaq Presario C700T Notebook
Windows XP boots endless if SATA is set to AHCI
this is'nt so easy here an example solution:
Enabling SATA mode to AHCI after XP Install (applicable to most laptops, or systems) If you want to enable SATA mode as AHCI after installing Windows XP, then read on. It's a bit of a long read because of step-by-step instructions, but worth it.
I did this on on Acer Aspire 5315-2153, it seems like the basic strategy should work on other laptops or systems.
For whatever reason, you may have installed Windows XP on your new laptops with SATA Native Mode disabled in the BIOS. Once XP is installed, enabling it in the BIOS will result in a BSOD upon loading Windows because XP doesn't have the correct drivers.
I read that enabling SATA native mode will give you a slight performance inrease and slightly increased battery life, so it seems worthwhile to me smile.gif
Here's how I did it on a Acer Aspire 5315-2153 running Windows XP (32 Bit version):
- Download the Intel Matrix Storage Manager software from Intel (I think it's iata_enu.exe)or AHCI_Intel_v7.5.0.1017_XP.zip from Acer web site.
- Extract files from AHCI_Intel_v7.5.0.1017_XP.zip to e.g. C:\AHCI_Intel_v7_5_0_1017_XP files need: (you may delete the rest)
iaahci.cat
iaahci.inf
iastor.cat
iastor.inf
iastor.sys
TXTSSETUP.OEM
- Now go to Device Manager, under IDE ATA/ATAPI controllers you should
see: Intel 82801HEM/HBM SATA AHCI Storage Controller
- Right-Click on that and select Update Driver
- Say no to connecting to Windows Update to search, hit Next
- Select Install fro a list or specific location (Advanced), hit Next
- Select "Don't search. I will choose the driver to install", hit Next
- Select Have Disk
- Browse to C:\AHCI_Intel_v7_5_0_1017_XP and highlight the iastor.inf file, hit Open
- Select OK
- Now you should have a list of controllers, for the Acer 5315-2153 choose Intel 82801HEM/HBM SATA AHCI Storage Controller, hit Next
- You'll get warned that installing the device driver is not recommended, click Yes to continue installing
- Click Finish
- Click Yes to restart your computer
When your computer boots up, you need to hit F2 to enter the BIOS. Change SATA mode to AHCI, save changes and exit.
After you log into Windows, your computer will find the "new" hardware. Wait until you get the popup message to restart your computer, say Yes to restart one last time.
You may download also from Intel the RAID/AHCI Software - Intel® Matrix Storage Manager (iata70_enu.exe 5640KB) and install it in your system, it may fix in case you got the wrong Intel 82801 AHCI controller.
I give credit to Jamie Rybarczyk at HP Business Support Center forum for doing most of typing.
http://forum.notebookreview.com/showthread.php?t=186471
Jan 06, 2009 | Computers & Internet
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
How to install XP on Toshiba Satellite L45-S7409
Hi
Ensure AHCI mode is turned off or set to Legacy/Compatible mode. If it says AHCI it will not boot XP
Aug 11, 2008 | Toshiba Satellite A100-S8111TD Notebook
ACER 4720Z
seems that it's a SATA drive and the drivers are not included in XP.
There are some tools available to include these drivers into the XP CD.
Search the net for 'xp-iso-builder' or 'n-Lite'.
This is not necessary if your laptop's got a floppy drive (i don't think so). Then the SATA drivers can easily be loaded by pressing F6 when booting from the XP CD.
Mar 02, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Home Edition Logo
188 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
