Question about Cisco Aironet 1131AG 802.11a, 802.11g/b (746320933474) Wireless Access Point
My PC is not detecting the wireless Access Point
Recently I upgraded my IOS of Cisco 1131 AP form 12.3(8) to 12.3(11). And the configuration remain the same. But now I am facing a problem like, when I enable my PC wireless software it cannot find the AP. I connected the AP in PC Network and tried. But my PC not able to detect the AP.
Can anyone please help me in this.
Make sure guest mode is set on the ssid so that it will broad cast.
Posted on Dec 05, 2007
    Problem Solver:
  • 5 Answers
You might double check to make sure the upgrade didn't disable one of you wireless protocols (a/b/g). You PC wirless card may only support certain types (b/g are common). Also double check you SSID is set. You should be able be able to do this via the http/htps config pages unless you have this disabled.
Posted on Nov 08, 2007
  • 49 Answers
Is your wireless adapter still ok? or is your wireless PC switch on? Try to check and then let me know.
Posted on Oct 25, 2007
Cisco Acces Point series 1020 Air-AP-1020-A-KG
This is an enterprise AP and needs to run with a Cisco router.
Mar 30, 2014 | Cisco Computers & Internet
Reset Access point Cisco 1020
If your current controller can't see the AP, then the 1020 can only be reset through the Controller it was originally configured with. It doesn't have a console port, so you have to connect it to the old controller and run "clear lwapp private-config"
Mar 25, 2014 | Symbol Spectrum24 4131 Access Point...
How to configure cisco aironet 1131 and how to find the getaway for this router ?
Have you read the quick start and installation guides?
http://www.cisco.com/en/US/products/ps6087/prod_installation_guides_list.html
Yes, the AP should be able to obtain an IP address via DHCP from your
Netopia router.
If this device is used, it may not be setup to aquire things via DHCP,
and you'll probably have to hookup over a console port and do password
recovery.
Cisco's aren't the easiest things to setup, they are more akin to a
box of tools, rather than a single purpose built item, and thus can
do quitealot, but you have to learn how to use the tool first. It will
then let you setup things quite advanced that the single-purpose built
item never imagined, but you have to know how to get there first, not
coast and do the advanced stuff later.
Dec 29, 2013 | Cisco Air-Ap1131G-A-K9 - Aironet 1131G...
Aironet 1100 ap amber led light
What controller are you using? You are correct - it is an IOS error. Usually the AP is not compatible with the WLC ios.
Mar 16, 2013 | Aironet 1100 802.11a/b/g AP...
Hi I have a AP 1131A K9. I was trying to reset the password of that. At the time of doing that, the boot file got erased. Now after booting up, it automatically comes into AP: mode. And it is showing...
On console you will see..AP: Step 1.Type format flash: on the AP and then hit enter Step 2. Enter the set command to assign an IP address, subnet mask, and default gateway tothe access point. Your entries should look like this example: bridge: set IP_ADDR 192.168.133.160bridge: set NETMASK 255.255.255.0bridge: set DEFAULT_ROUTER 192.168.133.1Note:-The system you are using must have tftpserver recomend by Cisco.You can download it from link givenbelow:http://tftpd32.jounin.net Also load the IOS file in the tftp server.Before step3.Step 3.Enter the tftp_init command to prepare the access point for TFTPbridge:tftp_initStep 4. Enter the tar command to load and inflate the new image from your TFTPserver. The command must include this information: .the -xtract option, which inflates theimage when it is loaded .the IP address of your TFTP server .the directory on the TFTPserver that contains the image .the name of the image .the destination for the image (theaccess point Flash) Your entry might look like this example: bridge: tar -xtracttftp://192.168.130.222/images/c1310-k9w7-tar.122_15.JA1 flash:In the meantime if you needassistance please feel free to contact me at any time.
Aug 01, 2011 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Can't connect to my Cisco Aironet 350 wireless Access Point
Did you setup and configure your Cisco aironet 350 directly from your laptop? I would verify the IP configuration on your laptop and make sure that your Default Gateway and subnet mask and DNS are set correctly. Give it a static address on the same subnet and see if it can see the router. Hope that helps!
Cheers!
J the Guru
Sep 09, 2017 | Cisco Aironet 350 Series Wireless...
Cisco Aironet 1200
if u have an cisco acs and windows AD, i'd configure the ap to point to acs and configure acs external db to point to AD. let ur windows dhcp server hand out IPs to your mobile devices.
Feb 18, 2008 | Cisco Computers & Internet
Configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Jan 17, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Erasing the flash....
Toast...looks like you killed your entire IOS installation...it will have to be reloaded to the flash...
Aug 21, 2007 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Cisco Aironet 1131AG 802.11a, 802.11g/b (746320933474) Wireless Access Point Logo
244 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
