Question about Turboair TAS-24H Split System Air Conditioner
Conditioner e7 error code amcoraire - Turboair TAS-24H Split System Air Conditioner
E7 code on amcoraire mini ductless unit
E7 i= "External Feedback Problem" which is a communication problem. There is a cable from the outdoor unit to the indoor unit ,check that cable is secured to the unit,check connections for tightness.
Here is the manual including instructions.
http://www.acwholesalers.com/EasyEditor/assets/amcor%20duo%20uchw-h12%20owners%20manual.pdf
Nov 08, 2015 | AmcorAire UCHW-H18AF2 Split System Air...
Code error E7
I'm not sure if NewAir is made by Gree -- they supply many. On Gree units, E7 simply means one unit is requesting heating while another is requesting cooling and you can't have both at the same time. So that's the first thing to check. Very simple, very common, doesn't indicate that anything is wrong with the system.
Apr 05, 2014 | NewAir ACS-1200H Split System Air...
E7 error message
The E-7 error code means the 2 wire defrost cable between the outdoor & indoor unit is disconnected or broken
Sep 10, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Hello im trying to trouble shoot two split systems the electrical wires were crossed for the two units I fixed it the compressors wont come on, wall unit says e7? This is on the Amcoraire ac split systems.
E7 indicates an "External Feedback Problem" which sounds like a communication problem. I believe there is a sensor cable that runs from the outdoor unit to the indoor unit also. Check that all cables are properly run to the appropriate unit and check all connections for tightness. Here is the link to a manual that includes installation and wiring instructions.
Mar 16, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
WE have Amcoraire Mini split unit heat pumps. One is
P 4 code means problem with the outdoor unit, Most likely low on refrigerant. Check all copper pipe connections for leaks first, then add refrigerant after checking pressures.
Jan 17, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Low cool air
Because the model numbers are based on the country in which you bought the unit, you will have to do the research yourself on the error code for your unit. Once you find out what the error code is you can determine if low refrigerant caused the problem. Here is the contact info website to download your manual.
http://www.amcoraire.com/index.html
Apr 03, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
Turboair TAS-24H Split System Air Conditioner Logo
48 people viewed this question
Top Turboair Heating & Cooling Experts
Steve F
Darial Jr Lasaria
Darial Jr Lasaria
Tom Chichester
Are you a Turboair Heating and Cooling Expert? Answer questions, earn points and help others
