Question about Cooktops
Install frigilux cooktop - Cooktops
Light comes on that cooktop is on but burners don't get hot. Just had new counters intstall so cooktop was re-installed.
dear friend,
was you cooktop in good working order prior to your counters being installed? How old is it? If so i would suggest you get the electrician back who re-installed it & get him to check it out. Could be a loose wire.
Cheers
Jim.S.
Dec 25, 2010 | General Electric Profile PP945 30 in....
Can i install bosch cooktop in a 26-1/2 by 19-1/2
No you will not be able to put in that cut out. The reason why is you will have 2 inches on each side or 4 inches on one side.
Apr 17, 2010 | Bosch PCK755UC 30 in. Gas Cooktop
I need an installation manual for a cvg4380p Jenn-Air cooktop
Hello Chuck,
Your request is for the Jenn-Air CVG-4280P gas cooktop installation instructions, even though the info at the top of the page states a JED8430 electric cooktop,
If I've got your request correct, here's a link to the installation instructions for the CVG-4280P cooktop.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380PII.pdf
If you'd also like the owner's manual for that same cooktop, here's the link for that too:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380P.pdf
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 13, 2009 | Jenn-Air JED8430 Electric Cooktop
How to install GE cooktop spark module WB21X10029
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 02, 2009 | GE 30 in. JGP337 Gas Cooktop
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
I need to know the ampere raitng or the wattage so I can size the electrical feeder to the cooktop
The installation guide, on page 3, says this cooktop can use up to 9700 watts. It also says to use #8AWG wire and a 40 amp 240 volt breaker. You can download the installation guide here:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318201427revA.pdf
Feb 19, 2009 | Frigidaire PLEC36S9EC Stainless Steel...
Propane conversion
All gaq cooktops come from the factory ready to be installed to natural gas. If the only gas available is propane the orifices have to be changed. The orifices are product specific and must be ordered for your particular stove.
That being said, if this is a new cooktop you have the answer. If this is a used cooktop and you do not know which style of orifices are installed now just contact your propane company and they will be happy to help you for free.
good luck with this. and please remember to rate my answer.
Feb 12, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Hello posted this question but family getting antsy without a cooktop. I am installing a 36 inch GE Profile gas cooktop, jgp970, along with a Frigidaire downdraft vent, pl36DD. The gas inlet pipe on the...
the reason for the fitting instruction for the regulator to be connected directly is that flex hoses deteriorate and allow a dangerous situation
AS gas is not in the diy domain I recommend that you get in an accredited gas fitter who will make a solid pipe to allow the fitment of the regulator away from the motor
While he is there he can adjust the regulator to get it all working correctly
Mar 13, 2017 | GE 36 in.JGP970 Gas Cooktop
Poor gas flow to GE cooktop
Try a bigger inlet pipe sounds like pipe too small for load .
Apr 11, 2017 | GE 36 in.JGP970 Gas Cooktop
Can't boil water on new Maytag Gas Cooktop
No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
Nov 18, 2006 | Maytag MGC6536 Gas Cooktop
Cooktops Logo
51 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
