Question about Metz Cameras
Capacitor new capacitor type
What type and size capacitor goes on a Baldor 1/3 HP bench grinder
Much would depend on whether it is a start capacitor or a start/run capacitor.
If there is a switch on the end of the rotor operated by centrifugal weights it will be a start capacitor only but if there is no centrifugal switch the capacitor will need to do double-duty and the value could be critical.
Contacting a dealer or the manufacturer would be favourite but a motor specialist might be able to make a recommendation. Guessing isn't really an option and the working voltage of the capacitor is equally important. Most generic capacitors are rated in dc volts and for them to be safe used on ac mains the working voltage must be considerably higher than the rms value of the ac mains. It is best to use only capacitors rated for ac mains.
You will probably find the capacitor as a spare part from a dealer will be prohibitively expensive but once the value has been discovered and if possible the manufacturer, part number and so forth, great savings can be made by sourcing direct from the capacitor manufacturer.
I recently paid less than £5 plus carriage plus VAT for a capacitor the machine manufacturer wanted more then £60 for.
Nov 04, 2015 | Baldor Grinders
Capacitor type
take capacitor to electric supply store to match up
Apr 20, 2012 | Century New Magnetek Pool Spa Pump Motor...
Order capacitors for Hunter fanscapacitors Where
you can call hunter technical support. the number is-- 1-888-830-1326, they should be able to help! have a good day !
Jun 03, 2011 | Hunter 52" Ceiling Fan With Light And...
I HAVE A 5MFD OVAL CAPACITOR WITH 2 PINS CONNECTOR AND MY OLD ONE HAS 3 YELLOW GOES TO ONE OF THE PINS RED AND PURPLE GOES TO ANOTHER PIN AND THE BROWN GOES TO ANOTHER PIN THIS IS FOR THE OLD CAPACITOR BUT...
You need to replace it with a matching 3 pole capacitor. Look at the rating on your old capacitor, on a 3 pole it should read (ie): 5/35 mfd. This is a split type capacitor and usually controls 2 motors. There are a wide varety of capacitors. Also, one of the terminals will be a common terminal, so be sure to put it back together correctly.
Jul 09, 2010 | Goodman CKL24AR24 Air Conditioner
New capacitors now freeview unavailable
what was the need to replace capacitors. if so on which circuit? Hope you have replaced the right value and type of the capacitor. Observe whether soldered points getting into other pcb track. Clean them again and give a try.
Jul 08, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Frigidaire front load washer won't spin, belt looks good, makes noise
Don't have much experience on Frigidaire. Is the motor a brush type, capacitor type or one of those new DC types? If it's got brushes and they are ok, then I would say your armature is up the creek. If it's a capacitor type (unlikely) then the capacitor is most likely duff. If it's the new DC type it could be a lot of things, most likely the module which breaksdown and passes an AC component in the motor supply which make the motor tremble but not rotate
Nov 02, 2008 | Frigidaire ATF6000ES Front Load Washer
GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Oct 03, 2008 | Washing Machines
Tv won't come on
Hello to all from Tom Arnold, WA6OVP
Subject: Repair of computer monitors or flat panel TV’s.
History:
Recently my wife's 27-inch AKAI (LCT21AS) 27-inch flat panel HDTV with DVD player quit working. Years ago, when I had an analog computer monitor quit operating; Joe Fadden WA6DDF had mentioned to me, that often computer monitor problems were caused by the monitor's power supply. Joe also said these power supply problems were often caused by failed electrolytic capacitors. Joe said he was able to fix many computer monitors by just changing all of the power supply electrolytic capacitors. Rather the fix that failed monitor, I just a bought a new one.
Symptoms:
The inoperative HDTV had been bought at COSTCO and had already been returned once to a COSTCO repair center for repairs. Cost to ship and insure the HDTV was 67 dollars. We received back a new HDTV set. Turn around time was over a month, with many long distance telephone calls being required. The new HDTV worked for about three months after it was received. When the returned HDTV failed, it trapped a DVD disc that had been left in the HDTV DVD player. The new HDTV failure symptoms were the same as the original HDTV failure. The red led indication would not change to green when the remotes power on button was pushed. There was no picture and no sound. The remote is required to operate the TV set.
Economics:
My wife's HDTV with internal DVD player was very expensive. Worse yet, the trapped DVD disc was the movie Flash Gorden Space Soldiers 1936. A local TV shop wanted 85 dollars to look at the failed HDTV; repairs were 75 dollars labor an hour plus parts. I quickly figured out that if I could fix the problem it would save a lot of time and money.
Internet Search:
I checked the Internet to determine if other AKAI owners had similar problems with their HDTV sets. There were lots of AKAI 27 inch and 32 inch HDTV set owners listing problems. Without exception all of the complaints concerned the HDTV power supply PC board and failed electrolytic capacitors.
General Internet Consensus:
Most of the AKAI HDTV sets worked just great and that many had been sold worldwide. There were some AKAI HDTV sets that did have power supply problems. Most of the AKAI HDTV set owners were not very pleased with either AKAI or the COSTCO response to the inoperative HDTV power supply problem.
Trouble Shooting:
All electrical power was removed from the HDTV set. The HDTV was placed face down on a workbench with a piece of cardboard to protect the display screen. The HDTV back panel cover was removed. There were many screws of several different sizes. The power supply PC board was separate from the rest of the set's components and was easily identified. The power supply PC board contained several different individual different voltage power supplies. Three electrolytic capacitors located on the PC board had obviously failed. The tops of these three capacitors were puffed out. Often when electrolytic capacitors fail they get over heated and the top of the capacitor is puffed out displaying an over pressurized appearance. The power supplies on the PC board were of the switching type. Switching type power supplies are also used in computer monitors to save money and weight.
Power Supply PC Board Removal:
The power supply PC board was mounted to the HDTV back panel with several screws. These screws were removed. There also several multi-pin connectors attached to the PC board. These connectors were numbered with a black felt marker to ensure correct reinstallation. The connectors were Hot-glued in place. A sharp knife was used to remove the hot glue. The connectors were removed.
Repair:
The three suspect failed capacitors were easily removed. The three capacitors were each 1000 ufd and rated at 16 working volts. The other power supply PC board electrolytic capacitors were visibly checked. Three new capacitors were installed, they were rated at 1000 ufd at 25 working volts. On the PC board the three electrolytic capacitors were in just one of the power supply circuits and were identified as EC18, EC19, and EC20.
The New Electrolytic capacitors:
These were low impedance / high reliability radial lead polarized aluminum capacitors, they have a plus and minus connection pins. Correct installation of any polarized capacitor is required. The three new electrolytic capacitors were specifically designed and rated for service in switching type power supply circuits. Switching type power supply electrolytic capacitors need to be both very robust and designed for use in high frequency circuits. General-purpose aluminum electrolytic capacitors should not be used in switching type power supplies, if capacitors designed for switching power supplies can be obtained.
Final Repair Steps:
The PC board was reinstalled without the electrical connectors to the PC board being hot glued. The HDTV back panel cover was refastened. Watched episodes one through five of Space Soldiers. It was well worth the time and three electrolytic capacitors to fix the problem. The repairs saved a lot of time and money. The repair was very simple and not the least challenging. It took longer to remove and then reinstall the HDTV back cover panel than it took to replace the three failed capacitors.
Safety:
These types of repairs should not be attempted without a complete understanding of the dangers involved with working on electrical equipment, especially working around power supplies and charged capacitors. Proper desoldiering and soldiering techniques need to be used.
Conclusions:
Flat screen computer monitors and TV sets do fail. Repairs of electronic equipment can be very expensive. When your computer monitor or flat screen TV does fail, you might consider a visible inspection of the equipments power supply. A simple repair might save you a lot of time and money.
Aug 12, 2008 | Akai LCT2785TA 27 in. LCD Television
Parts Needed
Where did you get the capacitor from?
Dec 10, 2007 | Planar PDP-42BK 42 in. Plasma HDTV
Yamaha RX-V1 Power
Got the same problem and did some searching.
Strange thing is that next day the amp works fine.
This is what I found on http://www.forums.hcsd.com.au/Blah.pl?m-1210733289/s-8/
SYMPTOM: The power cannot be turned on, or the protection circuit is activated to turn off the power.
CAUSE: Fluid leakage occurs from the backup capacitor C633 0.047F 5.5V (C662 in the case of RX-V3000/DSP-AX2) on the Function PCB and causes a short with the adjacent components and between patterns, resulting in operation of the protection circuit. Fluid leakage tends to occur with this capacitor particularly with high internal cabinet temperatures, with or without the power on. Often, the leakage is only visible with very careful inspection.
SOLUTION: Two types of backup capacitors are now available with a longer expected service life. When servicing, thoroughly clean the leaked fluid from the PCB and from under any nearby components before replacing the capacitor. There are models other than those mentioned above that use the subject backup capacitor. Check them for fluid leakage and replace the capacitor as needed.
PART(S): Old
Ref. No. Part No. Description Remarks
C633 or
C662
VT740700
V3860300 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* VU545000 ELECTROLYTIC CAP 0.047F/5.5V
Horizontal type
New
C633 or
C662 WD294400 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* WD292000 ELECTROLYTIC CAP 0.047F/5.5V Horizontal type
Nov 29, 2007 | Yamaha RX-V1000 Receiver
Cameras Logo
Top Metz Cameras Experts
Doberman
Neil
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
