Question about Belkin Home Office UPS System
Battery is not loading
I have a Belkin F6H500frUNV UPS. It's about 10 month old and now the unit didn't charge the Battery anymore. Battery level falls and falls every day, even if nothing is connected on it.
For this night I take the Battery out and charge it with the charge unit of my bike. Now the battery level is at 70% but still going down (nothing connected, UPS on AC power). So it seems that the unit doesnt deliver any power to charge the Battery.
What is it possible to do?
I know it is still on guarantee but unfortunately I can't found the Invoice
Thanks for help
  • morrie52 May 11, 2008
    Similar problem. Unit doesn't seem to charge battery. New battery purchased, problem not solved. JMM. Thanks for any ideas.
    Habit-Forming:
  • 188 Answers
Dear marc 68
i think u have problem in ur battery.....if battery is in warenty.replace it emidately...
try a new battery......
i m 100% sure u r problem will be solved man..
dont forget to vote for me...
dont forget to tell me u r problem solved or not
best regards & best of luck..
even u can mail me at my mailing add- sigma_shiva1@yahoo.co.in
Posted on Oct 13, 2007
  • SHIVAJI YADAV
    SHIVAJI YADAV Nov 05, 2007
    hey dude.....u did not make any repley....for u r problem solution ...
    hope it is solved.......
    Was this solution helpful? Show your Appreciation by rating it:
    pls vote for me man..& IF U R PROBLEM IS SOLVED RATE MY SOLUTION AS SOLVED
How long do batteries last
If they cannot hold the charge or do not charge then get rid of the thing and get a new one. Should be much cheaper than when you bought the one you have now.
Sep 22, 2013 | Belkin (F6C800-UNV-PL) UPS System
Backup power ends quickly even with new battery
What is the load on the unit? How old is it?
The symptom can occur if the load is too large. It will also happen when the unit reaches a certain age.
I've found that the low-end consumer UPS's should be replaced when the battery fails. The charging circuitry usually fails to charge the battery even with a new battery soon after the replacement.
The way I check if the battery or the UPS charging system has failed is with a voltmeter to give the current voltage and a variable DC power supply (whatever is appropriate for the battery) to attempt to charge the battery. I can watch the battery discharge with an oscilliscope if I want a full trace of the unit.) Charge the battery fully then watch the unit over time. If the battery itself is bad, you won't get the full charge or it will discharge as soon as it is removed from the power supply.
I hope this helps.
(the server UPS's tend to be a better choice if you want to replace the battery and keep the UPS.)
Aug 21, 2011 | APC (BE500U-WEB) (BE500UWEB) UPS System
Not holding a charge can it be repaired or better to replace?
If your UPS is not holding Charges, this means that the Battery does not carry the load when AC fails. Check to see that the batteries are okay by testing the individual batteries on load using a potentiometer load with multimeter. If the battery voltage drops below 10V replace the batteries and your UPS be okay
Jun 08, 2010 | Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS...
Belkin F6C1500-TW-RK discharged new batteries, won't recharge
This sounds like a battery issue...I would have the unit and batteries tested at your nearest batteriesplus store... www.batteriesplus.com
May 07, 2010 | Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS...
Battery does not get charged fully... and does not support load of computer in backup mode...
hello,
If the battery backup unit is over 2.5 years old then you will need to replace the battery. Go to your local electronics parts house or battery distributor. They will have the gel cell battery you need in stock. These units are just like small car batteries, after a few years of use they will break down and not hold a full charge. When this starts to happen the battery life is about to be over, it will hold less and less charge until one day no power at all and then the UPS will not power on. The UPS have a monitor circuit that will prevent them from powering up with a dead or missing battery. The replacement battery should run less than $20.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 05, 2010 | APC Back-UPS CS 500VA UPS System
Belkin doesn't work
Battery has a limited life. You must leave the UPS plugged-in all the time and the computer plugged into it.
Dec 28, 2009 | Belkin Universal UPS UPS System
Belkin UPS F6C900-UNV burns up after replacing the battery.
I just replaced the batteries on my Belkin F6C900-UNV. They died just short of 3 years of use, which is what I would expect. My unit contained two 12 volt, 4.5 amp-hour batteries that were connected in series. When connected in SERIES (one battery's red terminal is connected to the other battery's black terminal), the two batteries behave as if they were one 24 volt battery. Therefore, this UPS is designed to charge a 24 volt battery. When replacing the batteries, you cannot use a single 12 volt battery. This will fry the battery. You can use either two 12 volt batteries connected in series, or one 24 volt battery.
I measured the charging voltage of my two new batteries (connected in SERIES), and find it charging at 24.6 volts. This is an ideal float voltage to maintain these sealed AGM (absorbed glass mat) lead acid batteries (13.2 volts per battery). The replacement batteries are similar to the originals, each measuring about 2.7x3.5 inches and 4 inches high and rated at 12 volts, 5 amp-hours. They can be purchased for $20 or less each, so for $40 I now have a fully functional UPS, good for another 3 years.
Feb 25, 2009 | Belkin (f6c900-unv) UPS System
Belkin ups not working properly.... green and RED light on ...indicates bad battery. But unit not more than 1 yr old, no battery time at all when plug pulled...not enen i min on (desk to an d monitor
Your batteries are weak...(causes
1:-not powering the UPS for a longtime
2:- long use(3 to 4 years) )...you will have to replace them
PLEASE RATE ME.................
May 25, 2008 | Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS...
My model FC6120-unv is dead
If you've got nothing my guess is its something more than the battery as it should still be able to draw power if its plugged in. If its within the warranty period (3 yrs, I believe). Go to the belkin webpage and to their ups support and start the process to return it and get it fixed/replaced. A couple months ago I had a F6C500-UNV that suddenly died on me just like yours - no nothing. It cost me $13.00 or so bucks to ship the broken unit to Belkin; a week or two later I got a brand spankin' new F6C550 or whatever they currently sell in that same voltage area back from them. The cost to RMA the broken unit was much cheaper than even buying a new battery for the old and now discontinued unit.
Dec 26, 2007 | Belkin ( F6C500-UNV) (Bundle)...
Belkin Home Office UPS System Logo
133 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
jason
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
