Question about Lenovo R61 T7300 Notebook
I tried to switch on my laptop and it started booting and suddenly went off.From then on its not even booting.Nor does it show the green light which comes on, when you plug it to a power source. Its basically dead. Nothing is happening.Its as if you have plugged it in, and the lappy appears as if its shut down and not connected to a power source. Lenovo R61 thinkpad
  • Lenovo Master
  • 32,281 Answers
When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
A faulty adapter or the connector is not making proper electrical contact, this causes the LED not to illuminate. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Check the adapter with a multi-meter, the voltage reading should be a slightly higher than the voltage that is printed on the label on the adapter. If the voltage is more than 10% below the nominated voltage then replace the adapter it is faulty.
Posted on May 09, 2009
2 Suggested Answers
  • 10 Answers
SOURCE: Lenovo R61 Dead
The power supply in most computers has a fuse, either internal or external, that can blow without you noticing. Basically, you've been on battery operation this whole time, and the battery's finally gone dead.
It will be necessary to open the case and examine the power supply section. It may be possible to replace the fuse yourself, but any operation of this nature that involves opening the case will void any warranty you may have.
Posted on Sep 06, 2009
Sony vaio notebook won't switch on
Can you see any display from the screen? if its a new hard drive, with no Operating System the it show anything at all, try to insert a boot cd and boot from the cd
Oct 22, 2012 | Computers & Internet
My Toshiba Tecra M4 losses power and switchs off.
first to do is check the HDD RAM,or the wireless card,,
Jun 25, 2010 | Toshiba Satellite M35X-S149 Notebook
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
I have a Dell C400. All of a sudden it won't boot. Can't even access BIOS. Display has nothing. Battery light keeps flashing from green to amber.
Remove the battery and the hard drive , use the charger and try to boot to BIOS. If it fails then the laptop is dead.
Jan 17, 2010 | Dell Lattitude D600 Notebook
Acer 5920 -The power suddenly went off.
Probably this is due to surge current happend in the circute, butter not to switch on your lap. consult the service centre. Its is better not use the same adaptor for more troble shooting.
Oct 13, 2009 | Acer Aspire 5920-6727 Notebook
My Acer Extensa 5220 just blinks the power green light when switched on and goes off immediately.? Can anybody assist?
Try reseating memory modules.
Try taking out all parts like Hard drive, memory, wireless card. Does it do anything? IF it beeps, then put the memeory back in and try again.
Reseat all of them. Then try. Then if you have two memory sticks try one at a time in different slots. If nothing changes.. probably a bad motherboard or processor. (motherboard is more likely)
Sep 08, 2009 | Computers & Internet
Lenovo R61 Dead
Sep 06, 2009 | Lenovo R61 T7300 Notebook
I have IBM LAPTOP thinkpad T43 SERIES. it was working tiil yesteraday. Suddenly it turns switch off. I thought its the problem with AC adapter. I bought a new one. It shows it turn it on but its switch...
It's not necessarily hardware related, can you boot into Bios? If you can try to boot info safe mode, that's F8 for most PCs. I would suspect something with your motherboard drivers, then again it could just be your battery. Not all laptops will operate with the battery out, there is some kind of failsafe to prevent overheating in some, because without a battery the power supply can be fried sometimes.
Hope this helps
Dec 04, 2008 | IBM ThinkPad T40 2373 Notebook
Problem with booting my device
seems your file system was corrupted. try to boot your laptop through cd..installation would show the partition details. here just check all partition are in gud file system. if it shows like "unknown" u need to format the partition. if u have any important data in that partition just connect that hdd as a secondary disk and try to copy the data's
Jul 24, 2008 | Microsoft Computers & Internet
My mobile is dead
I just had this happen to me yesterday. I fought with my phone for about 3 hours removing the battery and trying to restart it. It would take about 5 minutes for it to finally boot and once it did the touch screen would not work. So I did a hard boot and within 5 minutes my phone was back to normal. I lost all my contacts but I just did a restore with the backup software. To do a hard boot hold down the red and green buttons on the front of the phone and push the reset button on the bottom of the phone with the stylus. The reset button is on the right side of the power/usb plug. As I said my phone was back to normal in just a few minutes.
Jul 16, 2008 | HTC Touch P3450 Smartphone
Open Questions:
Lenovo R61 T7300 Notebook Logo
327 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
