Question about Consew 226R2 Sewing Machine
How do i adjust stitch length on a consew cn-2230 machine
4 Suggested Answers
  • 3 Answers
SOURCE: How do you adjust the stitch length on Consew 226 R-1?
if it is like the other industrial machines I've used, here is the general principle:
On the machine there is a button with no label. Hold button while turning the handwheel toward you. When you feel the button depressl you can adjust the length. Hold the button in the machine and crank the hand wheel back to decrease the length of ths titch and foward to increase it. I usually put a notch on the fly wheel for my standard length with some nailpolish. Release the button and sew to test the length.
Posted on Jun 16, 2009
  • 30 Answers
SOURCE: I have just aquired a
The stitch length adjustment is the same as some other Consew post models, located on the manual advance wheel
See :
http://consew.marginspluslive.com/images/products/instruction%20manuals/287RB.pdf
page 4
Posted on May 18, 2011
  • 1564 Answers
SOURCE: stitch length suddenly stops and only sews on @ 1 length regardless if set @ 5
Cas: I'm going to give you a link to a google ebook that talks about these issues. Unfortunately, it's only a preview but it does show a great trouble shooting chart and mentions consew machines..
http://books.google.com/books?id=GLadvNufjaUC&pg=SA4-PA1&lpg=SA4-PA1&dq=sewing+machine+repair&source=bl&ots=RL9-FxFV_Z&sig=ZxOm_8lMAbm6uIActH_GwiFwXug&hl=en&sa=X&ei=d3ZLUIbyKcX9iwLh24DIDg&ved=0CFoQ6AEwBw#v=onepage&q=sewing%20machine%20repair&f=false
Good luck
Posted on Sep 08, 2012
Part number for the stitch length adjustment knob
This machine doesn't use a knob, there's a button to push which engages the stitch regulator under the machine.
Jan 22, 2014 | Consew 255RB-3 Mechanical Sewing Machine
New Consew 146 rb 1-a Stitch length dial is set at
I would suggest taking the machine in to be adjusted and make sure they can work on that model machine, and if they can, then the same day you get it back, sew on it to make sure the problem is fixed.
Oct 23, 2013 | Consew 7360R-1 Mechanical Sewing Machine
I have just aquired a consew 288r-1(no manual) How do I adjust the stitch length, and tensions?
See :
page 4
May 11, 2011 | Consew 288RB-1
I have a Consew 206RB and it feeds backwords. How can I fix this?
I have a Consew 206RB-1 , if I had This problem I would think the stitch length setting or the downward pressure of the upper walking foot is wrong.
If you set the stitch length to less than 0 it would be in reverse and feed backward.
Dec 02, 2010 | Consew 206RB
My stitch length is not what I have it set for. I set it on 5
I assume you mean it stitches 6 or 8 when set at 5.
Because the number shown on the wheel says "5" doesn't necessarily mean 5. It's just an approximation. You'll note that when turning the wheel there's tension. The numbers are just numbers. It isn't a micrometer, its a sewing machine. So, you can simply adjust to get the stitch you want then make a mark on the wheel at that point. You may end up between 4 and 5, or between 5 and 6. No matter. Wherever you get 5 per inch is where the adjustment is.
Aug 05, 2009 | Consew 226R-1
Jun 16, 2009 | Consew 226R-1
Lengthening stitches.
You can adjust the length of the Zigzag (Satin)
Stitch using the buttonhole fine-adjusting screw. You will find it right above your stitch selection dial.
> For a longer stitch length, turn the
buttonhole fine-adjusting screw with a large
screwdriver in the + direction.
> For a shorter stitch length, turn the
screwdriver in the - direction.
Hope this helps
Apr 06, 2009 | Brother XL-2230 Mechanical Sewing Machine
Consew Industrial Machine 2270 stitch length dial not working
Sounds like it is either out of time or the adjuster spring needs to be replaced.
Mar 14, 2009 | Sewing Machines
In need to know how to adjust my stiching and needle adjustment/ the bobing is jamming(not stiching)
Stitch length is adjusted by holding down the small button in the bed and turning the wheel to the desired number of stitches. The numbers are either on the wheel, next to the belt pulley, or under a small cover on top of the machine. Hold the button and turn the wheel either toward or away from you to get the stitches you want.
Bobbin jamming is either because of incorrect top tension or incorrect threading. Go to www.consew.com and get a parts and operation manual for free for a 224. It 's the same as the 226.
Mar 10, 2009 | Consew 226R-1
Open Questions:
See all Consew 226R2 Sewing Machine Questions
Consew 226R2 Sewing Machine Logo
42 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
