Question about Sony Video Game Consoles & Games
Bravia otrum mode turn off - Sony Video Game Consoles & Games
How to stop sony demo mode
  • Turn on your Sony Braviaicon1.png.
  • Press and hold the Up Arrow button on the remote control
  • Press the Powerlb_icon1.png button on the TV while still holding down the Up Arrow button. The TV will turn off and then turn itself back on.
  • Release the Up Arrow button. Once the TV turns itself back on, it will restore your Sony Bravia to its factory settings.
  • http://www.ehow.com/how_5855646_reset-sony-bravia-tv.html
    May 17, 2013 | Sony KDL 40CX520 40 CX520 Series Full HD...
    Sony Bravia stuck on Bravia screen
    "Bravia Screen". Not sure what you mean. Is it in maintenance mode?
    Option 1.. With the tv plugged in and the power OFF (this is called standby mode) take your remote (make sure it has fresh batteries) follow this sequence on the remote. You have to press the buttons within a second of each other in this order:
    DISPLAY - 5 - VOLUME + TV POWER.
    When the screen comes on hit JUMP right away and it puts you into a little screen for maintenance. Simply turn off the television to exit maintenance mode.
    2. If your remote is bad, ie, new batteries don't fix it, might suggest a new one.
    3. If you can't get a new remote, power on the television using the power button and then hit the menu button. Use the up and down keys to see if you are stuck in some weird screen or something.
    4. If you are connecting something to the television (like a dvd, a playstation, computer, etc) try unplugging everything and test each port individually, using the side buttons as described in part 3 to change the input mode to the port you are using.
    Hope this helps
    Mar 10, 2013 | Televison & Video
    MY SONY BRAVIA SAYS STORE DISPLAY MODE ON WHEN TURNING ON. HOW DO TURN THIS OFF?
    Press the "Home" button on the remote to go to the "cross bar" -> then go to "Settings" -> then "Set Up" -> then "Factory Settings" and select "Restore Factory Settings" -> upon completion the OSD will start in Set Up Mode -> select "Home" on the Shop Display page.
    Jul 28, 2011 | Sony BRAVIA KDL-32EX308 32" LCD TV
    How to connect camera to sony bravia tv.
    Connect your camera in RCA cable (the one with a red, white, yellow connector for audio/video connection). Then connect it to your Bravia TV.. Set your Bravia TV in video mode, (the mode when you're playing DVD player in your TV)..
    Note: Your video mode depends on where you connect your RCA cable. There are up to 3 video mode, Video-1,Video-2,Video-3
    Then turn on your camera..
    May 22, 2011 | Cameras
    Turn demo mode off on Sony Bravia TV 40"
    Here'show to turn off the demo mode,
    Power ON the television
    (Use remote Commander)
    1.Select "TV" mode (not AV, demo mode can't switch offwhen you are in AV)
    2. Press the "home" button on the remote.
    3. Select "settings"
    4. Select "set up"
    5. Scroll down to "factory setting" and restore them.
    6. When it asks home or shop display select "home".
    Feb 14, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
    I bought a Sony Bravia EX7/40 today. It's store demo mode appears every 60 seconds. How do I turn this off
    • Press the home button on the remote to go to the cross bar thing.
    • Choose settings
    • Look For set up
    • Scroll down to factory setting and restore them.
    • After that it will go to set up mode when it asks home or shop/display select "home".
      This will disable the Demo Mode.
    Nov 16, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
    I can't turn off the demo mode on my sony bravia tv
    Press Menu on tv remote, go to Settings and select Factory Reset and press enter button on remote, tv will reset to factory default settings and turn Off and On again itself, now select HOME mode instead of Shop mode to avoid demo mode and go by initial setup screen instructions.
    Above are generic info about Sony bravia tv, let me know model number of your tv if you do not see factory reset option in settings menu.
    Thanks.
    Nov 08, 2010 | Sony Televison & Video
    Turn demo mode off on Sony Bravia home theater
    On your remote;
    Press the Home button
    Scroll left to settings
    System settings
    Auto-start up - go through setup and select "Home" (not store)
    Sorted
    Dec 06, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
    How to unlock AV on hotel tv philips HT5504/01Z?
    mon tv mise en vielle apres toutes les 15 minutes
    Aug 30, 2009 | Philips 20PT6441 20" TV
    Video Game Consoles & Games Logo
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
