Question about Kitchen Ranges
Tappan stove pilot light
Where is the pilot light on model tgf336aud?
  • 183 Answers
SOURCE: Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Posted on Jul 28, 2007
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
bigg t
  • 640 Answers
SOURCE: Tappan Stove 5 burner with Oven
does the pilot seem low?you can remove the pilot then clean it out,let me know.
Posted on Nov 11, 2007
RJTech
  • 32 Answers
SOURCE: Tappan oven bought in 1994 / Oven not working...pilot works, burners work
you need to replace the oven ignitor coil.
Posted on Dec 18, 2007
  • 4 Answers
SOURCE: pilot light
I'd like to know, too. Thank you for your help.
Posted on Aug 26, 2008
I just moved into a condo I am renting and the Tappan gas oven/stove stays hot when it is not even on. The part that is hot is the top between the burners. Is that normal?
Probably the pilot light. You should be able to lift the top of the stove for cleaning ... try lifting it ... to see and verify for yourself this is the case.
This is very typical of a stove fired by a pilot light.
Thanks for your question at FixYa.com
If you found this helpful, the courtesy of a positive vote will be appreciated. Thank you.
Sep 19, 2010 | Tappan TGF320 Gas Kitchen Range
Will gas top flowing if pilot lights go out?
hI no they will stay on you should be able to turn them off
Jan 07, 2010 | Tappan 24 in. Freestanding Gas Range...
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Pilot light keeps going out on one side of my Tappan stove (TPF303BWA). The 2 left burners are fine but the right side burners will not stay lit. I can light them with a match and they stay on for...
HI, Try using a needle to clean out the pilot orfice. Most models have an adjustment for the pilot light. It would be located near the manifold under the top panel.
I hope this helps you. Please let me knwo if I can assist you further.
Vic
Jun 05, 2009 | Tappan TGF303BW Gas Range
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
OVEN PILOT WENT OUT
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Feb 14, 2009 | Tappan 24 in. Freestanding Gas Range...
Pilot light
Nov 11, 2007 | Tappan TGF363 Gas Kitchen Range
Nov 10, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan Gas stove
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Kitchen Ranges Logo
13 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
