Question about Motorola Mobility HS850 Consumer Headset
H350 once my razr finds this device it will not store it how can i get it to save this blooth tooth in the phone in order to use it?
    Sergeant:
  • 316 Answers
Once it finds it it should ask for a passcode which is 0000or 1234
then it should store it.
If this does not work delete any devices of the same name in you phone and try pairing it again
Posted on Nov 07, 2007
SOURCE:
Bluetooth will not stay connected on my 2006 BMW z4
Depending how far of a range your getting, between your razr and your blue-tooth is important. Any range of 30ft or over is less likely to connect/search/and or pair with any capable blue-tooth device.
Try pair the two devices again, but remember to save the trusted blue-tooth to your device so that disconnection can be prevented only by your command.
If your blue-tooth has a short, or battery is extremely low then that TOO can cause disconnection.
Hope this information can be of a benefit to you. Thanks.
Mar 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Want to remove Motoraola H350 Bluetooth from MOTORAZRV3T phone
Hi
Try going into paired devices or active devices and delete from there
Feb 20, 2009 | Motorola Mobility H350 Wireless Headset
The phone with which my H350 Motorola wireless head set was paired , got lost. How to pair the head set with my new HTC phone
you have to hold the button on the top till the blue stays on then go in your phone to the blue tooth settings and search for the device it should find it and be paired again
Nov 27, 2008 | Motorola Mobility H350 Wireless Headset
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
How do I put the Blue Tooth device into pairing mode?
first switch on ur mobiles bluetooth connection......... then switch on ur moto H350..... then it automatically ask to pair with ur mobile jst accept it........ and then enter the pass code 0000.........kkkk... then it get paired... kk..........
Oct 26, 2008 | Motorola Mobility H350 Wireless Headset
Motorola Razr 2 V8 blue tooth will not power on
my motrola v8 b tooth can b powered on , and it can recieve data but i cannt send data to any blooth tooth device , the send botton in the last not working, cn u tell me why.....
Oct 18, 2008 | Cell Phones
Blue-Tooth set-up
usually you press and hold the button on the bluetooth headset device for 10 secs, the led will change color, then you pick up your phone get into the bluetooth part of the settings and tell the phone to look for it. Then after that when it finds it, the pin will probably be 00000.
Look it up on google the model of your headset you should be able to find the pin.
Aug 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Don't know the pin to set up my bluetooth
Most Motorola bluetooths have a default passcode of 0000 and cannot be changed.
Mar 14, 2008 | Motorola Mobility RAZR V3
Motorola H350 Bluetooth headset
Ineed my pin code for h350 bluetooth headset
Sep 22, 2007 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Motorola RAZR V3 problems with a Motorola H350 Bluetooth Headset
I do not provide the user manual, however, function of the H350 is very similar to the H500 and we are providing a link to the H500 user guide. Just copy and paste this link into your browser and Motorola will explain how to connect your Bluetooth Headset. http://telecom.hellodirect.com/eBiz/pdf/cellphoneheadsets/Motorola_H500_Manual.pdf
Aug 23, 2007 | Motorola Mobility V3 Handsfree Headset...
Motorola Mobility HS850 Consumer Headset Logo
41 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
