Kodak C310 error code 3524 PAPER JAM - Office Equipment & Supplies
SOURCE: Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Posted on Aug 15, 2008
  • 285 Answers
SOURCE: error code 3820
try the baack of the printer. open it up from the back
Posted on Jan 28, 2009
Ajkill
  • 2035 Answers
SOURCE: E3 error code
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jan 31, 2009
  • 20 Answers
SOURCE: Paper jam error light on kodak esp 5
  1. Remove the paper tray.
  2. Disconnect the power cord, wait 5 seconds, then reconnect the power cord.
    NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
  3. Replace the paper tray.
  4. Press the Print button on the printer to resume printing.
Posted on Apr 01, 2009
SOURCE: My Kodak ESP5 keeps saying
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Posted on Jul 21, 2009
My printer is showing an error code 3524 (paper jam) yet there is no paper jammed. It says press OK to continue, but just instantly returns to the same message. It does seem that the cartridge head is
had the same problem it only happened when i turned the ac off . humidity i guess. i started buying paper made for a inkjet cost a little more but it seems like it helping.
Oct 24, 2014 | Kodak ESP C310 AllInOne InkJet Printer
Kodak ESP Office 2170 Paper Jam code 3524
Actually, to fix it, you need to disassemble the printer.
The smallest part inside the printer can trigger this error code. The printer needs to be taken apart, clean, check the paper feeder that it's not crooked or missing a piece.
I recommend that you take it to a profesional, because if you do it yourself, you need to have a bottle of crazy glue, in case something breaks, that's how we fix it.
May 16, 2017 | Kodak ESP Office 2170 All-in-One Printer
My kodak printer esp 3.2 is giving me an error code 3533 paper jam but there is no paper jammed and when i put new paper in it, it still wont print and keeps giving me the same error code 3533
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Sep 12, 2013 | Kodak ESP C310 AllInOne InkJet Printer
Koday esp c310 error 3533
I have code 3533 code but paper is not jam
Sep 13, 2012 | Kodak ESP 5 Printer
Get a paper jam error code 3533 but nothing in the copier.
I hit on mine several times and slammed it on the table a few more times and it cleared the jam. Seriously.
Apr 04, 2012 | Kodak ESP C310 AllInOne InkJet Printer
My kodak esp c310 tells me paper jam how do i fix it
Turn the Printer on
Wait for the error message
open the printer
move the ink cartridge a little bit to the right
on the left side you have three gear wheels
move the frontmost forward to move the printer carriage it should go easy.
Close the Printer and press OK to test the printer.
If it not works move the gear wheel further and further and maybe backwards to remove stuff which block the carriage
Nov 28, 2011 | Kodak Office Equipment & Supplies
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Apr 01, 2009 | Kodak ESP 5 Printer
120 people viewed this question
k24674
jasbo
jasbo
