Question about Traeger Industries Grilling
Auger is making squealing noise and not turning
3 Suggested Answers
  • 2428 Answers
SOURCE: I have a Toro 521
Short of disamblling you need to get the paper out try drianing the gas fliping over wet wetting the paper hopefuly its not in plastic and take like a long screw driver or a similar tool and keep working at it once you get the auger to move a little work it back and forthit will come out keep wetting it It may not be easy at first but it will come out and where do you live where you have snow now im an new englander
Posted on Nov 22, 2010
jolyanne5
  • 77 Answers
SOURCE: 03 tundra makes a noise when making left turn
maybe the ball joint or tie rod check it .
Posted on Apr 20, 2012
Why is my dryer making a squealing noise
It's hard to tell without hearing it or knowing where the noise is coming from. It could be a bearing or a belt or seal.
Aug 07, 2014 | Kenmore Dryers
Fix ariens snowblower 520 dies when engaging the auger lever
Your front end is jammed. Its either frozen or there is a rock or something jamming it up. Before you start engine reach down chute and turn back impeller that throws the snow out of blower. Should turn freely. when its free its fixed. You will probably need a new belt.
Feb 17, 2014 | Garden
Possible a/c problem, squealing noise constant, but gets better when a/c is turned on.
You did not give the make model and year, and I did not get all of the story.
Are you saying the noise goes away when the ac is on, or off ?
Dec 20, 2012 | Cars & Trucks
Snowblower stalls without reason and now makes a squeeling noise. craftsman 8.5 hp model 536.891851
Check the drive belts at the engine for wear or damage. It could also be a bad bearing at some point in the auger/impeller or wheel drive. Try to pinpoint the source of the noise and what you do that makes it squeal. Good luck!
Jan 22, 2011 | Craftsman Garden
I have a Toro 521 smowblower. We jammed up the auger with the daily newpaper and now the engine runs but when you turn on the auger the drive belts squeal and the engine slows but the auger does not turn....
Nov 22, 2010 | Garden
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Ice maker auger not turning
ICE MAKER NOT MAKING ICE ON MY GE SIDE BY SIDE FRIDGE.
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud squealing noise
The noise is most likely the serpentine belt. Check it's condition and that of the belt tensioner. It sounds like the belt is slipping, causing the squealing noise u describe. As the belt warms up, it's getting a better 'grip' and the noise stops. Turning on the heat also turns on the a/c in newer cars, this added drag on the belt (one more component to turn, the a/c compressor) would explain why it happens when u turn on the heat. Is the belt original? If yes, it's time to change it, and check the belt tensioner to make sure it's doing it's job of keeping the belt snug on all the pulleys. Let me know how u make out.
Dec 13, 2008 | 2003 Nissan Pathfinder
HP 2100 makes squealing noises
It could be a roller, a drum, sometimes the auger in the cartridge can do it.
Should have a technician look at it to find specifically where it is comming from.
Jun 13, 2008 | HP LaserJet 2100 Printer
Ice maker will not dispense ice.
ON THE AUGER MOTOR IS A COUPLER THAT SLIDES INTO THE AUGER WHEN THE BIN IS INSTALLED. SOMETIMES, THE COUPLER WILL ROUND OUT THE FLAT SIDE OF THE CENTER HOLE. THIS WILL CAUSE THE MOTOR TO CONTINUE TO TURN, BUT THE COUPLER WILL REMAIN STILL DUE TO THE RESISTANCE OF THE BIN AUGER. ALSO, BE SURE THE ICE IN THE BIN HASN'T MELTED TOGETHER BINDING UP THE AUGER. IF NECESSARY, REMOVE THE ICE AND START OVER WITH FRESH ICE. YOU MAY NEED TO REPLCAE THE COUPLER OR AUGER MOTOR.
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Grilling Logo
112 people viewed this question
Top Traeger Industries Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
